2017 BMW Radiator Guards on a 2015 GS (pictorial)
Discussion in 'GS Boxers' started by JimVonBaden, Dec 15, 2017.
  1. RotesHengst
    RotesHengst Adventurer
    Feb 10, 2018
    57
    Chesapeake, VA
    Thanks for the idea Mr. VonBaden! Just mounted mine . . . nocked the dust from my Dremel.
    2016 GSA
    I don't think a photo is necessary, looks pretty much a carbon copy of your post.
    2018-07-06 Update:
    Now that the blistering weather is here, I have noticed the dash is indicating the coolant temperature to be steady at 201℉, normal indication is 199℉. This is at road speeds 45 MPH +.
    #21
    JimVonBaden likes this.
  2. Plawa
    Plawa ¿ʞO ǝʞᴉq ʎɯ sI
    Jan 22, 2014
    3,018
    Prague, CZ
    Am I the only one who installed the left SKU on the right (throttle) side of the bike? I ended up with something that looks identical to Jim's post, just haven't seen that mentioned anywhere..
    #22
  3. GrumpyOne
    GrumpyOne Been here awhile Supporter
    Jan 10, 2008
    463
    No.VI, MI
    Yeah, I didn’t see it mentioned either. Mine wound up swapped right for left and upside down to the part fiche drawings I found. Spent a long time looking at JVB’s photos and test fitting to figure it out.
    -jw
    #23
  4. JimVonBaden
    Feb 11, 2005
    91,268
    Alexandria, VA
    I am fairly sure, but not certain, that I put them on the correct sides. :dunno
    #24
  5. GrumpyOne
    Jan 10, 2008
    463
    No.VI, MI
    There is a “R” and “L” molded in to the bottom radiator side of each. Based on your photos and trial and error, they fit upside down and swapped sides. (To match your photos.)
    -jw
    #25
  6. TBickell
    TBickell And away we GO !!
    Nov 14, 2010
    795
    Somers,MT......Anthem, AZ
    I ended up with the SW Motech version. Ordered from Revzilla. A bit complicated to fit on my 2016.5 GSW as the part was really for a 2017.5. (The confusion there continues). I had to forgo connecting the top of the shroud as there was no hole there on my bike. The other connection points look to be secure enough to hold it in place. Looks good but I like the OEM rallye version better.. should be good protection though.
    #26
  7. sranderle
    sranderle Adventurer
    Feb 22, 2014
    27
    Maybe that's why my attempt at mounting the right side with the 'R' part isn't going so well on my 2016 GSA. As is, I would need to trim the entire side of the shroud.
    #27
  8. GrumpyOne
    Jan 10, 2008
    463
    No.VI, MI
    Yep, only took 30 min of walking to the bike and walking back to the computer to check JVB’s photos to figure it out. ;-)
    -jw
    #28
  9. RichK
    RichK Long timer
    Jun 26, 2008
    8,931
    Stole JVB's idea here. (Thank you!) Did not need to trim the shrouds....
    #29
  10. WADE-O
    WADE-O Been here awhile
    Jun 18, 2011
    722
    SAN DIEGO, CA
    Now I'm confused do we need to trim the guards or not for a 2017 GSA?
    #30
  11. GrumpyOne
    Jan 10, 2008
    463
    No.VI, MI
    Trimming the shrouds is optional, trimming the guards is required (tabs etc. as JVB shows).
    -jw
    #31
    RotesHengst, RichK and JimVonBaden like this.
  12. F16Viper68
    F16Viper68 Trapped in the Sandbox! Supporter
    Oct 14, 2007
    1,036
    Crawfordville, FL
    This has to be one of the only times I've saved money going OEM. :)
    #32
  13. aceranic
    aceranic Been here awhile
    May 16, 2008
    152
    Stobrec, Croatia
    How would they fit 2018gsa. Same JVB's procedure?
    #33
  14. Navy Chief
    Navy Chief Long timer Supporter
    Oct 24, 2009
    2,087
    Waynesboro, PA
    Thanks for sharing this, have a set on order now!
    #34
  15. JimVonBaden
    Feb 11, 2005
    91,268
    Alexandria, VA
    Yes, very similar.
    #35
  16. aceranic
    May 16, 2008
    152
    Stobrec, Croatia
    Cool, thx.
    #36
  17. Myll
    Myll Been here awhile
    Jan 22, 2018
    208
    Illinois
    Just put them on a 2016 gsa. I was skeptical about plastic. The way the honeycomb is laid out and the grade of plastic seems solid.
    Easy fit and finish install. Used a razor blade to score and snap the useless tabs and trim the oem shroud. Notches were done with a fine tooth hacksaw blade.
    #37
  18. Myll
    Jan 22, 2018
    208
    Illinois
    Almost forgot. Thanks for the info on these 2017 rallye guards being an option JVB. had to redirect my local shop about this
    #38
  19. Millsaps2
    Millsaps2 Adventurer
    Mar 30, 2008
    39
    Anderson, SC
    Vendor used for this price?
    #39
  20. Boxerbreath
    Boxerbreath 2017.5 GS Black Storm
    Feb 7, 2018
    3,875
    Lost Angels County
    Yep, the BMW guards are the cheapest OEM insurance you can buy.
    Ya now, all the fab'd guards out there look really cool, but the thing to consider is do they flow enough air?
    They're overkill like most aftermarket stuff unless you're going hardcore offroading. Heavy duty ones will do the job if the guy in front of you is roosting rocks at you.
    Little other benefit IMO...
    #40
