2018-2019 Africa Twin Adventure Sports
Discussion in 'Japanese polycylindered adventure bikes' started by cabanza, Nov 6, 2017.
  1. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    755
    Jacksonville FL
    The ATAS rear rack is VERY sturdy. In a deer strike endo I had my aux tank torn free and the mounting plate bent around the rack but the rack remained undamaged. Here's a very blurry pic of it.
    rbsride365 and chasdog like this.
  2. GMM
    GMM Been here awhile
    Mar 15, 2005
    101
    Middle Tennessee
    I used compressed air to dry the tank after the acid/base flush. After the tank was dry, I flushed it with gasoline. Once I got the bike back together, I filled the tank completely to the top with gas (bike was on the center stand). I figure if any water was left in the tank, the ethanol in the gas would take care of it.
    chasdog likes this.
  3. GMM
    Mar 15, 2005
    101
    Middle Tennessee
    I have the SW Motech rack and 42 liter Givi Outback case. This setup is very sturdy and should not have a problem supporting two up riding. The only issue is that the case slants forward due to the angle of the stock rack and how the SW Motech plate attaches to it. I'm going to try to level it out some with some spacers when I get around to it.
    rbsride365 likes this.
  4. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    Cuyahoga Falls, Ohio
    Thank you. Hope everything worked out for you after that. Deer suck. We've got plenty where we live and I've been lucky a time or two. I guess I won't worry about it. I think the Altrider might give me a little more real estate and looks like the case might mount a little further back off the pillion seat.
  5. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    Hey all. Picked up my new bike yesterday. Think I'll absolutely love it. Hadn't ridden the AS version before. Bought a manual. Couple things. Does this engine run a little warm? I'm coming from a Suzuki Vstrom where you never felt the engine heat. I know this thing is wide at the bottom and right in front of your shins. After 20 minutes I can feel the heat coming off of it. Maybe my test rides were never long enough to notice but thought it strange. 2ndly, removed the skid plate last night to make sure I had everything I needed tool wise for an oil change on the road this weekend. Discovered oil on the front left corner of the motor that had dripped onto the skid a little and also on the bottom of the plastic cable cover on the front left side of the motor. Hoping that someone just spilled something trying to get things prepped. Definitely motor oil. Cleaned it up well and will ride again today and take the skid off and look again. Hoping it's dry! After reading all the negative stuff on here I'll admit I have a little anxiety over this whole thing. My Vstrom never had any problems at all or needed anything but consumables during the entire 63k miles I owned it. IMG_1262.jpeg
  6. playinatwork
    Jul 30, 2010
    755
    Jacksonville FL
    Make sure the oil filter is snug and on properly. I haven't noticed any heat issues on the ATAS.
  7. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    I will double check. No wetness around the entire filter seal that I could see though. Even ran my finger around it.
  8. Motorwerx
    Motorwerx Been here awhile
    Feb 12, 2014
    290
    Spokane, WA
    Congrats on the new bike! Unfortunately it looks like you might have the same issue that I did on my '18 ATAS. I had the same oil accumulation in the skidplate as well as specks on various plastics and even up to the windscreen. Looking around I couldn't trace the source, but it seemed like it was making its way down from higher up on the engine. The most noticeable was it accumulating underneath the clutch cable on the side of the bike. Dealer tore it down and figured out it was the valve cover leaking. Replaced the gasket and it still leaked, put the valve cover on a bench and it was warped. Replaced the valve cover and the gasket and I haven't had any issues since. Wasn't anything of my doing, just came that way from the factory because I remember noticing what at the time I thought was excess grease from the triple clamp being thrown up on the windscreen on my ride home from the dealer with 2 miles on the bike. Covered by warranty, but was a huge pain as the whole process took over a month.
    Some photos of mine for comparison:
  9. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    Awesome. Let's hope not. I guess we'll see what happens when we get home today. I was thinking it looked like it was coming from above. We will see.
  10. Squily
    Squily Squily Supporter
    Sep 18, 2006
    2,978
    Esperance WA (Down Under)
    my dct had an oil leak close to the dct oil ports. shop repaired it three times (o-rings etc) and it just got worse. finally they changed the cover gasket- said it was probably damaged in the factory during installation. fixed the oil leak
  11. TETSUHIRO
    TETSUHIRO Adventurer
    Aug 25, 2019
    10
    SAITAMA, JAPAN
    In the past, oil leaked from the rubber seals of my African Twin. That part can be resolved by caulking again with a liquid seal. The manufacturer warranty is valid. p7.jpg p4.png p5.png
      File size:
      166.8 KB
      58
  12. dwelds
    dwelds Been here awhile
    Jan 2, 2015
    105
    here n there
    Does anyone know how many watts the stator can supply on this bike? It was easy to find for a wrr not so much for this bike. I don't know if that means she's big enough for whatever you want or if there's still a limit.
  13. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    So it seems like the oil pan bolts on the front left corner where shown in the pic I posted may not be torqued down all the way. 4 or 5 in the corner shown could be tightened with little effort with a small ratchet, the rest of the way around could not. Torquing them to spec tonight but after putting some miles on it the leaking is much much less than it was. I have no oil coming from any higher on the motor. If it doesn't completely resolve itself I guess it will have to go back to the dealer. There is a metal gasket. I guess we'll see what happens. I'll post back later when it finally get's resolved completely. Thanks for the input.
    Oh, and I did have a tiny drip of coolant on the right side lower frame rail and the skid. Seemed to drip off of some small silver "nail" looking thing sticking out of the casing. Will look again tonight to see if we have any more. Couldn't really track that down.
  14. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    The DCT that I test rode had that problem. They had been waiting two weeks for the o-ring. They let me ride it but an amazing amount of oil had blown past that little seal during the short ride I had and all over everything. Glad it got fixed. I have to admit that the fact that they were having problems with it did influence my non-DCT decision a little bit.
  15. chittyrox
    chittyrox Been here awhile Supporter
    Dec 20, 2013
    165
    Midwest-ish
    For the coolant leak; overflow from the catch tank?
  16. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    793
    I guess I need to look the bike over more. The coolant tank is way toward the back near the swing arm pivot. This drip was up front on the right near where the frame spars go flat. It appeared to be dripping off of a nail like thing hanging off the back edge of the bronze colored engine case more toward the front. I'll grab a picture later and update. It is on the side with the water pump and all that. No idea where the overflow would be but the bike is new so the thought had crossed my mind and the sight of it didn't concern me a whole lot since it was very minimal.
  17. pepebayeta
    pepebayeta Been here awhile
    Dec 18, 2007
    624
    Spain
    400 Watts, if I'm not wrong
  18. Mr.Black999
    Mr.Black999 Been here awhile
    Jun 22, 2009
    481
    Sydney,NS
    490 watts at 5000rpm
    CLANTECH and pepebayeta like this.
  19. chasdog
    chasdog Been here awhile
    Mar 31, 2007
    149
    Sandpoint
    Looks like Honda has finally come up with the fuel pumps for the ATAS. My bike is being put together with a new fuel pump after 2 months in the shop. I’m excited to get my bike back!
  20. playinatwork
    Jul 30, 2010
    755
    Jacksonville FL
    I’ll need most of those watts when I hit my hi beams.
    Ledrider LD5’s
