2018-2019 Africa Twin Adventure Sports
Discussion in 'Japanese polycylindered adventure bikes' started by cabanza, Nov 6, 2017.
  1. dwelds
    dwelds Been here awhile
    Jan 2, 2015
    105
    here n there
    Can't compare something being broke to regular maintenance.
  2. Cuchulainn
    Cuchulainn Y.Me Supporter
    Mar 24, 2011
    162
    Denver, Colorado
    Of course, even if by doing it yourself you haven't been affected from Honda's perspective, you could still file a report with NHTSA and have it counted there.
    McLaughc and windowto like this.
  3. Olde Phart
    Olde Phart Olde Phart
    Mar 3, 2018
    650
    Land of Oro y Plata
    I appreciate your suggestion but I will defer given my particular animus for the NHSTA as no friend of the motorcycling community.
    I had my fill of them when Joan Claybrook blew over two million taxpayer dollars trying to design a motorcycle that steered with the rear wheel (despite physicists telling her it wouldn't work) and them engaging in statistical fraud to perpetuate the national 55 mph speed limit that I loathed with a passion unbounded.
    But that's just me ... :-)
    Good safety nanny nullification to ya!
    slipknot and playinatwork like this.
  4. redneckmech
    redneckmech No burrito left behind!
    Jan 31, 2010
    792
    Somewhere up shift creek sans paddle..
    Honda did mine the first time, I did it right the second. Took a while lot less time for me to do it than it took Honda.. Bike was down for two weeks at the dealership and I had it done on about two days and that includes sealing the tank.
    I don't like having others work on my vehicles and this just reenforced it. If ya didn't want to pull it apart and seal it it would be a pretty easy task to just swap the filter a couple times until flakes stopped coming through.
    Everyone has their own way of approaching the issue be it having Honda fix it, swapping filters, installing a prefilter, vinegar in the tank, sealing it or all of the above!
    I am disappointed to hear that Honda has not addressed the issue for the 2020 but it has been great seeing everyone's ingenuity and problem solving skills in action.
    chittyrox, Motorwerx and windowto like this.
  5. windowto
    windowto Long timer
    Jun 18, 2012
    3,136
    NJ
    Could you share your method and, maybe, pictures, if you got them? I have a 2016 DCT and seriously considering the 2020 ATAS, but dreading the potential tank problems. If I knew I could potentially fix it once and for all, I would be more encouraged.
    Thank you
  6. redneckmech
    Jan 31, 2010
    792
    I wrote it up in this thread a year or so ago. Posts number 2488, 2513 and 2547
    https://r.tapatalk.com/shareLink/to...&share_fid=14159&share_type=t&link_source=app
    https://advrider.com/f/index.php?posts/38156081
    https://advrider.com/f/index.php?posts/38202402
    Hopefully the links work, trying to pull them from my phone.
    windowto likes this.
  7. Mitch-DirtRider
    Mitch-DirtRider If it has two wheels, I’m on it!
    Jun 21, 2020
    1
    Murrumbateman, Australia
    Hey all, I recently experienced fuel starvation issues on my 2018 ATAS unaware of any such a problem prior. So I pulled the tank and had a peek and found loads of the white stuff! Then I got even more curious and jumped online and found some of you had the same problem with the flakes and that miserable black slime!
    So I opened the fuel pump up and man, no wonder she was down on power and hesitating - that sludgy goop got everywhere. I back flushed the teabag pre filter until it was white again, almost. Did the same with the filter inside the plastic housing. Cleaned up everything else I could get to.
    Bolted it all back up and took it for a spin and presto, the acceleration difference was unreal!
    I had to flush the tank about 30 times to clear much of it but I know it’s still in there on the welds that I can’t see or get to. I’d probably say there’s not much left because my final rinses didn’t have many of those flakes of doom. My tank flush technique was with fuel. I’d drop say half a litre in, shake it around, use my reverse fluid pump to suck the dirty fuel out, filter it back into the fuel container and repeat. Lots.
    I’m not the moaning type when it comes to motorcycles, I’ve had loads and they all tend to have the odd issue, I have a Harley and Ducati as my main bikes atm so I’m not unfamiliar with issues.... my Harley had to have a vent hole drilled into the primary to stop me losing tranny oil. For the time being I’m mobile again and I’ll call Honda Australia because it would have been nice to have been informed of this potentially dangerous condition before experiencing it on a killer road. I’ll also log a case with the dealer while I’m inside warranty. Because I think it’s a safety concern I’ve logged it with Department of Infrastructure and Transport because having fueling problems at speed on the Barton Highway into Canberra is not such a fun time.
    Other than this, the ATAS is a sweet machine. Maybe the grip heaters could be warmer but that’s splitting hairs.
    Thanks to all those folks who have documented this issue here on ADVR - really helped me understand what’s going on. Should have joined earlier!
    OneAUout, Blaise W, Pcfly and 7 others like this.
