2019+ ktm 690 enduro
Discussion in 'Thumpers' started by azur, Sep 24, 2018.
  1. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    3,829
    Los Angeles, CA
    Escorcio, ErGuss, mokhtario and 2 others like this.
  2. JPA
    JPA Been here awhile
    Jul 11, 2016
    352
    Finland
    I have oem SMC-R wheels on my 2019 and the rear is 5".
    oldfuddy likes this.
  3. stephlal
    stephlal Adventurer
    Aug 21, 2020
    67
    Oh Canada Eh
    I use flatland racing rad guard, it's great.
    smackyface likes this.
  4. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,665
    SouthWest (AZ)
    Yeah, I might go with 5”. The 4.25” would be a little stronger, but I doubt I’ll do any off road while in a SM set up.
  5. rsl47m
    rsl47m Been here awhile Supporter
    May 23, 2008
    485
    Kansas City
    What tires you thinking?
  6. oldfuddy
    oldfuddy Long timer
    Aug 28, 2013
    5,665
    SouthWest (AZ)
    Haven’t got that far yet.... I ran Trail Attacks on my 950’s (19/17 set up) and was happy enough when on dirt roads and they did ok on slab. There’s a new trail attack 3 out but I don’t like the tread pattern. Since I’ll be on 17’s front and rear there’s lots to choose from...
  7. grace
    grace Long timer Supporter
    Aug 22, 2006
    1,793
    denver co usa
    if you're thinking about conti trail attacks, i highly recommend that you consider the avon trailriders. i cannot imagine in what situation the the trail attacks would outperform the avon. i've run both and, for how i ride, it's no contest. the trail attack is a very good tire -very good. i think trailriders are excellent and work better in the dirt.
    i will say that what i really love about the avon is that they're so sticky and predictable. mileage is really not a consideration for me. i'm happy with 3-4k miles from any tire. i'll probably get 5-6k. maybe. maybe not. i suspect that some riders will achieve 10k from the avons.
  8. rsl47m
    May 23, 2008
    485
    Kansas City
    Do you feel you could do a track day on 17's front and rear with the Avons? Are they good enough and safe enough for a road course track day? Or squirley when leaned over?
  9. grace
    Aug 22, 2006
    1,793
    denver co usa
    i run the avon trailriders on the 690 super moto with 17's front/rear. yes, they're safe and good enough for road/track course. i also run these on my bmw r1200gs street wheels. these tires have ridiculous grip. i can run them at max lean angles and them some. they stick and break loose predictably. great feedback. for these bikes, i've stopped searching for something better. i've even considered running these on the super duke.
    here are a few reviews from revzilla specifically commenting about track use. i wholeheartedly concur with the reviews. as good as they work on the pavement, they also work pretty damn well in the dirt.
    Screenshot from 2021-10-17 21-38-47.png Screenshot from 2021-10-17 21-37-53.png Screenshot from 2021-10-17 21-35-43.png
    oldfuddy and rsl47m like this.
  10. spartanman
    spartanman regret minimizer
    Oct 17, 2009
    2,664
    Land of High Hopes & Low Taxes
    Avon Trailriders are my favorite of all street biased dual sport tires on my 1150 GSA. Better grip than Conti TAs and they wear more evenly. I’ve never had them slip out on road ever, wet or dry, and they work remarkably well on gravel and dirt. They’re also the quietest of all the tires I’ve run on this bike and wear well for how good they grip.
    oldfuddy and grace like this.
  11. The Cone of Silence
    The Cone of Silence Been here awhile
    Jan 16, 2006
    491
    Kurrajong, New South Wales, Australia
    Righto hoping this is a quick one for you legends...the TC/ ABS embuggerance has reared its head above the parapet.
    2021 690 Enduro R Euro5 model.
    Switch key to 'on' position and the ride mode is in 1 but the ABS and TC lights are automatically on, suggesting both are disabled. I think the ABS light should switch off when I start moving (will test later today) but I can't seem to be able to switch the TC mode to 'enabled' i.e. light off.
    I did try to turn them both off with many attempts at counting to 5 quickly, slowly, precisely and releasing but to no avail. Anyone experienced this before? Is it just a case of having to ride the bike a few metres and then trying again? I tried starting the engine to see if it would be different but the behaviour was the same - I can't change the TC setting from off to on.
    N.B. the 2021 Euro5 model remembers the setting when the bike is switched off and on again - no dongle is needed. I've installed a PCV and in-line AVDV dongle for the exhaust O2 sensor but neither of those should impact the ABS and TC and I'm finding it weird that TC is defaulting to 'Off' with light on when on its last journey the bike finished up being put away in normal mode i.e. ride map 1, TC on, ABS on.
  12. AllSeasonRider
    Feb 20, 2008
    3,829
    Los Angeles, CA
    Both ABS and TC are disabled until the bike rolls forward a short distance.
    I don't know if the Euro5 model changes how you disable TC, but on my '19 you do need to roll the bike forward a bit until the light goes out (enabled), then press and hold for ~5 seconds, then release. Light will be on at that point (disabled). You can do this while still moving, from memory. Repeat the steps to turn the light off again (enabled).
    Likewise, the ABS light won't go out until you moved a short distance - this is true of any ABS-equipped bike I can think of.
    The Cone of Silence likes this.
  13. The Cone of Silence
    Jan 16, 2006
    491
    Oh man that's good to hear. I've only ridden this bike once and changed about 40 things on it so I was worried about this. Will test later today, thanks mate. I knew it wouldn't take you blokes long!
    AllSeasonRider likes this.
  14. blalor
    blalor Long timer Supporter
    Sep 13, 2015
    1,004
    RVA
  15. zoomdude57
    zoomdude57 Been here awhile
    Mar 14, 2004
    771
    Seattle, WA.
  16. AbnormalWrench
    AbnormalWrench Adventurer
    Jul 14, 2021
    38
    seattle
    It will be interesting to see how they handle this, but in the automotive world, they would be forced to pay for it. I'm not sure if safety recalls work the same way with motorcycles. They definitely should.
  17. AllSeasonRider
    Feb 20, 2008
    3,829
    Los Angeles, CA
    JoeMongo and AbnormalWrench like this.
  18. grace
    Aug 22, 2006
    1,793
    denver co usa
  19. zoomdude57
    Mar 14, 2004
    771
    Seattle, WA.
    I believe an all new design on the 2021 so you should be OK.
    rsteiger and grace like this.
  20. dolphins13
    dolphins13 orange rules
    Jan 7, 2012
    391
    spo wa
