For sale 2015 Ram 5500 Laramie Toy Hauler / RV Camper
Discussion in 'Other' started by coryh, Oct 13, 2020.
Thread Status:
Not open for further replies.
  1. coryh
    coryh n00b
    Aug 19, 2017
    1
    Thought some fellow riders might be interested, looking to sell my rig. Built to be a mobile garage and camper (with function first) that could carry all the gear (securely inside) and allow space for sleeping also.
    4x4, proper ground clearance, heated seats. Easily room for 2 dirt bikes, 3 mountain bikes, 4 pairs of skis, all the related gear all inside, and can still sleep in the bunk and cook. Super easy to load unload. Looks "commercial" and blends in well.
    All aluminum box build, professionally done, painted to match the truck. I personally did all the interior, it's no 5 star hotel, function first. Few items of finish inside that could be completed or improved (ex the back wall TuckTape), but again, its function over fashion inside.
    Twin size bunk, fridge (12v), microwave, small sink all inside also. Insulated, with diesel heat.
    All the extras in the photos (chairs, bedding, water jugs, kitchen items, etc) are negotiable.
    Chassis and box both in great shape, no real issues to report beyond the expected odd stone chip and some tree branch marks. Some small paint blisters around rear door hinges. Minimal rust on chassis, been diligent with touching up rust proofing. The solar panels are working, but have discolored some and the plastic covering is faded.
    Truck is registered in Alberta (Canada) as an RV. Typically located in the Kootenays in BC (Canada). If you are located in the US and interested, likely could arrange shipping/transport if required.
    Priceā€¦.lets chat, but because even one needs to know:
    update --> $110,000 CAD
    cory DOT m DOT hancock AT gmail DOT com
    Some photos at end, and more can be provided
    Truck Chassis
    • 2015 Ram 5500 Laramie Crew Cab Chassis Cab, 197" wb
    • Purchased new in 2017
    • Currently 71,000km
    • Cummins Diesel, stock
    • Millage 19 to 23 L/100Km
    • 4x4, 4.44 axel
    • Sailun s740 tires (M&S and winter snowflake rated), approx. 10,000km on them
    • 2 new truck batteries (March 2020)
    • Full size spare
    • Granite crystal metallic paint (box painted to match)
    • Heated (front and rear), cooled (front), leather seats, heated steering wheel
    • 8.4" Uconnect system with premium audio and nav
    • Remote start
    • Ambulance prep group
    • Rubber flooring (carpet delete)
    • Dual fuel tanks (196 and 83L)
    • Rear view camera
    • Typical weight, empty 12,600lbs
    • Regular oil changes, no mechanical issues to report
    Truck Other
    • Fab Fours Black Steel Elite Bumper, winch capable (bumper is VERY solid)
    • LED bar on bumper, switched to aux and high beam switches
    • LED reverse lights installed on fender flairs, switched to aux
    • Tubular steel side steps
    • Front mud flaps
    • Rhino Rack Heavy Duty roof rack with aluminum basket (holds spare tire)
    • Over all approx. 25' long tip to tail, just sub 12' high
    Body
    • 12' long, 8' wide, ~6.5' high (inside)
    • All aluminum constriction
    • Buyers poly storage box on both driver and passenger sides, 120v and 12v power in passenger side box
    • 75L external water tank w. drain spout
    • 12v washdown pump and hose, fed from water tank
    • Basecamp propane shower unit (typically stored in passenger side box), runs off a water jug
    • Side and rear LED lights
    • Side door, freezer style latch with keyed dead bolt
    • Rear barn doors w. cam lock closure
    • 2.5" 10,000lb hitch with 2" reducer
    Interior
    • Rubber floor
    • All walls foam insulated, covered by plywood then industrial vinyl back carpet
    • Celling insulated, covered with fiber board
    • Roof vent, w. exhaust fan (new vent lid also to be provided)
    • Interior fan w. usb port above bunk
    • Window in door, opening w. small intake fan
    • Window back driver side, emergency opening
    • Twin size bunk with 6" foam mattress hung from celling (max capacity ~200lbs)
    • E-track and hooks everywhere
    • Metal 6' tall storage cabinet with Rubbermaid bins
    • Metal celling storage cabinets
    • Husky tool chest/box (easily removable if desired)
    Amenities
    • Goal Zero Yeti 1250 power pack chained to 2nd 100Ah battery, provides power to living area
    • Charged by truck, with low voltage disconnect
    • Charged by 120v shore connection
    • 200w solar on roof
    • Cell phone booster, external antenna and internal amp
    • All LED lights inside
    • Microwave, runs off (3-4min max) Goal Zero
    • Eberspaecher (Espar) AirTronic D2 diesel heater, fed from truck tank, altitude compensation module and digital thermostat (will keep unit at 20c even at -15c outside)
    • Sink mounted in counter, fed from fresh water jug, drains to gray water jug
    • Whynter FM-45G 45-Quart Fridge,12v or 120v powered, digital control
    IMG_20191113_140323472_HDR.jpg IMG_20191113_140205764_HDR.jpg IMG_20190809_195302540.jpg IMG_20191113_135403794.jpg IMG_20191113_135820984.jpg IMG_20191113_135508018.jpg IMG_20191113_140704678_BURST000_COVER_TOP.jpg
    DakarNick, Eagletalon, slime and 10 others like this.
Thread Status:
