2017 TAT, Ocean to Ocean in 12 days, Planning
Discussion in 'Americas' started by KenCM, Jun 28, 2017.
  1. KenCM
    KenCM Been here awhile
    Jun 9, 2014
    711
    Central FL or East TN
    The 12V outlet is only switched on with the ignition, which turns on the lights and other accessories.
    It is also fused (7.5A)... and getting to the dang fuse requires removing the mid-cowels and a front piece - like 40 minutes round-trip.
    So as a matter of practice, I do not plug anything significant or questionable into the 12V plug.
    I'll probably go the Antigravity battery route and live with the time/inconvenience of battery terminal access.
  2. Aces 6
    Aces 6 Whiskey Tango Foxtrot, Over
    Mar 10, 2009
    5,654
    CONUS
    I see. Mine is active to receive battery tender (PC8 box) so doesn't need to be switched on.
  3. DCTFAN
    DCTFAN 2019 CRF1000LD Supporter
    Mar 17, 2016
    2,278
    GA
    No doubt, won't work because the clutch is disengaged.
    Sent from my XT1254 using Tapatalk
  4. gbw
    gbw hillbily whisperer
    Sep 29, 2009
    252
    Murfreesboro TN
  5. Drumbrakes
    Drumbrakes Been here awhile Supporter
    Jun 13, 2015
    800
    Edinburgh
    KenCM seemed to be having fun with his heated washing line and it should trickle charge pretty well, but now that you mention it, this arrived at my house today!
    I already have permanent leads wired to the battery, because this is my second one.
    I had a frequent overnight discharge problem I thought was caused by a dodgy alarm.
    Attaching the pack and starting up took less that a minute.
    However, this is what happens if you regularly draw more current than they are rated for over a 2 year period
    (Still worked though)
    It's a very good product, and ideal for your purposes, if 10 minutes of charging is too slow.
    Aces 6 likes this.
  6. larryboy
    larryboy Stable genius.
    Jan 9, 2005
    31,022
    Über Alles,California
    Taking wheel bearings with you?
    On my attempt at a 330 mile average per day for 23 days wheel bearings, tires and clutch cables were my undoing. Still managed 290 miles per day for 21 days with a 37.5 mph moving average. You've run a fast pace on a smaller bike like I have and I see no way possible to go even faster on a bigger bike. I did pick up the pace once I sent everything home except my camelbak and tools, it got more expensive due to motels, but I was railing without the camping gear.
    Can't wait for the report!!
    Good luck.
    :lurk
    joenuclear likes this.
  7. Drumbrakes
    Jun 13, 2015
    800
    Edinburgh
    Find this part from your local store, and wire it in once before you go.
    http://www.antigravitybatteries-uk.co.uk/accessories/microstartxp1harnesskit.html
    Edit:
    You got there first!
    Aces 6 likes this.
  8. KenCM
    Jun 9, 2014
    711
    I'm really trying to avoid taking that dang battery out again :nah
    From here: http://www.engineeringtoolbox.com/wire-gauges-d_419.html
    ...it looks like 12 gauge has 66% the current carrying capacity of 10 gauge and all those jumpers (and the Antigravity) appear to be 10 gauge while mine is 12 gauge - albeit several times the length.
    So m-a-y-b-e it'd work.
    I need to move on to the auxiliary light guard, so no more time on this.
    I'm going to take an Antigravity and my hillbilly jumper cable and we'll just see how things turn out.
    Aces 6 likes this.
  9. KenCM
    Jun 9, 2014
    711
    I thought the name "Antigravity" was an implication of it's light weight - not that it literally doubled as a hydrogen balloon!
  10. KenCM
    Jun 9, 2014
    711
    Thanks.
    The big bike choice was actually driven by the problems I had with a smaller bike - most notably the tires.
    My working theory is that bigger tires = fewer failures and the same for shocks, bearings, etc...
    I guess we'll see.
    DCTFAN likes this.
  11. Aces 6
    Mar 10, 2009
    5,654
    CONUS
    A different method for starting a bike with a dead battery
    rbsride365 likes this.
  12. KenCM
    Jun 9, 2014
    711
    Decided an auxiliary light guard might be in order.
    Obtained some .125" Lexan.
    Cut it to the size shown (14" x 4")
    Used some mounts (obviously meant to be used for mounting the light) and hardware that came with the light.
    Added a neoprene washer in the front.
    Behind the Lexan is a rubbery piece that came with the mounts.
    Stop nut on the back.
    Will probably round the corners of the Lexan.
    FASTRacing likes this.
  13. Dyrden
    Dyrden Been here awhile
    May 3, 2017
    140
    That light is quickly becoming a bugs worst nightmare.
    DCTFAN likes this.
  14. DCTFAN
    Mar 17, 2016
    2,278
    GA
    I thought the stock Hi-beam is bright/wide enough.
    What necessitates the extra LED?
  15. KenCM
    Jun 9, 2014
    711
    It just depends on how much you want your night riding to be like riding in the day.
    Using this aux light compared to the stock hi-beam is like using the stock hi-beam compared to a flashlight.
    EDIT: I should have mentioned... The stock light is very bright. So much so that before I traded my KTM 1190 ADV R in on this AT, I tried NOT to be riding in front of Garrett on his AT at night because the stock light is very bright.
  16. DCTFAN
    Mar 17, 2016
    2,278
    GA
    Right! I forgot you guys may be doing a lot of riding in the dark.
    I see the light :)
  17. KenCM
    Jun 9, 2014
    711
    Yep. Depending upon the definition of "dark," something on the order of 4 hours per day.
  18. larryboy
    Jan 9, 2005
    31,022
    The traction control might help with tire life. I've been reading of quite a few rear wheel bearing failures in the cry about your AT thread, I'd take a couple sets with you.
  19. KenCM
    Jun 9, 2014
    711
    Haha - I turn off traction control as part of my start-up sequence.
    I'll check into the bearing. Thanks.
  20. Dyrden
    May 3, 2017
    140
    I've played with the TC a bunch and end up using the lowest level the most while trying to balance steering and unproductive/excessive wheel spin. I wish there were more than the preset modes and a user programmable setting as well. Then add a "master setting button" like on power seats in cars that returns all settings to your presets. I also wish I didn't like bacon burgers as much as I do, but it's not a perfect world. I'm eagerly awaiting the start of your trip.
