2017 DR650 Rear Damper Warranty Issues...
Discussion in 'Thumpers' started by Wildbillsgarage, Aug 1, 2018.
  1. Wildbillsgarage
    Wildbillsgarage Adventurer
    Mar 23, 2013
    27
    Whitehorse, Yukon Territory
    I don't think I'm the only one with this problem!
    smilin jack likes this.
  2. trailrider383
    trailrider383 867-5309
    Jan 12, 2008
    5,016
    Idaho Is Full! Don't Move Here!!!
    I guess you must be...
  3. Ohio_Danimal
    Ohio_Danimal If I die trying, at least I tried Supporter
    Dec 20, 2009
    5,768
    Cuyahoga Falls, Ohio (The Crooked River)
    The problem isn’t with the Cush rubbers
    The problem seems to be a poor design that misaligned where the bearing on the sprocket carrier is located. This causes the rocking that compresses cush rubbers quickly.
    Mines a 2011 same issue
    There are folks that will remachine the carrier to allow it to hold two bearing side by side, eliminating the rocking effect
    Check out @motolab he’ll fix you up.
    It’s been a known DR issue for quite some time
    Bultaco206 and smilin jack like this.
  4. TUCKERS
    TUCKERS the famous james
    Dec 23, 2005
    20,974
    Villa Maria Sanitarium, Claremont, CA. USA
    I’m glad I didn’t know about this when we rode two bikes 14,000 miles in one continued trip. They may have failed!
