2013 F700GS stalled while riding. Will Crank, but will not start.
Discussion in 'Parallel Universe' started by ultane, Feb 11, 2020.
  1. ultane
    ultane sqeezin the bag
    Feb 20, 2008
    2,815
    The dry side of the blood brain barrier
    Thanks Kathy!
    I agree!
    #21
  2. ultane
    Feb 20, 2008
    2,815
    I’m pretty sure it does, but don’t know where it is. I’ll have my son look on the REPROM, or I will when I get there.
    #22
  3. ultane
    Feb 20, 2008
    2,815
    I’ll try and find something on that.
    #23
  4. ultane
    Feb 20, 2008
    2,815
    Finally heard back from my son. He decided to use Lucas fuel treatment in four gallons of marine (ethanol free) fuel. He says that it starts but that he has to keep it above 2000 rpms or it will stall. He wanted to take the bike out and run it, but it was pouring down rain. I couldn’t get info about how smooth it ran over 2000 rpms, just that it ran.
    I recommended him just letting the mixture sit, so that it may dissolve more of the solidified alcohol from the ‘phase separated’ 5 year old BP high test. I’m also not sure if it’s bad for a twin to run for somewhat extended ride if they are firing unevenly. I had recommended some Techron, but he chose the Lucas.
    So, right now, I asked him to do a careful inspection using a flashlight for chewed or loose wires, birds nests, etc.
    When I go up, I’ll run the GS 911 and use Grocks Harmonizer to make sure injectors are balanced.
    Thanks all. More later.
    #24
    JimsBeemer likes this.
  5. ultane
    Feb 20, 2008
    2,815
    My son said that the bike has never been tipped over.
    #25
  6. atomicalex
    atomicalex silly aluminium boxes Super Moderator Supporter
    May 21, 2012
    10,927
    Detroit mostly
    A friend had this issue - the switch failed internally, IIRC. Her bike had never gone over, either. It would just randomly die when enough fuel vapor condensed on the switch. I am really stretching my memory here, but there was something with the tank vent that was screwing with the setup.
    #26
    ultane likes this.
  7. ultane
    Feb 20, 2008
    2,815
    I’m not even sure what to look for...
    #27
  8. dpike
    dpike BeeKeeper Supporter
    Nov 21, 2015
    1,819
    New Jersey
    yeah, there's a small check valve that has a ball in it, sometimes that ball sticks. there's ball 'ectomy threads here. on my f800 is was located under the right side rear trim plastic.
    i'd still start with draining whatever concoction of old/new/treated fuel is in there and replacing the fuel filter.
    #28
    4RF RDS, ultane and atomicalex like this.
  9. ultane
    Feb 20, 2008
    2,815
    Once again, thanks dpike.
    #29
