+2019 GPX FSE250E Air Cooled Modern MX Mountain Goat
Discussion in 'Thumpers' started by Navin, Feb 5, 2019.
  1. bark sampler
    bark sampler Been here awhile
    Mar 30, 2008
    403
    Middle of Michigan
    I’m using a CRF 230 lever. It’s 4” long center to center. It fits the shaft nicely but takes a little tweaking to clear the cases.
    I ground out the back to make it softer with these reports of bent shafts. Stock, it’s a little stiffer than I’d like. EDC63020-FD85-4061-9DFA-D3A4D333C82A.jpeg EB4D71D8-8FA4-4E6E-A2D8-7C21946FB0CC.jpeg
    Bitingdog likes this.
  2. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    Props to Navin for hooking me up with a shorter shifter. A little closer to the engine but works fine. Good option for normal size feet.
    Navin and BUNK657 like this.
  3. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    Awesome! It wasn't good for my feet on the older E but if anyone else wants to find it, here is the Ebay listing.
    Bitingdog and Fallacy like this.
  4. Bt10
    Bt10 Long timer
    Dec 18, 2012
    1,909
    Saranac,MI
    Was this bike getting fuel injection this year, and 6 speed? And across to the "S" small wheel bike? Thanks for any info.
  5. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    Carbs for now and the S is still the "old" E 5 speed as I understand it. The E has a 6.
    Fallacy and Bt10 like this.
  6. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    Navin likes this.
  7. GaryPismoBeach
    GaryPismoBeach Tragically Hilarious
    Sep 21, 2014
    14
    Pismo Beach CA
    Has anyone used and have feedback on the 4 degree offset flywheel key to advance the timing?
    bark sampler likes this.
  8. Cascade Adventurer
    Cascade Adventurer All the gear, no skill
    May 14, 2017
    56
    Seattle
    Recently installed the 4 degree key on my first gen 250E. This has helped with low end grunt and I can more easily lift the front wheel. I would do this mod again. To date the best improvement for low end grunt was setting the mixture/jetting correctly and this 4 degree key from Joe Kenner has further improved grunt.
    Navin and bark sampler like this.
  9. GaryPismoBeach
    Sep 21, 2014
    14
    Pismo Beach CA
    From your July 9 th post, are you still running the 45 pilot and 130 main? Have you played with the needle?
  10. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    Aceribix X-factory handguards were an easy fit. Only had drill out handlebar ends to 5/8.
    On a side note, one of the threaded holes in my front hub came stripped from the factory. Not sure best way to fix?
  11. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    Did you run a tap thru it? Id contact GPX for that but if you wanted to avoid shipping and waiting a timesert/helicoil is a permanent and better thread than bare aluminum threads.
    Fallacy likes this.
  12. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    Bolt slides in and out of hole. Definitely not wanting to ship anything back - will try helicoil pending Gary's response. Thanks
    Navin likes this.
  13. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    I happen to be eating lunch next to my E so I gave it a look... you can probably slip a nut on the other side and use a longer 6mm bolt to get by for now. The KTM hubs used to be that way in the older days.
    Fallacy likes this.
  14. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    That worked but had to go with smaller dia hdwr due to spoke interference. May leave it this way rather than risk weakening the hub with a drilling larger hole for helicoil?
    59F15E4B-56B2-4BEB-99A0-871E4EA9D612.jpeg CE3C1791-BF88-49D2-B78D-8FC7A23D3DA1.jpeg
  15. Navin
    Navin Long timer
    Sep 22, 2009
    29,405
    Id call that a temp fix, (though Im sure its fine). I think a thread sert would be better than new but see what Gary has to say if its a brand new bike. I guess the wheel guy in the plant got a bit over zealous with an impact driver. :lol3
    Fallacy likes this.
  16. Cascade Adventurer
    May 14, 2017
    56
    Seattle
    Yes. Keep in mind that my first gen 250E has the Keihin style carb and I've heard that newer 250E's are using a different carb so my mixture settings may not work on a different carb. Since making this jetting change I've been operating from sea level to 5000 feet elevation but mostly 2000' - 4000' and the plug is clean although slightly darker than before. I have not changed the needle height or anything else about the needle - maybe there's some additional tuning opportunity with this. My goal is better low end grunt.
    Navin likes this.
  17. GaryPismoBeach
    Sep 21, 2014
    14
    Pismo Beach CA
    I have the first generation as well. I will try the larger jets. And the 4 degree flywheel key. Thanks!
    Navin likes this.
  18. ChiefOshkosh
    ChiefOshkosh Been here awhile
    Dec 3, 2015
    152
    Oshkosh, WI
    Shift lever replacement -- 2019 Gen1 FSEe -- works/fits perfect!
    Tusk Folding Shift Lever Black/Red Tip
    Fits: 2012 HONDA CRF230F
    Part# 1030850097
  19. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    58 miles of mostly sand trails in Ocala and the bike did great.
    nuggets, crackerguy and Navin like this.
  20. carlk
    carlk Adventurer
    Apr 22, 2019
    18
    Florida
    Yikes - found sound in the airbox after my last ride. Air filter boot doesn't sit flat due to a mold defect which likely left a gap in the boot to cage mating surface. Compression reads between 145 - 160 psi. Some cylinder scoring. Oil gray but no sand found. Okay to run as is?
