1. ** Enter to win a $250 gift card! We want to hear from you, please take this survey **
    Take this survey which covers a range of questions about improving the community, the things that interest you and anything else you want to share with us. All responses will remain anonymous.
    Click here to take the survey
    Dismiss Notice
2014 F800GS keeps stalling but fixes (tempoarily) if reset TPS
Discussion in 'Parallel Universe' started by mickyboy1, Feb 25, 2020.
  1. mickyboy1
    mickyboy1 n00b
    Feb 24, 2020
    2
    Aptos, CA
    I just bought an 2014 F800GS and I'm having this weird problem with it. I took it out the other day and did about 100 miles on it them is started to fart like it was running out of gas, then it wouldn't idle at all, and would cut out at low revs. I reset the TPS and all was well. Until the next time and eventually the same thing happened again, reset TPS and all's ok. Any help appreciated.
  2. morfic
    morfic Been here awhile
    Jul 31, 2017
    669
    San Antonio
    If you have a GS-911:
    Make sure engine is cold.
    reset adaptation, which will also reset the idle circuit, following onscreen instructions.
    Start the engine.
    Now let it idle (no blipping of throttle) until the fan turns on.
    Turn it off.
    See if that improves things for you.
    Based on fueling changes pulling in clutch would allow RPM to drop too low and engine shuts off for me in the past,with minor throttle movements triggering drooping below idle and recovering, I did TPS resets until I realized I’ve never allowed bike to relearn to idle.
    That’s not only what the GS-911 says it’s actually in the service manual at a section where the engine was (iirc) “put back in” to some degree.
    Haven’t had idle issues since following the “idle relearn” every time I change fueling.
  3. JRWooden
    JRWooden Homeless motorcycle vagabond ... and ... loving it
    Jul 5, 2008
    6,524
    The great state of confusion
  4. mcbooya
    mcbooya Enginerd
    Apr 16, 2011
    15
    ND
    Not sure if the 2014 has the Fuel Pump Controller on top of the fuel pump unit, but my 09 would act similar when that was acting up. Fix was to replace the small electronic fuel pump controller.
  5. mahony99
    mahony99 Adventurer
    May 19, 2008
    43
    San diego
    Hi Mickey,
    I have had some electrical gremlins on one of my 800s (2014 GSA). Ended up being a bad coil.
    We helped diagnose an issue with a guy in South America. He thought his stalling bike was altitude related but it ended up being crap in the fuel filter.
    Give me a ring or a text on 8582184393. Have few more questions about the issue.
    I just rebuilt a crashed 2017 GSA with the bottom end of a f700gs engine so I have learned a hell of a lot about these bikes.
    I have a spare throttle body which has the TPS on it I think. I could send it to you to see if its that or not.
    These bikes are really reliable due in part to their simplicity I think. Should be an easy fix once all the steps are followed.
    shuswap1 likes this.
  6. bakercdb
    bakercdb Still searching
    Nov 28, 2014
    275
    In flux
    I've had the same thing happen to me a few times when I was riding my 15 F800GSA around the world. It didn't happen frequently enough for me to pinpoint a cause. It did sit at times for a few months, and was shipped around a bit (boat and air). I thought maybe water or gasoline issues or some issue with the ECU needing to recalibrate. (the fuel filter was fresh and battery (lithium) was generally never disconnected.
    It always cleared up after running for a few hours at higher RPM (wouldn't run sub say 2.5-3k). If you think Cairo Egypt traffic is bad, try it on a bike that is always trying to quit on you.
