2014+ DL1000 Vstrom
Discussion in 'Japanese polycylindered adventure bikes' started by The Game, Sep 11, 2012.
  1. Ridin'nFishin
    Ridin'nFishin Been here awhile Supporter
    Apr 18, 2009
    781
    Albuquerque, New Mexico
    I just bought a 2014 Vstrom 1000 and did not get a book with it.
    How much motor oil does it take when changing the oil and filter?
    Thanks,
  2. hawkgt
    hawkgt Where to and when?
    Apr 7, 2011
    365
    Hermantown, MN
    3.5 liters, but I go about 2/3 the way up the sight glass once it's been run and circulated thru the system and then shut off and settled.
    davyjones likes this.
  3. SloRonStinkypants
    SloRonStinkypants Without nipples Tits are pointless.
    Jul 10, 2013
    5,250
    Berlin/OceanCity MD
    Oil???
    You are supposed to change it?
  4. billyal33
    billyal33 Been here awhile
    Feb 16, 2017
    105
    northern ireland
    3.5 litres with the filter, 3 without. I do the filter every other oil change. I've never had to top up yet in 6 years and 33k miles.
  5. Jimo368
    Jimo368 Quantum Mechanic
    Feb 23, 2011
    576
    Northwestern Ontario
    I pour mine from a 5 litre jug and never pay attention how much it took, but it’s is stamped 2.7 litres on the side of the bike. 9CC6676A-13D8-41AA-BCB2-D3761CE67A19.jpeg
  6. Ridin'nFishin
    Apr 18, 2009
    781
    Thanks guys. I need a clymer.
  7. 2thdrinOR
    2thdrinOR Been here awhile
    Apr 22, 2015
    537
    Monmouth, OR
  8. 2thdrinOR
    Apr 22, 2015
    537
    Monmouth, OR
    ROYAL COACHMAN and Hanz like this.
  9. Jimo368
    Feb 23, 2011
    576
    Lettuce know if it makes a difference
  10. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,834
    Wicklow Ireland
    Yes surprisingly good with regard to oil consumption. other vee twins I have owned are not so good. I include KTM 950's and Varadero in that.
  11. billyal33
    Feb 16, 2017
    105
    northern ireland
    I do change the oil every 4k but never top up, it just stays on the full mark, I'm not easy on her but then again its never that hot here. My Triumph tiger 1050 used a litre of oil between every 3k change.
    My old dad always said when its using oil its trade in time!
  12. Griff2
    Griff2 Griff
    Jul 17, 2010
    1,834
    Wicklow Ireland
    Hmmm. If that is the case then I should have traded my KTM's from new :(
    Both my former 950's used oil from new and then as the mileage built up they used less :hmmmmm
  13. 2thdrinOR
    Apr 22, 2015
    537
    Monmouth, OR
    My V-Strom doesn't use oil. It seems the new normal, at least with cars/trucks, is to use lighter weight oils and expect at least one litre/quart of oil consumption per 5k miles.
  14. billyal33
    Feb 16, 2017
    105
    northern ireland
    I ride with 3 mates on Euro bikes, 1260 multi, tiger12 and gs12 and they all use oil, Duc the most. When touring they take oil with them (as its fancy stuff), i might remember to look at the sight glass every few days.
    My wee Suzuki car is ten years old now thou not many miles, 60k and I've never topped it up either.
    davyjones and 996DL like this.
  15. 2thdrinOR
    Apr 22, 2015
    537
    Monmouth, OR
    All done, new Touratech Explore shock installed. It was set up perfectly for my riding weight...51mm rider sag (solo). I haven't played with it yet to see how much adjustable preload is currently used versus what is left for two up riding. Going on a test ride.
    B-Mac likes this.
  16. 2thdrinOR
    Apr 22, 2015
    537
    Monmouth, OR
  17. billyal33
    Feb 16, 2017
    105
    northern ireland
    Very nice bit of kit. I have a Wilbers shock in mine but it was badly set up, I'd to remove 3 full turns on the preload to get 50mm sag. Sounds like yours was right outa the box.
    2thdrinOR likes this.
  18. B-Mac
    B-Mac Aged Beef Supporter
    Apr 18, 2006
    2,283
    Hocking Hills, Ohio
    I went with HyperPro rear shock. Klaus the wilbers man is with EPM.
    Very Happy: https://epmperf.com/ 2014-16 Dl1000 V-Strom Shock 001.JPG
  19. 2thdrinOR
    Apr 22, 2015
    537
    Monmouth, OR
    B-Mac likes this.
  20. NHTOTEROAD
    NHTOTEROAD Long timer
    Apr 1, 2012
    1,093
    Center of the 603
    How do you all support the bike for front wheel removal? I have a 2016 DL 1K A. No center stand. Nothing overhead to support it from above.
    I believe I have read suggestions here. But I couldn't find any old postings. I have a paddock stand for the rear. But, it doesn't fit the front. Thanks
