2012 multi with 15k used 7k
Discussion in 'Moto Bellissima: All Other Dualsports' started by satz, Sep 21, 2019.
  1. satz
    satz Been here awhile
    May 9, 2005
    157
    Mass
    Looking at a touring s .multi 2012. Has the ohlin and some nice bits. 15 k is not done. Desmo full service chang need to be done . But forks were just serviced. No smu . Tires and sprocket decent and I can do it if needed next summer but I do need to the big serivce.
    Price around 7k.
    Total newbie on duc. Previous 200k miles on bandit ,fz1,fjr ,vstrom and vstar touring when I decided to be a pirate for a while.
  2. equ
    equ Adventurer
    Sep 28, 2010
    98
    FWIW, I sold my 2013 touring S with 7.5k miles for $8k. It was up for belts (due to time), but had new fluids and tires. It was halfway to the 15k desmo service, which is more than $1k. The 2013-14's are a bit smoother at low throttle; some claim the 10-12's are overall better... Who knows. Also the 2013-14's are Skyhook/Sachs fully electronic. Not Ohlins, very smooth ride, push button suspension modes. Finally 13-14's have LED headlights and a bit better stock windscreen.
    satz likes this.
  3. Tripped1
    Tripped1 Smoove, Smoove like velvet.
    Aug 6, 2009
    33,213
    Nippon
    Call a couple dealers and see what they want for the belt/valve service.
    My last big was $1100 but I had them do a new chain and a set of tires as well, otherwise I had already done oil, anti-freeze, and battery. They SHOULD present you with a list and it should be less than a $1000 assuming that they don't need to shim it, then that goes up about $400-500 on hours involved.
    My bike is on its forth major, and hasn't had a shim yet.
    ....and if you get it the $400 for the Ohlins SCU automagic box is worth it.
    TrailBreak and satz like this.
  4. TrailBreak
    TrailBreak Willfully Stupid
    Nov 10, 2014
    239
    Vermont
    I've been eyeing that Ohlins box for my '11.
  5. ebrew
    ebrew Motorcycle A.D.D.
    Nov 4, 2005
    2,153
    Denver colo
    13-14 have different main bearings
    Nice 13 GT in the flea market ( nothing to do with it )
  6. ebrew
    Nov 4, 2005
    2,153
    Denver colo
  7. Tripped1
    Aug 6, 2009
    33,213
    Nippon
    Doooooo EEEEETTT!
    I have Sport, Touring and Enduro on the box
    Sport with pretty low TC/ABS settings 150 High
    Touring with the TC/ABS cranked up and 150 Low.....aka rain mode.
    Enduro/urban are the same setting as far as the suspension is concerned. So Enduro is on the box 100hp, for gravel roads and whatnot
    Urban I have set with manual track settings (set on Fuji Speedway), 150high and very minimal nannies I think 1-2 on DTC and ABS or solo hoon mode.
    Also saves trying to set the suspension for all 4 weights in every mode, kick everything down to one and let the auto-magic box deal with it, I only had to tweek the preload settings......which I am running WAY heavier than stock springs.
    I love how I could adjust everything to my taste, spent a couple months tinkering with it, but once I had it dialed I haven't touched any of that in a couple years.
  8. TrailBreak
    Nov 10, 2014
    239
    Vermont
    I have to pull the forks off this winter for servicing and I was debating getting some heavier springs while I'm at it. I weigh around 200 lbs and I usually ride with my girlfriend as well. She won't let me use "sport" mode because its too stiff, but "touring" mode is stupidly soft.
    #8
  9. Tripped1
    Aug 6, 2009
    33,213
    Nippon
    I went up to 0.95s in the front and a 1.25 in the back, and its still a little soft with both of us and all of the gear.
    I am 225 or so geared and she is like 150 or so plus crap, and I have the big panniers, a 48L case and a 20L tankbag that keepsthe tools.....we are runnign it at about max tire weights
    #9
    TrailBreak likes this.
