2014+ DL1000 Vstrom
Discussion in 'Japanese polycylindered adventure bikes' started by The Game, Sep 11, 2012.
  1. Maximus Power
    Maximus Power Bubby, you can call me Max
    Jul 3, 2016
    316
    Central Ahia boonies
    That worked. Taking all the wind and bugs, but for local rides this set up will work. Not real sure the washers are really doing anything though.
  2. Randyincolo
    Randyincolo Been here awhile
    Jun 26, 2013
    189
    Cumberland Plateau TN
    Last week mailed off a deposit to Terrys Custom seats. Spent the last 6 months waiting for the stock seat either to like me or me to like it. Failed on both accounts so it is time for a change. He is booked out till April of 2020 but good things are worth waiting for.
  3. jaydee1445
    jaydee1445 Footpeg Crash Tester
    Jul 20, 2006
    4,780
    high sided into the orange grove
    +2 on the fleabay shorties
  4. Jimo368
    Jimo368 Quantum Mechanic
    Feb 23, 2011
    532
    Northwestern Ontario
    Pulled the plugs again at 37k kms (23k miles) and I’m surprised how gummy they were. I’m going ahead and changing them seeing that I have it apart for an air filter and perhaps a valve inspection.
  5. Mr. Goodkat
    Mr. Goodkat The Dude abides......
    Apr 19, 2017
    922
    Escanaba MI
    Can you post pics of your maintenance as you do it? I have about 15k miles on mine and I was going to give the valves the first checkup but now I guess I'll check the plugs too. I think it says to replace them every 7k but that seems kind of crazy and I guess their expensive.
    Any pics or advice would be helpful.
  6. Jimo368
    Feb 23, 2011
    532
    I ordered my plugs here in Canada. You can probably get a better place in the US.
    https://www.clubplug.ca/en/ The plug is LMAR8BI9 I paid $11.75 each.
    There is a good video for removing the tank here.
    Here is where I’m at so far now that I’m waiting for parts.
    Mr. Goodkat and dtysdalx2 like this.
  7. dtysdalx2
    dtysdalx2 Knowledge is horsepower...
    Aug 1, 2004
    23,692
    Moneyapolis, MN
  8. tennyis
    tennyis Been here awhile
    May 10, 2010
    627
    Looks like we will have a new vstrom for 2020~!
      File size:
      29.8 KB
      83
      File size:
      162 KB
      90
      File size:
      178.7 KB
      88
      File size:
      246.7 KB
      86
  9. tennyis
    May 10, 2010
    627
    19" front wheel
      File size:
      541.8 KB
      30
  10. dtysdalx2
    Aug 1, 2004
    23,692
    Moneyapolis, MN
    Sweet! :thumbup
    3 years ago...
  11. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,670
    Wicklow Ireland
    The centre electrode looks clean enough. Looks more like oil on the threads though ? Does the bike use oil ?
    Jimo368 and tennyis like this.
  12. Mr. Goodkat
    Apr 19, 2017
    922
    Escanaba MI
    Thanks. I've never had the tank off my bike yet and the only valves I've adjusted are the typical screw adjuster type. It will make for a good winter project once I work on a few other bikes.
  13. Jimo368
    Feb 23, 2011
    532
    I was surprised at the oil too, looked like a two-stroke. No, it hasn’t used any oil.
  14. TipsyMcStagger
    TipsyMcStagger Long timer
    Oct 28, 2006
    1,631
    NYC & NPR, FL
    Time for a new battery. I've got an EarthX in my KTM 450 and figure I'll get one for the Strom.
    The EarthX site lists both ETX18F and ETZ14C, though the latter seems to be tailored for cold weather ops.
    Anyone running the EarthX ETX18F? Any fitment issues?
  15. mikeysduck
    mikeysduck Slow Ride to Nowhere
    Jan 18, 2008
    839
    Acton Ca.
    Are owners happy with these bikes? Anyone want to warn me off?
    Looking at a very clean 2014 V-1000, with 10k miles, center stand, Fat bars and bar risers.
    After some reading...popular changes are G2 tamer, lower the forks 10mm for quicker turn in.
    I found there were three electrical recalls on the 14's. I don't know if any of these have been addressed.
  16. neilking
    neilking Been here awhile
    Mar 1, 2008
    501
    Austin, TX
  17. V-Tom
    V-Tom Long timer
    Aug 26, 2006
    1,370
    Port Perry, Ontario, Canada
    Don't know what G2 tamer is or why it is needed.
    10mm raise the forks/lower the front of the bike was a very popular mod in first gen Stroms, less so on 2nd Gen DL650's, and I think I have only heard of someone mentioning it (asking about it?) once before on the 2014+ dl1000.
    Doesn't sound like either are "popular" mods on 2014+ DL1000.
    ..Tom
  18. mikeysduck
    Jan 18, 2008
    839
    Acton Ca.
    G2 is a throttle tube, with a different cam profile to slow the roll on throttle. Some report the stock throttle is touchy.
    It appears you are happy with the second generation V-1000.
  19. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,670
    Wicklow Ireland
    Mines a 2016 and I am very happy with 17,000 kms on the odo. Imho there is no need to lower the front end. Back in september mine tracked perfectly around some of the more demanding Alpine passes two up and loaded. The throttle can be a bit sensitive around 2900rpm as it transitions between maps. At worst its a minor irritation in heavy traffic. The shock is adequate for my purposes but I will remove some compression damping from the forks as they can be a bit harsh to react to sharp bumps in the road. Fuel consumption ridden normally is satisfactory for a motor this size. I think I am getting around 50/55 miles per imperial gallon. When ridden more briskly that of course will drop a little. The seat is comfortable for me and also for my Wife when two up. It is a fun bike solo on a twisty back road.
    Overall this is a good solid motorcycle. It is good value for money and is as quick as I will ever need. If ridden well it is well capable of hanging with any of the so called super big traillies on the road regardless of their capacity. They will only out drag it at ridiculous speeds. It is not a dirt bike albeit it will progress well on forest tracks and the like. Mine will be around for some time.
    2thdrinOR and hawkgt like this.
  20. Hanz
    Hanz Been here awhile
    Jun 16, 2015
    582
    Long Island, NY
    How did it change your bike?
    I haven't had it to the dealer for it.
    mikeysduck likes this.
