2017 TAT, Ocean to Ocean in 12 days, Planning
Discussion in 'Americas' started by KenCM, Jun 28, 2017.
  1. KenCM
    KenCM Been here awhile
    Jun 9, 2014
    711
    Central FL or East TN
    Started leaving on our dry run at 1:30 today. Actually left at 4:30 PM.
    My bike wouldn't start. Bad cell in battery. Local Honda dealer covered under warranty. Started to leave second time and discovered GPS not powered. Turns out there is some electronic gizmo in line with connector that is preventing the powering of external devices. Attached second battery tender and finally took off.
    Camping in Citrus tract of Withlacoochee forest.
    [​IMG][​IMG]
  2. KenCM
    Jun 9, 2014
    711
    Had to add second battery tender.
    Electronic gizmo on heavy one is preventing powering devices like GPS and air pump.
    Anyone know what this electronic gizmo inline is for?
    Sent from my SAMSUNG-SM-G891A using Tapatalk
  3. Drumbrakes
    Drumbrakes Been here awhile Supporter
    Jun 13, 2015
    800
    Edinburgh
    That is a Schottky Diode, or perhaps a few of them.
    Its job is to protect your battery and the booster pack from accidentally getting connected the wrong way round, or both leads together, that kind of thing. Basically it stops current going along the booster pack cable in the "wrong" direction.
    That means you can only use it to feed power into the bike battery, not to draw power out from it, such as powering a GPS, compressor etc.
    https://en.m.wikipedia.org/wiki/Schottky_diode
    kvango likes this.
  4. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    31,014
    Über Alles,California
    Whatever.
    I was either going to coast to coast to coast alone or a bunch of BDR's with a couple buddies...went with a more fun shared trip this year. Probably do the coast to coast to coast next year. Hard to do everything I'd like to.
    :ricky Go Ken and Garrett!!
    RG1984 likes this.
  5. phreakingeek
    phreakingeek Big Ear Inc - Virginia Provider Super Supporter
    Sep 17, 2010
    2,450
    VA
    Since I'm on the TAT at the moment and it's taken me 2 weeks to get to La Veta CO. I'm not sure how you will be able to do this ride in 12 days.
    Not that the pace isn't doable by some, but the weather has stopped me on 6 occasions. I don't mind getting wet, but when it's lightning hitting and thunder crashing at the same time all around you, it's not real prudent to keep going.
    Plus, this route goes by a lot of people's homes...many with young kids' toys all over. I think it is doing our riding community a disservice to go blasting by the "Children Playing" signs at 50mph just to set a record finish. Seems like there a lot of other places to do a fast pace blitz that wouldnt be dangerous and offensive to local residents.
  6. garrett3
    garrett3 Adventurer
    Jul 21, 2016
    21
    I'm willing to take the risk. I don't have rear blinkers either
  7. garrett3
    garrett3 Adventurer
    Jul 21, 2016
    21
    Remember, it's long days not fast speeds
  8. KenCM
    Jun 9, 2014
    711
    First, good job on hanging in there given the inclement weather.
    I hope you have better weather the rest of the trip.
    I want to reiterate that we intend to make distance by riding long days, not high speed.
    We will largely be complying with speed limits and never riding at unsafe speeds for the conditions.
    With respect to weather - that is my primary concern. Secondary concern is mechanical issues.
    If we get bad weather, it will slow us down.
    FWIW, I did this route solo last year in 20 riding days on a substantially less capable setup.
    It'll take what it takes. Our target is 12 days.
    Aces 6 and phreakingeek like this.
  9. KenCM
    Jun 9, 2014
    711
    We're back home from the test run, so I have a real keyboard and that means more words easier.
    When we discovered the issue, my first thought was that they had used a diode to prevent drawing current from the battery on the bike, but the voltage on the connector side was on the order of 9V and that was a bit of a mystery.
    If I have time, I'll cut that shrink wrap off of there and see if I can make sense of what they did.
    I presume they've done that specifically to preclude exactly what we wanted to do.
    I'm guessing the thought process went something like this:
    "Our" battery cannot sustain the fusing current of this wire long enough to present a serious risk.
    But "We" don't know what else they might try to plug in that could draw the fusing current from the bike battery.
    We can't simply fuse the wire with a reasonable size fuse - what to do?
    "I" know... we'll put a diode in line.
    If I can procure a couple of those connectors promptly, I'll make a jumper without the electronics.
    Otherwise, we'll rely primarily on the Antigravity battery for a jump and if that doesn't work, we'll try the smaller gauge battery tenders.
  10. Drumbrakes
    Jun 13, 2015
    800
    Edinburgh
    You could wire a 15 to 30 amp fuse across the diodes. That would let you power things from it. Remove the fuse before you use the booster pack or it will blow, as there's a slight voltage drop on the diodes and all the starting current will go through the fuse in preference to the diodes.
  11. KenCM
    Jun 9, 2014
    711
    Thanks for the suggestion.
    We already put a separate fused battery tender on each bike so we have that covered.
    The only remaining thing I'd like to do if we have time is make new larger gauge battery tenders without the electronics so we can jump one bike from the other.
