2017 500 EXC-F and 350 EXC-F
Discussion in 'Thumpers' started by noahr, May 17, 2016.
  1. brianpc
    brianpc Long timer Supporter
    Feb 20, 2013
    1,548
    CA
    Dumb question - does anybody have the full parts list for the in-tank fuel pump / filter, and the associated external fuel disconnect piece? I just got an Acerbis large tank for my '17 500 and I was considering fitting it with the fuel pump & disconnect so I have a 2nd separate tank ready to go for DS / SuMo / long distance rides, and keep my stocker for tooling around the dirt bike park. I already swap the Renazco seat in and out for dirt bike park rides and was thinking of doing the same w/ the large vs. small fuel tanks. Anybody else doing this kind of thing?
  2. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,404
    Globe ''D'' Earth
    78107088300
    (replaces part #
    78107088100)
    Fuel pump
    https://www.rockymountainatvmc.com/oem-schematic/4
    https://www.ktm-parts.com/OEMFINDER...628112ecd2/500_EXC-F_CHASSIS_-_2017_Fuel_Pump
    mokhtario and brianpc like this.
  3. brianpc
    Feb 20, 2013
    1,548
    CA
  4. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,404
    Globe ''D'' Earth
    No, this is for the entire fuel pump assembly. Just the fuel pump itself alone is over $100.00. You can shop around for the fuel pump and filters by themselves but not the entire unit. It would be nice though to have an extra tank with fuel pump ready to go. Here are 2 videos to help you decide and get started, different model bike but same procedure.
    mokhtario, Fast1 and brianpc like this.
  5. Zuber
    Zuber Zoob Supporter
    Sep 28, 2004
    6,505
    West of the West, Oregon
    I had two complete fuel tank assemblies on my 2012 500exc. It was very expensive for the pump assembly, like $175 or so. No other source for it.
    It never really paid off. I rarely swapped out the tank. Large chance of ruining the pump while it's sitting around with no fuel covering the pump.
    Now for my 350exc, I just got the 3 gallon tank that is not noticeable over the stock 2.2.
    You don't need to buy new parts for the banjo bolt/fuel pump mount, if you have access to a lathe. Only need to shorten the bolt's length a little and chamfer the end for the o-ring. Then you can run the stock right angle tap.
  6. brianpc
    Feb 20, 2013
    1,548
    CA
    Thanks for this. Maybe better to just run the big tank and not fill it completely on short/local OHV park rides.
  7. BigWally
    BigWally Been here awhile
    Dec 7, 2014
    518
    Iowa
    Posted query Thread in Garage forum and quickly got logical explanation. I had installed larger rear sprocket on my 500 (48T vs OEM 45) which lowers chain path leading to more rubbing/wear until new chain path is worn in. (690 had OEM rear sprocket so not similarly affected).
    My Acerbis replacement guide has 2 rear mounting holes to accommodate differences in rear sprocket size.
  8. BT4Stroke
    BT4Stroke Been here awhile
    Nov 26, 2006
    204
    Motominded XL80 Kit works great I have installed it on my 18 500 and on 2 19 500’s everyone seems to like it’s output a lot, I’ve tested it in Baja great light output, good for 80mph. And if you want to add the KTM 690 enduro windscreen it works well too!
    Bdballestero and dino702 like this.
  9. DIRTLER
    DIRTLER Long timer
    Sep 5, 2015
    1,404
    Globe ''D'' Earth
    When you get the new tank if it is an ACERBIS it will come with what looks like sheet metal screws to attach the back of the fuel pump. Be very careful to NOT apply TOO MUCH FORCE on these 4 screws as they can strip the plastic fuel tank. This video shows you how.
  10. SoilSampleDave
    SoilSampleDave Dr. Zaius was right!
    Jan 21, 2005
    10,033
    The Delta Ghetto, GA (aka PTC)
    I can also tell you that if one of those holes is stripped out (as it was with a used tank I purchased) a short lag bolt from the hardware store will work perfectly in the stripped out hole. I can’t remember off the top of my head if it was 1/4” or 3/16” diameter, but it will be completely obvious when you look at it which one is correct. The sizing is PERFECT.
    Edit: I wish there was an equivalent fix for the shroud screws on the Husky tanks. No more Acerbis for me.
    DIRTLER likes this.
  11. Hertz13
    Hertz13 Been here awhile
    Aug 19, 2018
    226
    Central PA
    So this came today, going to give it a shot, it will be my first time ever even trying an auto clutch.
    Do I actually need the special tool to hold the clutch basket while torquing the big center nut? Or can I put the bike in gear and hold the back tire or keep the clutch from spinning some other way?
  12. dino702
    dino702 OFF2BFE
    Jun 14, 2014
    827
    Las Vegas, NV
    I have the same one sitting on the shelf came with the bike I bought but haven’t done the install yet. Let us know how it goes.
    yes you can install without the special tool.
  13. SoilSampleDave
    Jan 21, 2005
    10,033
    Some lazy people like me just give the center nut a quick tap or two with the impact wrench and call it a day. The bent washer will keep it from loosening.
    little squirt likes this.
  14. Zuber
    Sep 28, 2004
    6,505
    Yup, and a little blue loctite doesn't hurt.
    little squirt and SoilSampleDave like this.
  15. AdvMoto18
    AdvMoto18 NORDO Supporter
    Jun 17, 2013
    2,387
    Coastal SC Low Country / Land of Shrimp & Grits
    And wash/rinse out the Acerbis tank numerous times to remove plastic dust, shavings and residue. Failing to do so will allow plastic dust to pass through the fuel filter and clog your fuel injector in very short order.
    Fast1 likes this.
  16. bkoz
    bkoz Been here awhile
    Dec 6, 2008
    816
    Kamloops, BC
    Your fuel filter is a finer micron rating than the injector nozzle. The worst thing that will happen is you will clog your filter.
    Oldebonz likes this.
  17. Zuber
    Sep 28, 2004
    6,505
    I like the IMS tank's better. Brass inserts for all the bolt, no wood screws and often fits better. But, about $100 more.
  18. AdvMoto18
    Jun 17, 2013
    2,387
    I don't think so when it comes to the fine dust inside a new Acerbis tank. I learned the hard way. I failed to wash and rinse the tank when new prior to installing.
    The bike ran great for 2 years with the factory tank. Within 3 days of installing the Acerbis tank, the injector was clogged. Back flushing the injector with the fuel pump wouldn't clear the mess. Sent the injector to a shop for cleaning, they got the white powdery mess out of the injector.
  19. WIsixfitty
    WIsixfitty rock and roll the bones
    Aug 7, 2006
    4,567
    west of road america
    IMO The only thing the IMS has over the Acerbis is the threaded inserts.
    The fit and finish are nicer on the Acerbis. The exterior of the tank finish/tooling mold finish is smoother which makes getting it clean much easier. The dirt sticks to the rough surface of the IMS. Neither tank fits the plastic that well.
    Even after the dealer stripped one of the fuel pump mount holes in the Acerbis, I've never had any leaking or problems. I only run my IMS 4.0 in the fall. The rest of the season is with the smaller Acerbis 3.0.
    I guess I got lucky as I did not flush either tank before the first use. I do change my inline OEM fuel filter every 2nd or 3rd oil flush.
    Hertz13, empedrado and keepshoveling like this.
  20. Hodakaguy
    Hodakaguy NorthWest Adventure Rider Supporter
    Jul 30, 2007
    2,960
    Eastern WA State
    Had a great local ride on the 500...spark arrestor required :-). Love this bike!
    Hodakaguy
