1. AVOID SCAMMERS!
      (1) Do not transact without protections in place! Different payment options may limit your payment protection
      (2) Use a payment service like PayPal WITH (!) purchase protection.
      (3) Terms like 'Friends and Family' are a warning that NO payment protection exists.
      (4) Avoid transactions with new members with no history and "family or friend of friend" offers.
      (5) If you do not understand the payment method you're being asked to use; stop and do not proceed until you do
      (6) If you receive a suspicious private message, click the "report" link and let us know!
    LISTINGS MUST INCLUDE: Price, Location, Product Description(s) and NO Links to CL or EBAY or your post will not be allowed. Read the rules!
Sold 2012 Ktm 990 Adv
Discussion in 'Bikes' started by Polska93, Jul 20, 2021.
  1. Polska93
    Polska93 Adventurer
    Jul 5, 2021
    10
    St Louis Missouri USA
    2012 Ktm 990 Adventure White ABS
    36,223 miles and will not be going up. Located just south of St Louis Missouri.
    Rade Garage Rally lights with amber Halos and 6,000k brightness lights
    6” slim LED lightbar
    KTM H&B luggage and racks, powder coated Ktm orange, all locks work, 2 sets of keys.
    CJ Designs rear box mount plate
    HEED front upper crash bars and 4 crash bar storage luggage.
    Renazco Seat
    Suspension has been completely re valved and re sprung for adventure riding by ShockZone in St Louis MO in April of 2021. Valved like an aggressive enduro, front springs 7.0kg/mm, rear spring 16.5kg/mm (can get you all shim specs if needed)
    Swing arm and steering head bearings done with suspension upgrade.
    Warp 9 Elite 21/18 wheel set with new rotors with new wheel bearings front and back as of May 2021
    Rear wheel is 3m tubeless, front remained tubed
    Shinko tires has 75%+ life left
    New JT sprockets and chain 17/42 and new oem chain slider and rollers as of May 2021
    SW Motech skid plate and rear master guard
    New Brembo rear master cylinder, all new Brembo re build kits in all 3 calipers and front master cylinder as of May 2021.
    Clutch master cylinder rebuilt with genuine Magura rebuild kit, brand new oem clutch slave cylinder, new magura blood clutch oil. All done as of May 2021.
    Thorax side stand relocation bracket
    Smart Moto side stand switch eliminator
    Billet aluminum shift lever
    ProTaper Evo Adventure bend bars with renthal super bike grips
    Garmin Zumo 595LM GPS in a Touratech gps mount, lock works and have 2 sets of keys. Updated last riding season. Comes with Ktm linked TPMS sensors for front and rear wheels
    Heated grips
    New Bad Wolf brand hazard button on dash, no more deteriorating oem switch.
    Orange anodized bodywork hardware
    Rottweiler snap out glove box
    Rottweiler under seat storage bin
    Rottweiler entire smog delete (canister delete, block off plates, o2 delete, o2 bung block off plugs, sas purge dongles, and vacuum lines caps)
    CJ designs billet clutch basket
    CJ designs clutch cover
    Triple Clamp Moto air intake
    Moto Hooligan Performance oval secondary butterflies in the throttle bodies
    Valves adjusted in May of 2021, new valve cover gaskets and spark plug o-rings
    New ngk iridium spark plugs when valves were adjusted
    New oem Ktm water pump rebuild kit May 2021 (shaft, seal, both bearings, both clips and water pump cover o-ring along with new oem radiator cap, thermostat and 85c fan switch.)
    2nd radiator fan kit
    New orange CV4 silicone radiator hoses with AS3 hose clamps
    FMF Q-4 twin exhaust cans, re packed May 2021, new oem exhaust gaskets and hardware all around.
    Throttle body synchronization checked via vacuum gauges and did not need to be adjusted.
    Ecm has been tuned by Skunkwerks in Nixa MO via TuneECM hookup.
    Shorai lithium battery
    Everything works as it should 110%. ABS is functional.
    I am most likely missing a few things that have been done but the bike is turn key ready to rock. Multiple shoulder surgeries have kept me off it and I finally got around to getting it ready for a new owner.
    3 small paint chips that have been touched up with color matched paint pen. One on the light cowl, one on the rear right number plate, and one right next to the front right turn signal.
    Extras include a box of oil filters, spare air filter for the TCM intake, 45t rear JT sprocket, extra orange body work hardware, and 90% of the OEM parts.
    I am more than happy to provide documentation on all work performed and get pictures of anything.
    2 keys, clean and clear MO title in my name, and owners manual/service paperwork from the original owner and the owner before me.
    Sold for $8000
    34A1DAF7-BCDA-40C0-B74E-B4D6AD00244A.jpeg 89F50608-FE71-4CE4-93C5-D5C302D78069.jpeg D5C1B7C7-5B64-460B-94E2-60F94A98D7A4.jpeg 915DF32C-C478-45AE-A4A1-0EA354F08D85.jpeg 8FAC6FE6-5DB3-4158-8B75-8486EF216B51.jpeg
  2. CrazyBiker
    CrazyBiker Fast N Smooth
    Aug 28, 2007
    504
    Fremont, CA
    WOW
    Polska93 likes this.
  3. Polska93
    Polska93 Adventurer
    Jul 5, 2021
    10
    Bump, price dropped
  4. Polska93
    Polska93 Adventurer
    Jul 5, 2021
    10
    Sold on Aug 1st 2021
