2013 KTM Adventure 1190
Discussion in 'Hard. Core. (1090/1190/1290)' started by goodcat8, Apr 23, 2012.
  1. Bamboo Baby
    Bamboo Baby Been here awhile
    Aug 4, 2010
    329
    Port Elizabeth South Africa.
    Did you check your front discs both sides?
    On the GS with floating discs, that click sound is normal on some bikes.
  2. IgorBorisenko
    IgorBorisenko adventurer
    Jan 20, 2014
    101
    Ljubljana
    thats a loose\not tight\not set bearing somewhere in the headset.
  3. waterboy222
    waterboy222 Dirt Road Explorer
    Sep 23, 2014
    178
    Grand Lake, OK
    Im having the EXACT same issue with mine.. at only 800 miles.. Been doing it since 400 miles. I posted in the problems thread as well, hoping I can get an answer on where to steer the dealer when I take it in for service next week
  4. Alarm
    Alarm Been here awhile
    Nov 11, 2010
    300
    Could you give us any further feedback , or someone that owns this setup?
    Does the windscreen wobble a lot at speed over 100km/h ? Does the air go over the helmet ?
  5. 6USMC6
    6USMC6 -U-
    Jan 5, 2009
    4,891
    I have an X-Screen on another bike. Mine is the clamp-on.
    No, it doesn't wobble at speed (my windscreen does in fact bend backwards slightly at speed and of course the X-Screen moves with it) and the way I have it adjusted, I can ride at speeds up to 100mph without putting my visor down - unless it is raining. At 125mph, it stayed clamped and only leaned back a bit.
  6. Tails_KTM
    Tails_KTM Adventurer
    Nov 12, 2012
    87
    The Netherlands
    Not sure what the right thread is for this...
    I went to the dealer today to have an error message fixed.
    The mechanic told me that there was a dashboard software update and that he had applied it. He said to ride for 10,1 kilometers before the fuel range indication would be back on.
    What he didn't tell me was that the update disabled my Favorites and also set my LED lights off. This means the low beam headlight was on all the time.
    I reprogrammed the Favorites. In the bike's Settings, you can set DRL back to ON. Exit the menu, turn the ignition off and after that the LEDs under the headlight will be active again.
  7. Tonyvm
    Tonyvm Adventurer
    Dec 25, 2013
    12
    You have to reset both trip counters for the fuel range to work again.
  8. Schussboelie
    Schussboelie Kicking up dirt Supporter
    Jul 22, 2013
    1,070
    Belgium
    No you don't.
  9. Sagirider
    Sagirider n00b
    Mar 6, 2016
    3
    Benton Harbor, MI
    Sir.. Wow. I know that this thread is old, but if you're still around, please tell me how you did your bike like this! I want nothing more than to have my 1190 blacked out, with the sweet decals you've got going on (though mine will be a little different in other regards, not trying to be a total copycat here :p ). Have been searching for a way to do this for a while now, and can't find a thing! :(
