2019 Electra glide standard
Discussion in 'Road Warriors' started by chickenhawk71, Mar 4, 2019.
  1. villageidiot
    villageidiot Long timer Supporter
    Apr 29, 2010
    16,764
    Orange County, CA
    So, apparently there’s no removable passenger backrest that works with the OEM FIXED RACK/TOUR PACK MOUNT.
    I went and bought a detachable rack/backrest, docking hardware, and I’m not happy with it for myself. The backrest is fine, I’ll work with it, but I don’t like the rack.
    so.
    just cuz HD can’t make it work, doesn’t mean I can’t.
    back on with the OEM fixed mount, only I took off the plastic chrome trims.
    the backrest will still slot onto the shock bosses, I removed the latches, and it’ll fit over the OEM rack.
    I’ll have to make a couple small plates and a spacer, but I think I can get it to be a semi quick release...... 2 easy bolts is quick enough for me.
    Plates will bolt in thru the old trim holes
    spacer should sit in where my finger is pointing, and should just have to thread the bolt into the spacer
    Traxx and JRowland like this.
  2. Kevm
    Kevm Eternal Optimist
    Feb 18, 2018
    5,815
    Medford, NJ
    That's why I went with a topcase (with built-in backrest). Two birds, one stone.
    Traxx likes this.
  3. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    yeah, except I don’t want a top case
    Oilhed, Kevm and Traxx like this.
  4. Traxx
    Traxx Long timer Supporter
    May 14, 2016
    3,644
    Somewhere
    Mr. Id10T, is there a reason to stick with the hard mount rack? Better load capabilities? Just like the way it looks? Simplicity? Looks like a QD set up would be more versatile. Granted it is not the end all be all, I am still trying to find a solo QD back rest. Well I did find one but it pretty funky.
    I need to see if I can find that back rest that bolts onto the police seat frame.
  5. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    I just like it better. i like the cast aluminum, I like the simplicity, and I always have a rack on the bike. The only thing I want to add or detract is the backrest for the ol lady the 6 times a year she might wanna go for a cruise.
    I don’t like the movement in the QD rack. Brackets on brackets on brackets never really appealed to me. Especially when you can’t just tighten a bolt and call it good. The QD hardware all has a little movement in it by design and I’m just not feelin it.
    also, you can call me mr idiot, or VI, or dumbass...... anything but late for a meal
  6. Traxx
    May 14, 2016
    3,644
    Somewhere
    LOL, it was Id ten t that I typed but didn’t come out quit right. No fence ment just fun.
    JRowland, Kevm and villageidiot like this.
  7. Hammerdown77
    Hammerdown77 Long timer
    Apr 24, 2014
    2,764
    North Alabama
    Traxx likes this.
  8. Traxx
    May 14, 2016
    3,644
    Somewhere
    Okay, I had one of their backrest on my trophy se.
    villageidiot likes this.
  9. ebbanflood
    ebbanflood Riff Raff Supporter
    Sep 26, 2010
    1,059
    Just north of Mediocrity
    I wanted to take this rack off but I immediately found out that it protects my license plate, my plate is very camera shy. The plate is still fully visible at street level. Hopefully you live where this is not an issue.
    Cogswell, MiltonHog, JRowland and 3 others like this.
  10. Kevm
    Feb 18, 2018
    5,815
    Medford, NJ
    If your license plate still feels exposed or threatened, tell it that adding a removable topcase will give it even MORE protection.
    rauchman, MariusD, MiltonHog and 3 others like this.
  11. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    my license light is below the tail light, but I’d rather the rear light bar like on @Kevm roadking, and the plate on the rack. Might have to make that switcheroo, I have a new old style lens with the clear on top from my dyna I never put on. Would just have to get the light bar
    ebbanflood, Kevm and Traxx like this.
  12. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    The following post is pic heavy and rather meaningless to most.
    Today was the day......
    made a plate to bolt to the rack, 2 bolts thru the front 2 trim holes.
    whipped up a little "spool" for the backrest to rest against, drilled and tapped the plate to take the spool.
    slid the rack on, rests up there like so.
    wasn't sure how i was gonna hold it on, but i thought about it, and used the holes i knocked the poem latch pivots out of. so i spun up another spool, and knocked a flat spot in it.
    bolted that into place after drilling and tapping the appropriate hole.
    once i knew i all fit and i tested it on both sides, i laid out a par of them, drilled, and tapped the holes, etc
    cut em out on my buddies bandsaw, didnt feel like cutting em by hand with a hacksaw.
    got to work with a file, and some sandpaper, made em match, are they perfect, nope, but they match, and they fit.
    bolted up a spool for good measure.
    8761585C-7788-4DAC-BDAE-09D67E227FF7.jpeg B7FD3097-60B1-4EBB-83AF-5C1E926E61BC.jpeg
    and this is how it'll fit on the rack, quite minimal really. E1882B5B-F56A-4FD7-A93E-B6A77B185D37.jpeg
    still need to buy the correct hardware, lock washers etc, gonna use button head cap screws, and countersunk allen heads, i just mocked it up with what i had on hand at work.
  13. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    Tumbled the aluminum pieces in the vibratory tumbler. Got em installed today.
    Fit up right nice. And when the backrest is off it makes for a good lashing point.
    6A28868D-ACF8-49F8-A5DB-6488D87DD27B.jpeg D16D2149-019E-4747-ACFE-3CD2A743135E.jpeg 05656D87-0A0D-4E28-A521-E07E5F8C30C7.jpeg 0AFFB4D8-7E11-41A3-B142-90C24F2DF29A.jpeg
    pardon the dusty bike. The winds have been crazy here this week
  14. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    My “freedom shields” windscreen came in on Monday. 8” medium tint, standard width.
    I had to take the truck in Tuesday as the detailer comes tuesdays... (wash it from the 1000 mile Friday last week)
    anyways, rode it in today, installed it this morning. No freeways on the way home as they’re a huge parking lot, but so far up to 60 or so on side roads it’s a huge improvement.
    10” would probably get me there, but I prefer the aesthetic of the 8” screen.
    A6FDA48F-B7C8-4FFE-9069-7938E3C2D880.jpeg 3CB511F8-9037-4C95-B2E1-4082126EC5BC.jpeg
    still has the plastic wrap til i complete the test ride back in tomorrow, at that point I can decide to keep it, or opt for a different height, etc
    Traxx, Kawidad, Cogswell and 3 others like this.
  15. jersey jim
    jersey jim Long timer
    Oct 6, 2008
    2,297
    ...somewhere in the swamps of Jersey...
    I'm thinking of getting a shield from Freedom Shields, they get great reviews. I'd like an inch or two shorter than my stock 12" screen I think, been playing with painters tape on the shield to see which way I want to go. For some reason after 7 years the stock screen has started to really annoy me, especially at night, being right at the bottom of my normal line of sight. Leaning towards a 10" screen right now.
    Traxx, dceggert and villageidiot like this.
  16. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    8” isn’t gonna work for me. Getting a fair amount of buffeting to the top of the helmet. Going to try a 10”
    I am very long torso, so YMMV and all that.
    Traxx and dceggert like this.
  17. Huladog
    Huladog Been here awhile Supporter
    Jul 16, 2008
    219
    in the middle of the ocean
    You might want to try fork mounted wind deflectors that attach to the lower legs. Google an image and I bet you could whip up a set. Helped when I had a Street Glide but was a bit too shiny so I sprayed them flat black to be a little more stealthy.
    Aloha!
    Traxx and villageidiot like this.
  18. villageidiot
    Apr 29, 2010
    16,764
    Orange County, CA
    but they’re so not good lookin.
    the “fangs” I get the function, I just can’t get past the visual.
    might also try the bottom triple wind deflector.
    one change at a time
    Traxx likes this.
  19. Kevm
    Feb 18, 2018
    5,815
    Medford, NJ
    I agree(d) with you.... till I installed some.
    I was surprised how much they disappear.
    I just don't see them anymore.
    * Shrugs *
  20. Oilhed
    Oilhed MarkF Supporter
    Oct 17, 2003
    17,043
    Connecticut
    mine are still in the box so
    I’ll repost this picture
    Traxx likes this.
