2014 steering damper retrofit kit
Discussion in 'Hacks' started by windmill, Mar 18, 2014.
  1. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Kent, Washington State
    Ural has released their 2014 style hydraulic steering damper retrofit kit for 2013 and older rigs.
    Installation is easy, takes about 20 minutes
    remove the friction damper
    Punch out the friction disc pin,
    install right mount on front strut,
    install left mount using the friction damper knob, and a bolt through the hole where the pin was with the washer between the triple tree and damper bracket,
    Secure the damper to the brackets with supplied hardware and spacers, center damper on rod making sure it doesn't bottom out at either lock and tighten all hardware.
    The kit retains the friction damper knob, but it could be replaced with a peice of all thread with a nut and washer on top if desired.
    The knob on the end of the rod adjusts the dampening rate, there are 15 steps increasing the rate when turned clockwise.
    On my older rig with the rubber bushings in the swing arms, it makes a significant difference in handling, especially in the corners.
    It reduces the tendency to follow irregularities or the crown in the road, softens and slows yaw under throttle and braking almost to the point it feels like its eliminated, tracks exactly where you point it in the corners even if they are rough, and makes it feel steadier at higher speeds. In short, what you would expect a damper to do.
    For 08 and later rigs with bearings in the swing arms I suspect the difference will be less dramatic, but still worthwhile.
    Bar None likes this.
  2. road_donkey
    road_donkey not really into it..
    Mar 4, 2007
    40
    Calgary,AB
    Thanks for the step by step. Mine is ordered and in the mail! Can't wait to install it and try it out.
  3. Bar None
    Bar None OLD DUDE Supporter
    Mar 2, 2007
    14,320
    SWFL WNC
    windmill,
    Nice install write up with photos. Much clearer for me than the ones on SS. If I end up keeping my 2012 I'll invest in one. Think I would get rid of the knob with the acorn nut on top idea. The 2014 that I rode in the short demo ride at Gene Holopaw's seemed to handle better.
  4. camaroz1985
    camaroz1985 Been here awhile
    Mar 12, 2009
    175
    Carlisle, PA
    How much does that run?
  5. windmill
    windmill Long timer
    Feb 18, 2008
    6,578
    Around $250.
  6. RustySpokes
    RustySpokes Ordinary average guy Supporter
    May 13, 2004
    2,006
    Between here and there.
    I just ordered one from Ural NW for significantly less than that. I hope it shows up soon!
  7. FLYING EYEBALL
    FLYING EYEBALL out of step
    Mar 18, 2008
    12,599
    north of seattle
    I talked to Ben at nw Ural today...he said they had one more in stock and it may be a month or so before they get more.
    Thanks for the write up, Barry :wave
  8. RustySpokes
    May 13, 2004
    2,006
    Got my damper installed, wow, that thing is nice! :clap
    I've only got 1000 kilometers on my Ural, and I've never driven any other sidecar but this is how I expected my Gear Up to handle from the beginning. I've only put 12 miles on the damper but it's a keeper! :thumb
    #8
  9. jphii
    jphii OK, now what?
    Oct 29, 2008
    5,349
    Greenville, NC
    What is significantly less?
    #9
  10. msblu79
    msblu79 Adventurer
    Oct 25, 2010
    96
    Invading NewYorkastan
    Ural NW had them for $180 + $10 shipping. Works great, well worth it. :D
    #10
  11. offroad
    offroad Mogger
    Feb 12, 2005
    203
    Cullowhee NC
    Thanks, Barry.
    Your helpful descriptions and photos always appreciated. After reading your posts and those who have now added the damper I ordered one from Pacific NW Ural. :clap
    Ben had a couple in stock yesterday.
    #11
  12. silverdog
    silverdog Been here awhile
    Nov 20, 2003
    772
    Yep a pretty good improvement, if you don't have one you need one I think.
    #12
  13. RustySpokes
    May 13, 2004
    2,006
    Just rode my rig home in some pretty good wind gusts. Before I changed damper gusts would make the rig dart around and my heart race on occasion. :eek1 With the new damper it's more like a firm but gentle weave, and I can retain my calm, cool composure. :lol3
    #13
  14. Sit
    Sit Thread Killer
    Jun 3, 2007
    638
    Portland
    Thanks for the write up Windmill. Got mine put on with little issue. Now just to try it out!
    Got it out twice this weekend. Once was just a short trip around town with the dog. No issues and it felt goo.
    Next ride was with the wife and we were out and about through the hills and back roads for about 2 hours. Purposely tried to keep the speed up in some less than smooth corners etc to see how the front end would respond. Pleased to say the rough corners etc were very drama free. With the added weight of a person in the car, it still pulls and pushes on acceleration/deceleration, but not as much and once moving, regular throttle adjustments don't upset the bike nearly as much (empty they really don't do anything to the bike). So all in all, I like the improvement and think it was money well spent.
    #14
  15. jegarh
    jegarh Adventurer
    Jul 11, 2011
    44
    Eagle Pass, Tx (the actual edge of the world)
    I ride a rough ranch road for 1 mile to get to the front gate. The damper made a very noticeable difference. I have it cranked fully in and I don't feel like I'm fighting it any more. Very smooth. My ural is a 13 GU. :clap
    #15
  16. Blue Newt
    Blue Newt n00b
    Aug 5, 2009
    2
    15 miles from 64 mile marker on Blue Ridge Pkwy
    I just put the Ural accessory steering damper on my 2009 Patrol. Big difference in handling, especially above 50 MPH. I now feel comfortable above 60 MPH on the machine. After some experimentation, I have the damper at maximum dampening, ie, 15 clicks.
    I very much recommend this improvement to Urals. Well worth the money.
    #16
  17. monkeydad
    monkeydad Long timer
    Jan 15, 2012
    4,238
    Earth
    +1
    I've ridden the '12 and bought a '14 due to the several improvements.
    Mainly, fuel injection, the hydraulic steering damper, and the new brakes.
    The '14 rig is massively better than the '12 I rode, and the new steering damper was a big part of that.
    #17
  18. UralNorm
    UralNorm Adventurer
    Jul 14, 2010
    48
    Adelaide
    I ride my '09 & '10 Urals with the friction damper very loose. I don't consider a damper of any type is necessary if the head stem bearings are properly adjusted. I have ridden a 2014 outfit and found the hydraulic damper OK when on the minimum setting.
    EFI and disk brakes may be reasons to buy a 2014 model, but I fail to see the benefits of the new steering damper.
    #18
  19. Flying GS
    Flying GS Adventurer
    Sep 3, 2005
    28
    Great write up. The friction disc pin was tough to punch out but eventually relented. The kit didn't come with a guide so thank you @windmill! I find that I have to keep it at 12-13 (out of 15) to limit low speed wobble on rough surface, would not have issues at speed with a slightly lower setting.
    #19
