2018-2019 Africa Twin Adventure Sports
Discussion in 'Japanese polycylindered adventure bikes' started by cabanza, Nov 6, 2017.
  1. DSM8
    DSM8 Where fun goes to die....
    Aug 1, 2005
    7,522
    Escondido, Ca
    The filter sock install after giving the tank a good cleaning will mitigate much of this issue since your removing bulk of the contamination and increased the pre filter area several hundred fold with the sock over the filter
    https://advrider.com/f/threads/atas-fuel-pump-filter-howtoo.1404188/
  2. redneckmech
    redneckmech No burrito left behind!
    Jan 31, 2010
    792
    Somewhere up shift creek sans paddle..
    Yes they have! I have another 2200 miles since the modification with no further issues. With the extra filter area of the guglatech filter combined with the tank sealant I really do not see this issue returning.
    If you did not want to completely seal the tank I think that treating it with the phosphoric acid and using the guglatech filter would be adequate as that seemed to remove the majority of the crud.
    Motorwerx and chittyrox like this.
  3. deadzed
    deadzed Meat Popscicle
    Jul 11, 2010
    231
    I've got over 2500mi on my replacement tank & filter, purposely recreating the high temp, low fuel conditions of the previous fueling issues. So far so good. The weather's starting to cool off now so I'm unlikely to get any more opportunities to run it hard in 90+degree conditions this year.
  4. playinatwork
    playinatwork Been here awhile
    Jul 30, 2010
    805
    Jacksonville FL
    Last night I pulled my tank off without removing my Heed bars or the side panels. This is way easier than pulling the panels and tank to access the fuel pump.
    Just pull the 2 rubber grommets loose on each side panel after removing the plastic piece on the front of the gas tank. Then remove the tank.
    windowto, simmons1 and Kiwi Canuck like this.
  5. chittyrox
    chittyrox Been here awhile Supporter
    Dec 20, 2013
    165
    Midwest-ish
    Thank you for your feedback, I will consider this as I do the future updates! =]
    I don't think I will be accepting another new fuel tank, as that is the root cause.
    Honda replaced with a new fuel tank and fuel pump, same part numbers as what came on the bike. 3900 miles later, my issue came right back so it was only a band-aid with the same bad "new" fuel tank. I ride in 85+ degF heat in the midwest and south. Now I have to miss the Cookeville, TN and Buffalo rides =[
    I hope it works better for you!
    chasdog likes this.
  6. playinatwork
    Jul 30, 2010
    805
    Jacksonville FL
    @chittyrox Why not just pull the tank, clean the strainer, rinse the tank with some vinegar, and put it back together? It shouldn't take more than 2-3 hours and you can go riding. I know it is still under warranty but it beats not riding.
    Amphib and chasdog like this.
  7. chasdog
    chasdog Been here awhile
    Mar 31, 2007
    150
    Sandpoint
    The other day I was able to recreate the problem on my repaired Atas. My fuel gauge said I had enough fuel for another 40 miles at the start of a ride. At about the 30 mile left up a mountain road the bike cutout. At first I put it down to a late shift and hitting the rev limiter. Then it happened again. It got worse on the way back down the mountain. I had a showing of 15 miles left when I pulled in to the gas station for a fill up. It was still running but any amount of excess throttle would cause cutout. The tank took 6.412 gallons to fill.
    The bike has about 800 miles on it since the fuel pump , tank cleanse. After filling the bike ran fine.
    At this point I am hoping this occurred as a result of having hardly any fuel left.
    Opinions?
  8. chittyrox
    Dec 20, 2013
    165
    Midwest-ish
    I could do that and if this would have happened outside of warranty I would do that. I bought a brand "new" bike from a reputable company and although every bike has it's issues, this is not acceptable. Issues like this are reasons why companies so big get away with things, as we (the handy consumer) do the work for them which helps to hide their issues so they do not "need" to actually fix the root cause. They also cost me alot of $$$$ in hotels and to fly back when it left me stranded. The second time almost got me ran over by a semi on the interstate, and Honda needs to be held liable. It should not take somebody getting hurt for them to fix their known issue.
    Again, I do agree I could have this back up and running after a couple hours + the guglatech pump filter. But there are other things tied to this claim as to why I cannot do it myself (at this time). Sorry for the long post =]
    windowto and chasdog like this.
  9. rbsride365
    rbsride365 Hi-Viz
    Oct 3, 2008
    833
    Cuyahoga Falls, Ohio
    Another top rack question. I purchased the AltRider rear rack with the hopes of mounting my Givi Trekker 42L top box on it. Turns out that even though the rack is pre drilled for Givi Monkey mounting and I have the Altrider Givi hardware kit that there is interference with the grab rail where the two posts mount. To make matters worse I apparently overlooked Altrider's and Revzillas fine print. Revzilla says it doesn't work, Altrider says there is "interference" so call for help. So assuming that I need to pick a different rack is the SW Motech rack the only real good option? I don't want the Givi rack with the complicated support system and really wanted a large plate rack that I could also use for soft luggage. Does anyone know if the B&B rack works well for this application? I'm not interested in the extension plates since I'll probably end up with an SW Motech pillion seat that it won't clear so just need a good solid tail rack that accepts Givi Monokey top boxes.
    EDIT: I just got off the phone with AltRider. They are making a set of 3D printed spacers that lift the rack off the grab rails to create space for the Givi mounting kit. (The nuts on the bottom of the two forward Givi mounting pins hit the grab rail on the ATAS bikes). They are supplying the spacers as well as longer bolts to replace the 4 that come with the rack. I was charged $7.50 for the parts and another $7.50 for 2 day FedEx shipping. Apparently very soon these parts will be included in the Givi hardware kit that Altrider distributes and will be specific to the bike. I will post pics of the whole setup when I get it. I was told that they have only been doing this for about two months but that the parts seem to work and hold up just fine. Now that I know what they are doing I'm sure I could have fab'd something up myself but for $15 I don't need to leave my house. We'll see how this goes. A little irritating to buy a rack for a specific bike that is pre drilled for Givi hardware that won't actually work.
  10. rob377
    rob377 Adventurer Supporter
    Jul 29, 2012
    18
    Indiana
    I had the nearly the same thing happen last week. At 15 miles left, it started sputtering whenever I opened the throttle. I shut it down to pull of the road and check the bike over, and then when I restarted, the range went to "---" Fortunatley I was only a few hundred yards from a gas station and limped in to the pumps. Oddly, it only took 6.1 gallons to fill, which seemed weird. I bought a cheap wifi endoscope to check the inside of the tank once it gets close to empty again. *fingers crossed* Bike only has ~900 on the clock, but almost all of that was in in pretty warm weather.
    chasdog likes this.
  11. Quercus petraea
    Quercus petraea Been here awhile
    Jan 11, 2019
    209
    Spain
    So do you think that is not a protective product to prevent welds get rusty? No need to aply any sealing product after cleaning the tank?
  12. chasdog
    Mar 31, 2007
    150
    Sandpoint
    @rob377. Good to know your bike did the same thing with low fuel.
  13. AZMtnRider
    AZMtnRider Been here awhile
    Feb 1, 2016
    188
    Southeast AZ
    I began installing my barkbusters tonight. I am having trouble getting the right side clamp away from the wire coming from the bottom of the front brake switch. I moved the reservoir right and left, but the clamp is still really close. You can see the wire in the photos below.
  14. chasdog
    Mar 31, 2007
    150
    Sandpoint
    Here’s a pic. of my barkbuster install. Pic makes it look tighter than it is for the wires, there’s some wiggle room.
    Getnout likes this.
  15. AZMtnRider
    Feb 1, 2016
    188
    Southeast AZ
    Thanks Chasdog. That’s where I have mine, and it all fits. Just a lot closer to things than I would like. Now I am dealing with the throttle not wanting to return properly, even though there is a gap between the rubber and the bar end weight. I quit for tonight and will tackle it tomorrow after work.
    Getnout likes this.
  16. mpharris
    mpharris Adventurer
    Jun 18, 2018
    26
    Lancaster
    The kit include a spacer (washer) that goes between the bar end weight and the throttle. I had to double mine up to prevent the throttle from sticking.
    chittyrox, AZMtnRider and Getnout like this.
  17. relichunter
    relichunter Precariot
    Nov 23, 2015
    102
    Provo, UT
    Just picked up a new 2018 ATAS in Phoenix and rode it straight home, only 650 miles. The next day I rode it to work and discovered oil burning off the engine on the right side. Dealer had it for two weeks waiting on a bolt from honda. They determined that a bolt had been over tightened causing a crush washer to fail. The bike is too new for me to have any idea what that really means. I'm hoping this isn't the harbinger of more problems.
    rob377 likes this.
  18. AZMtnRider
    Feb 1, 2016
    188
    Southeast AZ
    Mine came with three washers. With just one washer, there was already a space. I ended having to cut the end of the rubber grip off. Apparently the BB insert stretched the end of the bar slightly and the rubber was now too tight. No pun intended
  19. chittyrox
    Dec 20, 2013
    165
    Midwest-ish
    Before I put the Kaoko lock throttle on, I also had to add another spacer. I emailed Barkbuster and sent pictures along with videos, and they understood that there is some variation from the plant with how far the throttle is installed on the handlebars.
  20. GMM
    GMM Been here awhile
    Mar 15, 2005
    101
    Middle Tennessee
    I decided to try cleaning the tank with the method described and not coating the tank. Based on the research I did, my opinion is that the residue in the tank is a byproduct of the welding process opposed to a coating applied to the welds. If I have any problems in the future, I will install a tank coating like redneckmech did on his. I'm not worried about the welds rusting in the tank as a result of the cleaning.