    Someone indicated that connector is commonly used on R/C toys - need to ask Garrett if there are any R/C shops around here.
    EDIT: Yep! It's an EC5 connector and available at a nearby Hobby Town.
  12. phreakingeek
    Sep 17, 2010
    2,450
    VA
    Thanks for setting me straight. Hope you guys get some good weather and have an awesome trip.
  13. KenCM
    Jun 9, 2014
    711
    WEIGHT AND BALANCE
    Before leaving for the trial run yesterday, I realized I had optimized for the wrong thing.
    I'd put stuff I wouldn't need for a while in the bottom of the bags - that was mostly clothing, the lightest stuff.
    So I re-packed.
    Got rid of the green Sea-To-Summit bag altogether.
    Put the heavy stuff in the bottom of the pods and the clothes in the pod under the beaver-tail.
    That noticeably reduced the center of gravity.
    And, I weighed everything...
    Left pod: 12 lbs.
    Right pod: 11 lbs.
    Top pod: 9 lbs.
    Tank bag: 8 lbs.
    Backpack: 15 lbs.
    55 lbs. total luggage with 47 lbs. of that on the rear and 8 lbs. on the tank.
    Pondering further changes...
    Aces 6 likes this.
  14. larryboy
    Jan 9, 2005
    31,014
    Oh it's both, I've done it. You're going to need to hit 75 mph every chance you get and ride 18 hours per day.
  15. larryboy
    Jan 9, 2005
    31,014
    That's not really possible. For instance, the TAT through Colorado has a 20 mph speed limit unless posted higher.
  16. KenCM
    Jun 9, 2014
    711
    DRY RUN RESULTS
    Discovered several things:
    * After the test run of my auxiliary light a week or so ago, I adjusted the brackets to raise the light. Turns out that slight extension was enough that the clamps on the bars no longer hold sufficiently to keep the light from rotating downwards. PROPOSED SOLUTION: Drill and tap the bracket for a set screw.
    * I haven't used the InReach much since last year's trip. We were riding for 45 minutes this morning before I realized I'd forgotten to turn it on. We stopped and I did so. When I got home I discovered I'd neglected to start the tracking. PROPOSED SOLUTION: Place a checklist in the map case on the tank bag with items for Morning, Stops, and Evening to help ensure everything gets done properly.
    * The backpack is a less than ideal solution. It requires 3 bungies to hold it in place and even then it's... spineless - I guess is the best word I can think of to describe it. SOLUTION: Was at Euro Sports of Tampa Bay today and picked up a Kriega 20L bag to use instead. The Kreiga bag can double as a backpack and it snaps on nicely to the beavertail of the Reckless.
    FASTRacing, FarmerKeith and DCTFAN like this.
  17. KenCM
    Jun 9, 2014
    711
    Last year I carried one of those emergency straw water filtration gizmos - I didn't pack it this year.
    A buddy pointed this $20 filter out.
    Added it inline to my Klim jacket hydration system.
    Weighs next to nothing.
    Positioned it so the filter hangs just in front of the shoulder.
    Getting the tubing onto the filter was... not easy - put some Vaseline on the stubs and that helped.
    Repoman87, Aces 6 and FASTRacing like this.
  18. KenCM
    Jun 9, 2014
    711
    Replaced that green pack with a 20L Kriega bag and sorted out the mounting.
    Here's what it looks like (raining outside, so in the garage and pictures a bit cluttered):
    From the back
    From the front
    Side
    Lower profile.
    More securely mounted.
    No bungies.
    Moved the hydration pack that was in the backpack into the lower rear pocket of the Reckless 80. So that 5 lbs. is not in the Krieger, but lower.
    Almost doesn't seem like it belongs on MY bike :lol3
    FASTRacing and steveo555234 like this.
  19. PittsDriver
    PittsDriver Fuse lit.... Supporter
    Mar 11, 2012
    1,042
    Annapolis, MD
    Don't ya just love how many people are ready to say "It can't be done!" Kudos for having a real stretch goal on speed/distance/schedule. It's not for every one, especially those that like to smell the roses and do some bird watching along the way but obviously you've done the ride before and know what's ahead of you.
    Somewhere up there in this thread you said something like "did it in 20 days on a less capable bike." What'd you mean by that? What "more capable" are you riding/doing this time that will chop 40% of the time off your trip? We rode the TAT from Andrews NC to Port Orford in 2015 and it took 20 days of haulin' ass, riding long days, camping (no searching for places to sleep), AND skipping big sections of what we called "gratuitous gravel" like, oh, the entire TAT track through the state of Oklahoma.
    So, I'm personally going to be really cheering for you and definitely think you ought to give it your best shot. Do I think you can ride coast to coast in 12 days? Absolutely. Do I think you can do it riding nearly all of the TAT? LOL, I guess we'll see!
  20. DCTFAN
    DCTFAN 2019 CRF1000LD | 2016 CRF1000LD | Supporter
    Mar 17, 2016
    2,243
    GA
    Those CAM straps don't look very secure in the back.
    I'd loop/hook it onto the straps itself and zip tie them for added insurance.
