2019-2020 CB300R
Discussion in 'Road Warriors' started by cabanza, Nov 6, 2017.
  1. rwifilipe
    rwifilipe n00b
    Apr 5, 2021
    6
    Portugal
    It's a bit louder than i'd like bit sounds good. I'll probably get a noise reduction Dbkiller.
    I'm thinking about upgrading to a bigger bike, i've done some 300+Km trips and find the gearing a bit short. But then the bike is so light an nice arround town, so i'll probably just get a 15t front sprocket
    GeoKrpan and KeimadO like this.
  2. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    My thoughts exactly! Did you encounter the 15T sprocket? I can only find one, from PBR.
    P.S.: Bem vindo! Portugal, caralho! :D
    rwifilipe and GeoKrpan like this.
  3. U4IC
    U4IC U4IK
    Feb 25, 2009
    40
    Lookout Mountain
    Any leads on finding a 15T front sprocket? - - Just found one on motosport.com made by Sunstar... Apparently #36115 - Amazon carries...
    I'm just wondering if I should be searching for a 2019 model without ABS, since the sprocket change isn't recommended for ABS models?
    Last Update: I recalled a post I saw previously about sprocket replacement to reduce noise. They recommended JTF1321 and JTR1224 with DID gold chain.
  4. GeoKrpan
    GeoKrpan Been here awhile
    Dec 6, 2018
    821
    Westlake Village, SoCal
    Welcome rwifilipe.
    Which aftermarket exhaust is it?
    rwifilipe likes this.
  5. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    For me it doesn't make sense the ABS/sprocket thing.
    The ABS reads wheel speed from the sensor/ring combo at the wheel. I guess it does not uses the vehicle speed info form the gearbox speed sensor.
    Anyone with access to a wiring diagram can confirm my theory please?
    By the way, the PBR reps at the United States of America is Drive systems:
    https://www.drivesystemsusa.com/
    Maybe you can get the 15T PBR sprocket from them.
    GeoKrpan likes this.
  6. Lee Dodge
    Lee Dodge Been here awhile Supporter
    Aug 9, 2002
    763
    Horicon, WI. By da marsh.
    The ABS unit has 2 connections to the ECM and the gearbox VSS also talks to the ECM. The ABS can generate an incorrect tire size error code. One way of doing that might be to compare VSS data and wheel speed sensor data. If the ABS unit is not seeing the data its expecting to see I suppose its possible ABS function could be compromised.
    KeimadO, rwifilipe and GeoKrpan like this.
  7. rwifilipe
    rwifilipe n00b
    Apr 5, 2021
    6
    Portugal
  8. rwifilipe
    rwifilipe n00b
    Apr 5, 2021
    6
    Portugal
    It's the Arrow X-Kone
  9. Reconstructed
    Reconstructed Been here awhile
    Jun 11, 2009
    413
    Lawrenceburg, Ky
    Hey everyone, quick question. Got any recommendations for a quality tail bag that will fit a full face helmet? The videos I watched on tailbag reviews didn’t say at all which ones will fit a helmet, and I don’t want to end up with something that won’t be big enough.
    Thanks.
  10. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    I have a Nelson Rigg Commuter touring. Full extended it fits easily a full face helmet.
    I also use it to put my stuff to go to work every day.
    Would buy again the Nelson Rigg.
  11. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    How do I do that..? :D
  12. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    What brake/cluctch levers are those?
  13. rwifilipe
    rwifilipe n00b
    Apr 5, 2021
    6
    Portugal
    They are some cheap short levers from Rezo. They work well, are adjustable and stable. I have small hands
  14. Reconstructed
    Jun 11, 2009
    413
    Lawrenceburg, Ky
    Thanks! I was looking at those, but wanted to get get some first hand knowledge.
  15. KeimadO
    KeimadO Adventurer
    Oct 27, 2020
    29
    Lisboa, Portugal
    Be advised that the seat is a bit smaller that the base of the tailpack, but not an issue at least for me.
    Let me see if I can take a picture of it on the bike.
  16. Reconstructed
    Jun 11, 2009
    413
    Lawrenceburg, Ky
    Yeah, that passenger seat is kinda small. I’m good with it though.
  17. BacasableFR
    BacasableFR Adventurer
    Mar 1, 2021
    43
    FRANCE, Paris
    Sounds very good, just like a supermot, but be aware, you don't have boot's protection on the pipe (i burnt my shoes a little, and it's smelled very bad everytime, i had to brush it)
  18. GeoKrpan
    Dec 6, 2018
    821
    I had been running my shock at full stiff on the advice of my long experienced neighbor, I weigh 193.
    Just for trial and error purposes, I backed it off two clicks. What a difference, it is now set correctly. I am able to lean the bike so much more aggressively and it holds the line so much better.
    There is a big curve near home that has perfectly smooth asphalt. I notice how well the bike sticks on this curve but not so much on the bumpy pavement in the canyons. The light bulb finally lit.
    I guess my neighbor would say it now has too much sag but it works and I'm leaving it that way. Advice is nice but thinking for ones self is nicer.
    I'm far from a beginner but it's the first time I've owned a bike where there is so many curves.
    U4IC likes this.
  19. DaBinChe
    DaBinChe Long timer
    Dec 28, 2007
    3,175
    Santa Cruz Mtns.
    I have, I think 2 SunStar, brand new 15t front sprockets available, $25 shipped.
  20. DaBinChe
    DaBinChe Long timer
    Dec 28, 2007
    3,175
    Santa Cruz Mtns.
    New SunStar sprockets are gone. I have a used one with under 4k miles some can have for $10, this covers USPS shipping and paypal fees.
