Sold 2017 KTM 1090 Adventure R - $10,450 OBO
Discussion in 'Bikes' started by IronMonkey, Mar 9, 2020.
Tags:
Thread Status:
Not open for further replies.
  1. IronMonkey
    IronMonkey Adventurer
    Mar 12, 2015
    18
    Tyler, Texas, USA
    Asking $10,450 OBO.
    Selling my 2017 KTM 1090 Adventure R with $2000 worth of accessories. This bike is set up for a 6'4" rider to be able to stand comfortably. The foot pegs have been lowered and the handlebars have been raised by a total of 3 inches.
    Below is a list of all modifications. All original parts will be included with sale. I am happy to answer any questions you have and I can take pictures if you want to see something specific. New saddlebags available depending on price.
    - DualControl Brake System Black - $91 - Enlarges the brake pedal and makes it easier to control the brake while standing
    - BlackDog Cycle Works Platform Footpegs - $219 - Enlarges the footpegs for better traction, lowers them by 1/2" for comfort
    - BlueSea Systems 12/24V Dual USB 4.8A Chargers - $48 - Waterproof 4.8 amp USB outlets with 1 mA parasitic current draw, so it won't drain the battery
    - Cyclops Adventure Sports LED Upgrade Replacement Headlight Bulb - $144 - 9600 Lumen LED for better visibility when riding at night
    - HighwayDirtBikes Ultimate Handguards 180KTM Center Stand - $240
    - KTM Powerparts Skid Plate - $300
    - KTM Heated Grip Kit - $141
    - KTM Offroad Dongle - $115 - Enables Offroad Mode
    - KTM Rear Carrier Plate - Provided mounting points for a tailbag
    - Heizkorper KTM1XX0 ADV footpeg lowering brackets - $60 - Moves footpegs 15mm down and 15mm forward
    - Powercell Performance Fuel Pump Easy Connect Kit - $60 - Replaces the stock fuel pump connector with a much more durable connector. The stock connector is easily damaged during servicing and tends to fill with dirt
    - Rocky Creek Designs MotoPlug Powered Phone Holder - $35 - Mounts phone securely enough for off-road riding while providing a 2.4 amp USB outlet
    - Rottweiler Performance Canister Valve Removal Kit - $23 - Frees up enough room to store a toolkit or tire pump under the seat
    - Rottweiler Performance Fueling Dongles - $50 - The stock ECU is set very lean under 5500 RPM and 20% throttle. This causes heat issues from extremely hot header pipes, makes the motorcycle jerky at low RPMs and reduces power. The Rottweiler Fueling Dongles send a return signal to the stock ECU that richens the mixture and translates into an overall better running motorcycle.
    - Rox 1" Lock Spacer - $20
    - Rox 2" Pivoting Bar Risers - $65
    - Seat Concepts Tall Comfort Seat - $210 - For increased comfort on long rides. Also raises the seat height 2".
    Total - $1,986
    Junya likes this.
Thread Status:
