2017 500 EXC-F and 350 EXC-F
Discussion in 'Thumpers' started by noahr, May 17, 2016.
  1. DockingPilot
    DockingPilot Hooked Up and Hard Over
    Mar 24, 2004
    11,462
    Andover, N.J.
    Consider the original TAT, Lakeview-Fort Bidwell-Denio-Fort Mcdermit-Battle Mountain-Eureka-Baker then continue.
    Keeps you more south
    Either way, have great, safe ride.
    Fat Chance and tundradirtbiker like this.
  2. WIsixfitty
    WIsixfitty rock and roll the bones
    Aug 7, 2006
    4,568
    west of road america
    Just an update on the shock knuckle issue.
    Just after the JBweld cured I was cleaning it up with a dyna-file/used scotchbrite belt, it went away pretty easily. Which told me this may not be the best solution.
    350 miles of wet sand and it's gone. It's hard to see but that's bare alunymoon.
    Before
    After
    Here's my next test. I wanted something thin and relatively tough. I found a small sheet of 0.020" titanium that will be glued to the troubled area. I cut it to match my wear pattern with some surface above and below for gluing area.
    Here it is just hanging in place.
    Epoxy or JBweld? I suppose both will work just fine.
    Some of the things I've noticed that affect the wear.
    1. Wet riding. Hitting puddles or water repeatedly keeps loading the area with abrasives. If it's dry, just the opposite. This seems to be the biggy.
    2. Ride height. If you run more sag or heavy loads the inner fender does not contact the knuckle as much. Less sag, higher ride heights equals more wear.
    3. Shorter wheelbase/chain may cause the tire to rub a bit more in that area.
    I will also take a heat gun to the flap to tweak like was suggested earlier by ?
    I've got one more ride/test in a few weeks. After that my season is pretty much done except for the ice.
    BT4Stroke, Harder1, mokhtario and 2 others like this.
  3. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,407
    Globe ''D'' Earth
    Thanks for the update:
    '' 2. Ride height. If you run more sag or heavy loads the inner fender does not contact the knuckle as much. Less sag, higher ride heights equals more wear.''
    My 2018 450 Six Days was lowered 1.96'' front and rear and I have not seen any wear yet, plus no muddy sand stuff.
    Oldebonz, mokhtario and WIsixfitty like this.
  4. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    3,950
    Bridge over Troubled Water
    Would an aftermarket mud flap made out of different material/compound reduce the abrasion on that point?
  5. WIsixfitty
    Aug 7, 2006
    4,568
    I don't think so. As long as water carries the abrasives to that area it's gonna happen.
    edit: I need to proof read my brain ramblings before I hit send.:nod
  6. keepshoveling
    keepshoveling DNF
    Oct 9, 2014
    4,798
    NYC
    If there isn't, why are you even riding? :pope
  7. WIsixfitty
    Aug 7, 2006
    4,568
    I don't know. But I'm even more confused now. :brow
    keepshoveling likes this.
  8. Fast1
    Aug 18, 2007
    3,950
    so if you don't ride the sand, mud and swamps of WI, MN and MI .. you won't have a problem:lol3
    keepshoveling and mokhtario like this.
  9. WIsixfitty
    Aug 7, 2006
    4,568
    ummmm? I'm not sure I like where this is going.
    For the record I hate water and mud. It's so dirty. You should see me avoiding puddles and such.:rofl
  10. Fast1
    Aug 18, 2007
    3,950
    yah.. you never know what is lerking in that muddy water or how deep it is in the upper mid-west... Those streams I just did in CO and WY were so nice and clear you could see exactly what was in the water and the depth.
    stark difference
    This
    or this?
  11. Gryphus1
    Gryphus1 I'd rather be riding
    Mar 3, 2015
    1,045
    Dirty Old Van Down By the River
    I've searched around for some used OEM Take Off's, for foot pegs. To clarify it's for an 18' 500 EXC-F, does anyone have any pegs for sale?
  12. satchmo3
    satchmo3 Been here awhile
    May 20, 2008
    194
    Portland, Oregon
    Another rear shock/swing arm/mudflap update... after about 10 hrs of single track and 15 hrs loaded with camping gear ( and several power washings) the self adhesive 3M duolock seems to be doing the job.
  13. WIsixfitty
    Aug 7, 2006
    4,568
    That might the easiest fix yet.
    mokhtario and mo_rider like this.
  14. MAXVERT
    MAXVERT O.G. on da O.C.
    Jan 19, 2004
    2,586
    Baja Arizona
    I've got 3 or four sets laying around ! PM me I'll get you a set cheap .
    Max
    mokhtario likes this.
  15. thejrod
    thejrod Been here awhile
    Nov 2, 2010
    729
    Arlington, WA
    Did a video review of both the Cyclops LED as well as the Motominded Ultimate Pro on my 350EXC.
  16. Big Tall Bastard
    Big Tall Bastard Voice of Reason
    Jun 11, 2008
    1,199
    Bend, OR
    Any chance you would PM me and tell me where that is? Awesome looking trail
  17. Big Tall Bastard
    Jun 11, 2008
    1,199
    Bend, OR
    God she is still smokin hot!
  18. tokyoDirk
    tokyoDirk n00b
    Jul 29, 2011
    2
    TAT update. Yep - it's cold! Worse in a few days just in time for Colorado :(
    I really wanted to do agate Creek but fear it might be snowed in Thursday. Any locals have any thoughts?
    Bike is doing great. Had one issue where the rebound side fork just came apart inside after anda few days and caused a major thunk on rebound for big hits. I think the shop that I had change the springs didn't torque it back. When we took the the fork cover off the cartridge lifted right out with the spring, not even attached to the bottom. Yikes.
    I made my own route from Tahoe to eureka NV. Turns out satellite photos aren't good indicators that a road still exists or is passable. Who knew? From there follow the old TAT tracks that go through NV.
    Favorite riding so far was devil's racetrack or the narrow canyons outside Moab. Some sketch parts being solo though.
    Bike just blows me away. It does it all.
    andybj, Harder1, mokhtario and 5 others like this.
  19. BigWally
    BigWally Been here awhile
    Dec 7, 2014
    518
    Iowa
    Thanks for the tip. Quick trip to Walmart and I've got a Duo Lock patch in place and enough left over for my $2.98 investment to repeat the process 7 more times. Will be riding the Parashant & Gold Butte areas of SE NV/NW AZ later this Fall and will report back on patch wear.
  20. BigWally
    Dec 7, 2014
    518
    Iowa
    Saw an inmates comment a few pages back regarding his 500 wearing thru chain guides relatively quickly. Checked mine and was surprised to see its quite worn, ready for replacement at ~100 hrs (2800 miles).
    Kinda apples & oranges but my 690 with 12k miles shows little chain guide wear.
    Why the large apparent difference? I think the 500's chain sag is greater than the 690's and wonder if that's the explanation or if their OEM chain guides are that different in durability (they are different part#s). Or some other factor(s)...
