2018 GS/GSA now recommends 87 octane fuel
Discussion in 'GS Boxers' started by 8241, Oct 30, 2017.
  1. 8241
    8241 Adventurer
    Dec 6, 2016
    22
    Just read through the Manuel and now bmw recommends 87 octane fuel. Wonder what changed ?
  2. jdub
    jdub Dawg bytes reel gud
    Jan 7, 2004
    3,023
    S. Central PA
    :lurk
  3. x32792
    x32792 Cracker American
    Jun 9, 2007
    1,745
    Winter Park, Florida
    What changed? Honda AT arrived and it burns regular gas.
    gobux and River-Runner like this.
  4. obcr
    obcr Adventurer
    Sep 5, 2017
    49
    Vienna, VA
    What are the implications? I use 93. Is there any harm done? Wasting money? Because I'm ok with that if I get more performance :lol3
  5. KHuddy
    KHuddy Survivor
    Jun 24, 2008
    4,094
    Silver City, Montana
    Using higher octane than required will not improve performance.
  6. x32792
    Jun 9, 2007
    1,745
    ^^You bring up some interesting points. I've burned 'mid range' 89 octane with no ill effects. I also believe you can have your ECU re-flashed to burn regular if planning to ride in the 3rd world (or just economically minded) - I here defer to those with technical knowledge on the subject of re-flash.
  7. ragtoplvr
    ragtoplvr Long timer
    Oct 18, 2007
    9,171
    central USA
    It will depend on how sophisticated the control algorithms are in the ecu. If it can tune to take full advantage of the octane then you will get more performance. If they play it safe and it does not retune, you can have worse power, as higher octane has lower BTU per gallon, so more must be burned.
    I am sure at some point we will have someone dyno on both fuel types, then we can know. Until then it is all guesses and wishes
    Rod
    TT RDHS likes this.
  8. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,656
    Coronado, CA - KNZY
    For model years up until 2018 BMW has recommended Premium fuel but with the footnote "89 AKI" which is Mid Grade in most states.
    Generally speaking internal combustion gasoline engines run at their peak efficiency when they are right on the verge of detonation so for this reason using fuel of higher octane than required is usually a waste of money since higher octane fuels contain less specific energy as noted above.
    There was a time when premium fuel grades would often contain more detergent and additives but that is no longer the case.
    I wonder what the technical reasoning for BMW to change the fuel requirement for the 2018 models, if it was an actual change to the bike (likely software if any) or if they have just come to the conclusion over the years that 87 octane fuel is safe.
    #8
  9. krussell
    krussell Long timer
    Nov 19, 2009
    3,095
    Portland, Oregon
    Which manual?
    I just compared 2014, 2017, 2018 and there hasn't been any change. Are referring to the 'alternative' fuel option?
    2014
    2017
    2018
    #9
    1911garand likes this.
  10. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,656
    Coronado, CA - KNZY
    Occasionally the printed manual that comes with the bike is more up to date and not exactly the same as the .pdf version downloaded from BMW's site, there is a chance that the OP is correct.
    #10
  11. Kaw4Life
    Kaw4Life Chief Dark Cloud
    Sep 27, 2008
    8,396
    Maine
    So ... to add to the issue ... how much 87 are we getting from a pump with only one hose?
    I highly suspect that 95% of cage drivers get the 87 and with the gate valve being at the other end of the hose from the nozzle ....
    I figure I am getting about a gallon of 87 with every purchase of 91 or higher octane.
    #11
  12. LowOnFuel
    LowOnFuel In the crapper
    Oct 2, 2007
    1,526
    Pacific Northwest
    A gallon? You think it's that much?
    #12
    gnwes likes this.
  13. Kaw4Life
    Sep 27, 2008
    8,396
    Maine
    Guessing ... not sure of the hose ID.
    #13
  14. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,656
    Coronado, CA - KNZY
    I read an article that seemed to be written with some facts and common sense, it may not have any place on this forum but the author seemed knowledgable and estimated no more than 1/3 of a gallon was left in the system between each use and would not effect the octane numbers as long as a couple gallons or more were dispensed.
    I notice that many stations have pumps that use separate nozzle/hoses for each grade these days.
    #14
    x32792 likes this.
  15. Kaw4Life
    Sep 27, 2008
    8,396
    Maine
    I am glad to know this. I guess I can stop running the bike on fumes until I find a three hose pump.
    #15
    PRW and Yearroundrider like this.
  16. Kaw4Life
    Sep 27, 2008
    8,396
    Maine
    I digress but I found this during some research of the topic.
    (publisher has not validated the validity of this photo)
    #16
    PRW likes this.
  17. krussell
    krussell Long timer
    Nov 19, 2009
    3,095
    Portland, Oregon
    I get all my premium at the 'high test' pump. Well, that's where it came from on May 8th in Maupin, OR.
    #17
    BMWGSA, HD Steve, Mofrid and 3 others like this.
  18. JetSpeed
    JetSpeed Naviator
    Nov 28, 2007
    7,656
    Coronado, CA - KNZY
    I'll wager it wasn't no millennial that pumped your gas with that contraption, no one this side of 70 years of age would be able to operate that pump, you gotta love it.
    #18
    PRW, CJ3Flyer, SPX and 2 others like this.
  19. Kaw4Life
    Sep 27, 2008
    8,396
    Maine
    It easy ... ya twist that black thingy until you see the number of woman that lust for me, then you go inside and screw the fuse in at the fuse box marked non-local-folk, RUN outside before all those rusted joint start spewing fuel every where and pump the gas as you would anywhere else.
    Easy :D
    #19
  20. yangins
    yangins Been here awhile
    Sep 23, 2014
    204
    Green Bay WI
    Had the BMW dealer flash the 87 map. Been running 87 since new. No porblem no issue. 16kmiles now. Pulled plugs to change last week and they look perfect.
    #20
    holycaveman, Jbrjbr21 and TT RDHS like this.