  8. NCD
    NCD Dirty Hairy Supporter
    Nov 13, 2008
    845
    NE Ohio
    Maybe I missed this in the thread, but once this material flakes off the welds...has anyone seen rust or anything develop along the seams? Wondering what happens in the longer term without the coating.
  9. docgonzo
    docgonzo Old Gadfly
    Mar 1, 2002
    21,156
    within 20 miles of the Center of the Universe
    Tried to get through this thread about the ATAS fuel filter issue, but am not an engineer.
    Is this a problem just with this model? I haven't had any problems with my 2016 AT with DCT that now has 39,000 miles.
    Was it the different tank on the AS that was the problem? Wasn't it recalled by Honda?
  10. redneckmech
    Jan 31, 2010
    792
    This problem is only related to the ATAS, standard models are unaffected. It was never recalled by Honda but it is covered under warranty.
    I have never heard of any rust forming and it likely wouldn't unless you had some contaminated fuel or the bike sat for extended periods. I can't really speak for my machine as I coated the inside of the tank 15k ago and have had no issues since.
    NCD likes this.
  11. Pcfly
    Pcfly Dude?! Seriously?? Supporter
    Nov 30, 2008
    1,952
    North of the Columbia River
    Yup, as mentioned on the previous thread, only on the ATAS. The issue showed on the 2018 ATAS but its continuing to show up and a few weeks back showed up on the AT FB page on a 2020 ATAS. Nobody seems to know exactly if its a paint overspray at the factory, a lining in the tank or metal flaking off from welds in the tank. I've even read some people believe its fuel related but nothing confirmed. I have a 2016 AT and 30K......zero issues. A friend has a 2018 ATAS and he had the issue. He replaced the fuel pump, dded a sock and cleaning out the tank. So far no other issues.:dunno
  12. North6633
    North6633 Long timer
    Feb 11, 2004
    1,133
    Portland, OR
    My 2019 ATAS is in the shop for that issue right now. Have about 2700 miles on it.
    The shop said they had two other bikes over the last year that had the same issue. See what they come back with as a fix.
    It's more than just inconvenience it's a safety issue mine decided to cut out and give problems on the interstate in full traffic at 70 mph while I was in the middle lane. So going from 70 to 40 in that situation is not much fun.
    Getnout likes this.
  13. Getnout
    Getnout Mmmmm, Micro Brews!! Supporter
    Nov 18, 2018
    359
    Albany, Oregon
    I've got the dreaded '18 ATAS and yes I delt with this tank garbage. I was on the Oregon BDR and with out warning, experienced major power loss. I could shut the bike down, restart and take off for awhile. Ugh........ Frustrating. Once home, did the Tank cleaning, Double filter sock, and as of now no issue. September 15th, gonna finish up the Oregon BDR so I'll let ya know how it goes. I'm confident my tank cleaning and a way larger filter surface will do the trick but time will tell and I definitely won't hold back. This is so frickin stupid for us to be dealing with...... Really! Come on Honda.......... Get this Shit right! IMG_20190816_161514.jpg
    rideforzen, windowto and Pcfly like this.
  14. windowto
    windowto Long timer
    Jun 18, 2012
    3,136
    NJ
    I decided to forgo the 2020 ATAS in hopes that the 2021 might fix it, but not holding my breath. I agree, it is insane to have this on a NEW Honda :becca. Even more insane to have this third year in the row :muutt!
    Getnout, BronNowo and twinrider like this.
  15. DSM8
    DSM8 Where fun goes to die....
    Aug 1, 2005
    7,563
    Escondido, Ca
    My solution after all the work I did to the bike and realizing it was never to be what I wanted out of it was to move on to another bike.
    pepebayeta, Getnout and BronNowo like this.
  16. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    17,839
    日本
    Yeah, it's understandable to have a batch of bad tanks, but you'd think Honda would change the production process to eliminate the issue.
    windowto and Getnout like this.
  17. Getnout
    Nov 18, 2018
    359
    Albany, Oregon
    ........... And while they were at it, lets think about a plastic, lighter tank too. :jack. I would love that.
  18. slipknot
    slipknot Hello Girls
    Aug 10, 2006
    1,225
    So long as those plastics are not of the same swell :D recipe that found their way to Ducati.
    Getnout likes this.
  19. Schlug
    Schlug JockeyfullofBourbon
    Jan 23, 2006
    12,643
    put something on and stay in that position.
    Came to the this thread after mulling over the 701, the 850GS, the AT, the Tenere, etc.
    While here I stumbled on easily one of the most confusing and illogical posts I have read in a long while. But, at least we know where this fellow stands. :norton
    Cuchulainn likes this.
  20. Olde Phart
    Mar 3, 2018
    650
    Land of Oro y Plata
    No worries, in reading your posting history I can see that you are easily confused ...
    Good escaping being held prisoner by your own lilliputian imagination to ya!
