2017+ Vstrom 650/650XT
Discussion in 'Japanese polycylindered adventure bikes' started by MariusD, Oct 4, 2016.
  1. eakins
    eakins Butler Maps
    May 29, 2002
    36,245
    Fort Collins, Colorado
    Look above
  2. eakins
    eakins Butler Maps
    May 29, 2002
    36,245
    I'd say that depends on bar bend, sweep, width, for/aft position, risers used, gen of strom
  3. The_Precious_Juice
    The_Precious_Juice 2019 DL650XT Touring
    Jun 2, 2013
    9,455
    SW VIRGINIA
    2" is good enough.
    The DR could get 2".
    Most likely so can the Wee.
  4. Gustavo
    Gustavo Motociclista Errante
    Jun 1, 2004
    4,477
    Sometimes in Hillsburrito
    You can't get 2 inches without rerouting the cables and brake line. IIRC, conventional wisdom on the V-Strom forums is that 1 inch is all you can raise the bars before you start running out of cable and brake line length. As mentioned above, I only have experience with 2 inch risers, so can't guarantee that's true.
    Gustavo
    The_Precious_Juice likes this.
  5. The_Precious_Juice
    Jun 2, 2013
    9,455
    SW VIRGINIA
    I just watched a review by brake magazine and he said that she has a good wheel turn range.
    That might be why 1" is as high as you can go.
    The height is not an issue. It's the reach.
    I wish she had Versys 650 ergos.
  6. mh7
    mh7 Adventurer
    Aug 18, 2019
    16
    Memphis, TN
    Front and rear sag are set appropriately. Cogent ddc front end with stock rear. The top box was normally empty or had just a backpack with a laptop-I’m about 205 lbs plus gear. It didn’t make the bike unrideable by any means, but it definitely feels better balanced, more predictable, and overall (a little) more enjoyable with the box off. It’s disappointing as I love the top box for commuting, so I was just curious what everyone else experienced
  7. Gustavo
    Jun 1, 2004
    4,477
    Yeah, between your weight and the topbox load behind the rear axle, you are taxing the rear spring/shock. I weigh a lot less, have an aftermarket shock (refurbished DL1K shock, which is longer, so it also shifts more weight forward) and I can tell when I have a fully loaded topbox that bike doesn't handle the same. You are right, for commuting, it's hard to beat a topbox. When I travel, I have a drybag that sits over the passenger seat and rack, keeping the weight forward and having minimal impact on the bike's handling. Unintended benefit - the shape is actually a lot more usable, despite having the same nominal rating as the topbox, I can fit more things in the drybag. Con - it's harder to find things at the bottom of this cavernous bag... :fpalm
    I actually bought it for my Versys, as it has a shorter wheelbase and is even more affected by a heavily loaded topbox than the V-Strom, but it works just as well on the V-Strom too.
    Gustavo
    The_Precious_Juice and rsteiger like this.
  8. The_Precious_Juice
    Jun 2, 2013
    9,455
    SW VIRGINIA
    I was curious as to how well the 650 is doing with inflation.
    $1,300 increase in price from 2011 to 2020.
    So, $144/year.
    Top improvements:
    Two engine upgrades. More beans and longer service intervals.
    ABS
    Lowered pipe
    Rear spring load adjustment
    Slimmer ergonomics
    Gear indicator
    12 volt socket
    TC
    Easy Clutch assist
    Can upgrade to spoke wheel tires easily. And the XT Touring model too.
    Did drop some fuel. 5.8 down to 5.3
    Did gain about 5lbs of weight.
    ____
    I would pay the extra $1,300 for the 2020 model.
    No question.
    Now, upgrading to the DL1000 that is now $13,399. No way.
    I'll keep the $4,600.
    The ergos are better and so are the suspension and brakes. But that really matters if you are pushing the bike harder. Sure, one could argue it is safer.
    ggrant likes this.
  9. rickh123
    rickh123 Been here awhile
    Aug 15, 2010
    438
    ON, Canada
    Rear shock adjustment existed already on 1st and 2nd generation. Unfortunately for some strange reason Suzuki decided to make front end not adjustable any more for 3rd gen. In addition you can't just replace forks on it with set from previous model because lower legs are not the same. They changed design of ABS sensor and it's mounting point.
  10. The_Precious_Juice
    Jun 2, 2013
    9,455
    SW VIRGINIA
    Thanks for the feedback.
    So did the 2011 model have ABS?
  11. Gustavo
    Jun 1, 2004
    4,477
    ABS was available on V-Stroms since the 2007 model year as an option. It became standard on the 2nd gen bikes (2012 and later).
    Gustavo
  12. rickh123
    Aug 15, 2010
    438
    ON, Canada
    No ABS on 1000 untill 2014 model. On 650 as mentioned above except Canada where it was standard on 2008 and up.
  13. Norcal_Rider
    Norcal_Rider IBA Alumnus Supporter
    Sep 3, 2007
    267
    Sonoma County, CA
    I added some 10w LED lights to my '17 650 V strom today. Mostly for others to see me but also to brighten up the night a little. I got some Vision X lights off of Craigslist for $30, and after thinking about fabbing a mount, I decided to order a light mount from Rick at Adventure Tech. I'm glad I did, because the mount works well, is powdercoated and is well thought out. There are lots of ways to wire auxiliary lights, but for me the simple solution is to wire with a relay that is triggered by the high beam circuit. I had an old PIAA relay laying around and used it for this project. IMG_4347.JPG IMG_4348.JPG IMG_4351.JPG After some searching I found that the high beam circuit to the lights (yellow wire) can be accessed at the large group of plugs fastened to the left fairing panel. I hope this tidbit of information helps someone down the road.
    tjzondrz, RobG. and stromsavard like this.
  14. Ernest T
    Ernest T Long timer
    Jun 19, 2008
    5,094
    Texas
    I've seen adjustable fork caps on e-bay. Will they work on the 2017 and up to make preload adjustable?
    https://www.ebay.com/itm/Preload-Fo...527551?hash=item3d938d79bf:g:WZkAAOSw-INdkaUP
  15. Gustavo
    Jun 1, 2004
    4,477
    @Ernest T - Yes, but these are not the right size. The DL650 uses 43mm forks.
    Gustavo
  16. Vrode
    Vrode Not my problem Supporter
    Jan 21, 2014
    4,833
    Vermont
    Has anyone gone from a Super Tenere to a late model Wee? I’m thinking lighter is better at my age and the Wee checks a lot of boxes ( reliable, dirt roady, decent handling, etc). I’ve had big hp and don’t mind the idea of having to flog it for motivation. I must be gertting old because just tooling around (instead of hooning) is my thing these days.
    aussie dubber likes this.
  17. Hogges
    Hogges Been here awhile
    Apr 7, 2018
    325
    Burlington, VT
    How does this help you be seen by others if you wire it to the high beam? Then it's only on when nobody is in sight.
    JAMIII and Flyin' Monkeys like this.
  18. Norcal_Rider
    Sep 3, 2007
    267
    Sonoma County, CA
    high beams during daylight hours increase visibility
    Motonirvana likes this.
  19. Hogges
    Apr 7, 2018
    325
    Burlington, VT
    Wow, this is totally irresponsible in my opinion and I believe also against the law just about anywhere. Doesn't do anything to maintain good relationships between motorcyclists and other motorists. Why don't you just wire the accessory lights to be on all the time instead of driving around with high beams on?
    ggrant and Flyin' Monkeys like this.
  20. Norcal_Rider
    Sep 3, 2007
    267
    Sonoma County, CA
    I may end up doing just that...
    Flyin' Monkeys and Hogges like this.
