2019-2021 Honda CB500X
Discussion in 'Japanese polycylindered adventure bikes' started by cabanza, Dec 2, 2018.
  1. fastnlight
    fastnlight Tire Tester
    Sep 25, 2007
    654
    Gig Harbor, WA
    If you have heel clearance issues, just remove the heat shield. Problem solved and doesnt look half bad. Being so low, it serves no purpose for me anyway. The little mounting tabs could easily be cut off if your feeling picky. About a pound of weight to loose as well.
    https://photos.app.goo.gl/4e6JM69sHw8wWxVDA
    Greg
  2. fastnlight
    Sep 25, 2007
    654
    Gig Harbor, WA
    Looks like a direct no conflict fit. Spacers and longer bolts are used at front lower frame mounting points. I have hepco and becker bars that mount even simpler.
    Greg
  3. J.Mo
    J.Mo Been here awhile
    Aug 13, 2018
    101
    Belgium
    Fitted the 230mm black Widow exhaust. Sound is decent and not too load. Nice pops when getting off the gas. Only at highway speeds I think the original exhaust was more pleasant. That was what I liked about my 1200gs dohc which had a valve that opened when getting on the throttle then resulting in a nice roar. Rest off the time it was not load at all.
    Can someone tell me I fitted it good enough? First time I change an exhaust. The link pipe is not 100 procent straight with the original pipe piece. Had some leaks in the beginning but after tightening the clamps pretty hard it seems OK now. IMG_20191022_140520.jpg IMG_20191017_162306.jpg IMG_20191017_162311_1.jpg
  4. sscardefield
    sscardefield Adventurer
    Aug 13, 2016
    79
    Scottsdale, AZ
    Hey JoJo, have you gotten a chance to figure out how much of a drop you actually got with the Knights? I was planning on getting the Knights as well since they are supposed to be over an inch, but if in reality they are only providing .5" then I think I'd rather just go with the SW-Motech Ion's that are listed at .5".
  5. Jeffo
    Jeffo Been here awhile
    Mar 5, 2014
    731
    South West England
    Looks ok to me, looks great in fact and obviously looks better than the stock. Hard to tell from only the pics if the link pipe is situated correctly. If the centerstand stop tab is in the right place, then it should be good.
    Did they give you a tube of exhaust sealant ? you shouldn't have leaks if you used this.
  6. sherloc
    sherloc Been here awhile
    Jan 24, 2015
    234
    KCMO
    Looks great, what’s the project cost for a set in alloy and\or stainless?
    Thx!
  7. sherloc
    Jan 24, 2015
    234
    KCMO
    Will a center stand work with this skid plate?
  8. fastnlight
    Sep 25, 2007
    654
    Gig Harbor, WA
    sherloc and KevinMcCall like this.
  9. J.Mo
    Aug 13, 2018
    101
    Belgium
    Yeah used the exhaust sealant. But apparantly I didn't tighten the clamps strong enough the first time as the sealant escaped and splattered out of the connections.
    After tightening now it seems ok but I think there's maybe not many sealant left...
    Will keep an eye on it.
  10. Johnytuono
    Johnytuono Been here awhile
    Aug 17, 2017
    304
    Well I had a reply off SW Motech re the centre stand and they can only assure me that theirs will but they haven't tried the skid plate with the OEM centre stand.
  11. fastnlight
    Sep 25, 2007
    654
    Gig Harbor, WA
    Try finding the install instructions for the center stand you want, and compare those details. I would be happy to provide any detailed pics or other info needed from my end.
    Greg
    sherloc likes this.
  12. Johnytuono
    Aug 17, 2017
    304
    Thanks...I already have the OEM centre stand and SW Motech crash bars installed
  13. PLJ.
    PLJ. Adventurer
    Oct 15, 2017
    20
    Michigan
    I'm in agreement with the tire pressure change. Hard packed sand roads, loose gravel, etc. 25 psi in front, 30 psi in rear helped handling a ton.
  14. dereck74
    dereck74 Adventurer
    Jul 9, 2016
    71
    Regarding tire pressure, don't you find a bit strange that the specifications printed in the label indicate the same figure (2.8 if I recall correctly) for front and rear tire? Do you think that such figure could be correct for normal road use (I do not go off road)?
  15. J.Mo
    Aug 13, 2018
    101
    Belgium
    Same pressure? Itt says 2.0 front and 2.8 rear? That's quite a difference. More than I ever experienced on previous bikes
  16. dereck74
    dereck74 Adventurer
    Jul 9, 2016
    71
    You are right. I just checked and realised that I was wrong. I apologise for my mistake.
  17. jojojones
    jojojones Long timer
    Jul 21, 2016
    1,553
    Northeast
    Sorry I do not have the oem pegs around to compare. The knights are lower and did help my knees but when I swapped them they did not seem to be as low as Knight said.
  18. jojojones
    Jul 21, 2016
    1,553
    Northeast
    wow "Desert X"...will honda answer with something real??? 11/5 will be a big day for ADV bikes!
  19. sherloc
    Jan 24, 2015
    234
    KCMO
    Nice Render..
  20. TimmyTheHog
    TimmyTheHog Been here awhile
    Jan 11, 2017
    398
    Surrey BC Canada
    Well, Yamaha just came out T7, KTM has their 790, Suzuki is rumor to have a new DR Big and now Ducati has this Desert X.
    Even Moto Guzzi has their V85TT.
    Not to mention a rumored Triumph Tiger 900 as well.
    well, hopefully Honda will counter with a new 800/750CC AT or at least hint as the possibility.
    for now, this 19 CB500X is all they got for mid size off-reader
    2020 is going to be good with all these in the mix.
