2013 + Honda CB1100
Discussion in 'Road Warriors' started by cabanza, Aug 24, 2012.
  1. DESERT VIPER
    DESERT VIPER ATK 605
    Jul 18, 2016
    67
    La Quinta, ca.
    Thanks Dao 1 for the explanation ....Mobiker I think you’re right.....I don’t like the gap on the Wyverns....if I put on pipes they’ll be these from Endurance Racing 76013B3E-27F1-46F8-A8CF-90B78E3AA7FA.jpeg 0F1A105C-2FDB-4915-88A7-F7F21026CA44.jpeg
  2. Mobiker
    Mobiker Long timer Supporter
    Apr 22, 2003
    6,525
    Missouri
    Those look a lot better. A lot.
    I still think it looks fine the way you have it.
    DESERT VIPER likes this.
  3. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
    Desert's K10 transformation will look AMAZING with ANY config, stock 4:2, 4:4, or 4:1 ,
    as per Samurider pic shows...
    IF there's anything irregular w/ a 4:1 on a K10, I simply don't see it.
    that K10 kit is a game changer, it elevates this bike into a whole new level of aesthetics.
    DESERT VIPER and Backlund like this.
  4. Backlund
    Backlund Long timer
    Nov 30, 2013
    1,267
    Rapid City, South Dakota
    I'm definately going to sell my '17 CB1100EX, the decision has been made. I love looking at it, but find myself not actually riding it enough to justify hanging on to it, and we've pretty much exceeded the space limit in our garage by one bike.
    fyr, hb9400 and DESERT VIPER like this.
  5. cblais19
    cblais19 Long timer
    Nov 3, 2017
    6,144
    NoVA
    I'm so glad you're around, because you make me feel less guilty about how quickly I go through bikes.
    Backlund, DESERT VIPER and Mobiker like this.
  6. DESERT VIPER
    Jul 18, 2016
    67
    La Quinta, ca.
    Nice stable...is that a water buffalo along the wall?
  7. DESERT VIPER
    Jul 18, 2016
    67
    La Quinta, ca.
    Sure would be easier to keep them shiny! And I could keep $2100 in my wallet!
  8. Backlund
    Backlund Long timer
    Nov 30, 2013
    1,267
    Yes, the '76 I picked up late last year. It should be up and running before summer, then the plan is to 'nickle and dime' it back up to a very good condition cosmetically over the next several years.
    Here it is right after I brought it back from Kansas City, I rode it two days, then started to pull it apart a bit to start fixing some things up.
    I bought a Delkevic full reproduction exhaust system for it, it will get a repaint (tank and sidecovers) next month, and the instrument cluster will be sent off for a complete restoration towards the end of this month.
    1/2 of the Delkevic repro exhaust...
  9. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
  10. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
    This may be old news, but anyhow....
    July, 2019:
    Patents hint at new Honda CB1100
    ".....there appear to be changes to the bottom end, with a smaller clutch cover that hints at changes to the transmission. The exhausts are also new, with header pipes that sweep across to the right hand side, a little like the current CB650R or the 1970s CB400F, gathering into a single end can."
    "The current CB1100 has a full duplex frame, with two steel tubes running up and over the engine to the headstock, and another two cradling the motor from underneath. That design has gone in these patent images, replaced by a half-duplex frame that keeps the two under-engine cradles but has a single, thick spine running over the top. In many ways the design is more ‘authentic’ than the existing CB1100’s chassis, as the original CB750 featured a half-duplex backbone chassis."
    "The seat subframe is also different, triangulated to a point higher up above the swingarm pivot, near the monoshock’s upper mount. That makes for a significant visual change for the bike, with a lighter appearance for the rear end."
    ".....it appears that Honda is working on a system that uses the front mudguard to help scoop air, ejecting it through a vent that focusses the flow towards the centre two cylinders."
    "Honda’s patent .... showing computer-simulated airflow diagrams of the design."
    https://www.bennetts.co.uk/bikesocial/news-and-views/news/2019/july/patents-hint-at-new-honda-cb1100
    DESERT VIPER and HapHazard like this.
  11. DESERT VIPER
    Jul 18, 2016
    67
    La Quinta, ca.
    Curious how the new tank will look Dao....
  12. DESERT VIPER
    Jul 18, 2016
    67
    La Quinta, ca.
    I have a Chrome Delkevic 4 into 4 on order for my Z900rs......that will be a blast with some sticky rubber riding thru the Black Hills area.....LOVE 2 strokes, here is mine E4938C16-C81E-4BFA-B7BB-AC84791D0A83.jpeg
    1 wheel peel and jethrocephus like this.
  13. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
    :D
  14. Jim K.
    Jim K. Long timer
    Jan 14, 2011
    2,541
    New Haven, Ct.
    At risk of sounding like a cranky geezer, I hope the new sub frame design doesn't bring about the jacked up, "cat in heat" rear end look, that's become so common. It makes luggage carrying awkward & sure doesn't help with pillion comfort. Plus, visually, it strikes a sour note when there's a foot & a half of space above the rear wheel on a bike that has maybe 5" of suspension travel back there.
  15. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
    I concur
    vs.:
  16. Dao1
    Dao1 Long timer
    Mar 17, 2014
    2,203
    Austin TX
  17. milo
    milo Been here awhile
    Aug 4, 2001
    972
    Clifton Mills, Almost Heaven.
    I concur as well. And don't point the muffler 45 degrees up, keep it lower and pointing straight back. On the front I'd like to see an 18" wheel with a real fender.
  18. PAULIBIKER
    PAULIBIKER Long timer
    Mar 13, 2010
    1,485
    ANKENY, IOWA
    This trend has GOT to stop!
    Have heard awesome things about the Z900, but can’t get over the rear end.
  19. Jim K.
    Jim K. Long timer
    Jan 14, 2011
    2,541
    New Haven, Ct.
    Oddly, I bought a Z 900 RS "Cafe" last week! The butt end is still canted up too high for my taste, but virtually everything else on the bike suited me to a tee, so I bit.
    I think we'll just have to ride this trend out, just like square headlights & 16" front wheels. I try to keep in mind the most encouraging line in the bible.... "and this too shall pass...".
  20. HapHazard
    HapHazard Be Kind - Rewind
    Dec 30, 2009
    6,776
    Central CT
    Congrats on the purchase!
    Now if it would just stop raining...
    (at least it isn't snow)
    Jim K. likes this.
