2019 Electra glide standard
Discussion in 'Road Warriors' started by chickenhawk71, Mar 4, 2019.
  1. Jed Clampett
    Jed Clampett Long timer Supporter
    Nov 17, 2017
    1,149
    Mid Con
    Traxx and KneeDrachen like this.
  2. Traxx
    Traxx Taxation is Theft Supporter
    May 14, 2016
    3,627
    Tejas
    Well, got some saddle time today.
    Got to see some cool shit.
  3. relayer4u
    relayer4u Been here awhile
    Mar 26, 2018
    197
    Henderson, NV USA
    One problem with adding a stereo to the Police model is that they are not pre-wired for stereo like the EGS is. Biketronics has a solution for this and there may be other vendors as well.
    Having installed a single din Sony on my EGS before I traded up to the SG I know that adding the radio hand controls to an EGS and aftermarket radio install does allow for control of some functions. Look to Volunteer Audio, Biketronics or Fathead cycles for different levels of pre assembled kits.
    KneeDrachen likes this.
  4. Hammerdown77
    Hammerdown77 Long timer
    Apr 24, 2014
    2,752
    North Alabama
  5. TurkeyRun
    TurkeyRun Long timer Supporter
    Nov 25, 2012
    1,041
    Northern California, USA
    Hey @Traxx
    How’s the police saddle working out for ya?
    Traxx likes this.
  6. KneeDrachen
    KneeDrachen Long timer
    Jul 23, 2006
    2,715
    Northern Maryland
    @relayer4u , I saw fathead and biketronics; biketronics seems like a bit more comprehensive kit and I do not think the police model will allow for the double DIN head unit. I may consider the inner fairing from an FLHTK or something of the sort....
    Traxx likes this.
  7. Traxx
    May 14, 2016
    3,627
    Tejas
    For the 650ish mile ride it was great. Soaked up lots of bumps, and knocked the edge off the big hits as well. I put it on to try it out with the taller windscreen. I still find myself leaning with the stock handle bars. Short rides it is not a issue. With longer ones my wrists were not happy.
    While I was out yesterday, some tall boy handle bars arrived, so I will be looking at getting them installed over the next few days.
    What ever you do don't put your finger between the bump stop and the motorcycle frame to check to see if it is working when youre going down the road.
    If you're rocken stock bars and windscreen and want to stay that way, I would not recommend the police seat. If you're ready to change up the bike some then yes.
    Jed Clampett and TurkeyRun like this.
  8. Kevm
    Kevm Eternal Optimist
    Feb 18, 2018
    5,716
    Medford, NJ
    [QUOTE="Traxx, post: 40842226, member: 365968]
    [/QUOTE]
    I've totally done that!!!
    But I've got the preload pretty high!
    Traxx likes this.
  9. Traxx
    May 14, 2016
    3,627
    Tejas
    But I've got the preload pretty high![/QUOTE]
    How much you weigh with gear n all? How many threads do you preload yours. And when you look at it are you counting from the lock nut up or how?
    Right now I have the preload pretty light. I tip the scales at 240 geared up at 5'10". Not a light weight LOL
  10. Traxx
    May 14, 2016
    3,627
    Tejas
    Got some clean up to do today.
  11. Kevm
    Feb 18, 2018
    5,716
    Medford, NJ
    Damn close to you these days and I'll check the measurement tomorrow.
    Traxx likes this.
  12. ebbanflood
    ebbanflood Riff Raff Supporter
    Sep 26, 2010
    1,054
    Just north of Mediocrity
    I used Biketronics for my 2017 Police bike. They make up the harness and it is a plug and play install. The adapter plate is aluminum and a quality piece. The instructions are good and if there are any issues they will talk you through it over the phone. Great company to deal with.
  13. Kevm
    Feb 18, 2018
    5,716
    Medford, NJ
    The top of the locknut is about 8 mm below the top/start of the threads.
    Traxx likes this.
  14. Big John Sny
    Big John Sny Long timer
    Jul 3, 2009
    2,478
    Irving, Tx
    Traxx likes this.
  15. Traxx
    May 14, 2016
    3,627
    Tejas
    Just came inside from mounting up the Tall Boy handlebars. I'll get some pictures after I clean up the bike a little and a quick ride to test. something to note, the handle bar risers do not match up with the notches in the fairing. Just a little wide. I also didn't have to use a wiring harness extension. Which means that I need to cancel that order.
  16. Traxx
    May 14, 2016
    3,627
    Tejas
    Installed a little screen in the fairing vent. Maybe this will keep that last little bit of bug guts getting through the little vent.
    StittWall and KneeDrachen like this.
  17. Traxx
    May 14, 2016
    3,627
    Tejas
    Oh and full disclosure it is a Custom Dynamics piece. Took like 5 min to install.
  18. Hammerdown77
    Apr 24, 2014
    2,752
    North Alabama
    The Tallboy bars required different risers? Is the clamp diameter different or something? I thought the Tallboy bars, at least the ones I looked at for the Road King, were 1" diameter. Maybe there's a difference for the fairing bikes.
    Traxx likes this.
  19. Traxx
    May 14, 2016
    3,627
    Tejas
    Sorry, I guess risers is the wrong word. Where the bar bends from the horizontal plane up is a touch wider is what I meant by riser.
  20. Hammerdown77
    Apr 24, 2014
    2,752
    North Alabama
    Oh, yeah, now I'm with ya
    Traxx likes this.
