2019+ ktm 690 enduro
Discussion in 'Thumpers' started by azur, Sep 24, 2018.
  1. AllSeasonRider
    AllSeasonRider Wandering, maybe a little lost...
    Feb 20, 2008
    3,820
    Los Angeles, CA
    @Trailryder42 - I've been thinking about a Rekluse and LHRB, so thanks for pushing me closer to the cliff of spending that money :lol3
    Seems like the Rade tanks have come with 2 or 3 different caps. Mine is black plastic and it definitely vents outward - after some hard riding, even in cold temp, when I stop you can hear it hissing. Open the cap and you get a whoosh and it stops, cap back on and slowly starts hissing again. Can't say I've ever heard or felt the fuel actually boiling, but it is putting out a lot of vapor. I'm only using the included-stick on reflective sheet.
    I recall people buying heat blankets for their Buell's to keep them from cooking their legs and ass... I've found some info, but the company that sold them looks to be long gone and I can't figure out what the material is, but maybe you'll recognize it. It was a guy named Odie and company called Special Ops http://www.badweatherbikers.com/buell/messages/142838/342016.html?1204333358
  2. Trailryder42
    Trailryder42 Long timer
    Oct 3, 2006
    1,788
    Amarillo, Texas
    Mine hisses too, but it's an inward draw as the rear tank uses fuel and transfers fuel from the front. You can take the little vent valve thingy off and try blowing and sucking thru it with your mouth. Mine, you can suck air but not blow thru it the other way. The ball valve freely moves, so it's not that. It's the design of the valve.
    Found some stuff called Thermal Block I'm going to try for covering the Rade tank.
    https://www.amazon.com/Second-Skin-...ive+heat+blankets&qid=1634935223&sr=8-34&th=1
  3. ErGuss
    ErGuss Adventurer
    Oct 9, 2011
    89
    My friends Sherco have a valve that can open both ways but it stops the gas from spilling when in a tumble. It blocked and wouldn't let out..
  4. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
    That would be ideal, a valve that lets air pass both ways but fuel only one way.
    I had a similar check valve to the one that came with the Rade tank (going to save it) and it is the same type valve, one way only. I drilled a very small hole in the top of it so positive pressure could be vented. Ran a length of vent line from the cap down along another stock vent line for something, zip-tied to the right radiator so it drains below the radiator. Then zip-tied a piece of old air filter foam around the vent valve to act as a filter for when the Rade tank is drawing a vacuum.
    If I have another boiling episode, the tank will be able to blow that pressure off now. We'll see how well it works in time. Fuel Cap Vent.jpg
    ErGuss likes this.
  5. smackyface
    smackyface Boldly going wherever Supporter
    Nov 3, 2020
    298
    Albuquerque, NM
    The stock vent line you mentioned behind the radiator would be the coolant overflow. I’m not sure if you teed into it, but if so, I imagine you’d want to change to a separate line.
  6. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
    No T-in, just ran it beside that line and terminated it at the same place.
    smackyface likes this.
  7. ErGuss
    ErGuss Adventurer
    Oct 9, 2011
    89
    I thought so too. He said it was broken because it wouldn't vent. I Googled for it but can only find one way valves... Will have to ask him before spreading misinformation
    Trailryder42 likes this.
  8. AllSeasonRider
    Feb 20, 2008
    3,820
    Los Angeles, CA
    I just double checked mine and there is a ball in there (I thought it was a rubber flap for some reason). Air can go in no problem, and I can blow out slowly. Blow too hard and ball moves up and blocks it. Sure seems like a 2-way valve that will plug up in a tip over - it's been on its side more than once and I don't recall any fuel spilling, so it must work :lol3. I suppose if it's boiling and trying to vent pretty aggressively like you describe, it might block it entirely.
    ErGuss likes this.
  9. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
    It may seal in a tip over to prevent fuel from passing. Don't know as I haven't tested that.
    Apparently, mine doesn't take much positive pressure to seal off. I had fuel making it's way past the vent hoses seal with the fuel caps nipple. Had to slowly unscrew the cap to let it bleed off in a controlled manner. Don't like the idea of escaping fuel under pressure dripping down onto a hot engine. That's a recipe for a fire. I'd rather loose a little fuel in a tip over.
    I had my phone with me, don't know why I didn't think to get a video.
    ErGuss likes this.
  10. ErGuss
    ErGuss Adventurer
    Oct 9, 2011
    89
    Look at about 0:30. :eekers
    mokhtario and Trailryder42 like this.
  11. Barak
    Barak adventure photographer
    Apr 28, 2006
    289
    Albuquerque, NM
    Need advice - Front brake squishy after bike sitting unused...
    I have a 2019 with around 12K miles. ABS dongle, so front abs by default always on, rear always off.
    About half a year ago for the first time I experienced a squishy front brake after the bike sat for around a month.
    I bled the front brake and it was better, but following that on a ride involving long slow steep downhill descents it almost felt like like the ABS was kicking in under non abrupt, mild braking and the lever felt soft/squishy again to the point it was feeling dangerous. Switched the ABS off and didn't seem to improve.
    After that ride, I replaced the brake fluid, and bled the system, and checked for any leaks at the brake reservoir and checked the ABS system as well and it all looked dry. Brakes felt good for the next similar ride with long downhills so I thought it had resolved itself with the bleeding.
    But today, same thing, bike has been sitting for a couple of months and the brake is so soft I can press it all the way to the grip. The system is dry, no leaks.
    Anyone experienced this? Any suggestions?
    Thanks,
    Barak
  12. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
    Not with my 690, but I have had it happen with my 1090 after it having sat thru this last winter.
    Rather than immediately break open the system (bleed nipples), I compress the calipers with my foot to push the fluid out of them and up to the reservoir (with the top off). Have some catch rags in place. Then suck out the reservoir fluid, keeping just enough to prevent the port from becoming uncovered and top off with new fluid. Install the cover and pump the brakes up. Repeat compressing the caliper a few more times and pumping back up.
    This has worked well and I didn't need to break open the system and deal with the possibility of introducing air into the system that I would then need to deal with.
    ErGuss likes this.
  13. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
    The exact reason why I don't run these stubby one way valve things on any of my dirt bikes. I was amazed/disappointed with that part of the Rade kit. I figured I'd be coming up with another solution in short order.
    ErGuss likes this.
  14. Zuber
    Zuber Zoob
    Sep 28, 2004
    8,353
    West of the West, Oregon
    This happens. Check the master cylinder cap. There's a tiny slot around the edge that lets air behind the cover's diaphram. The gasket will close off this slot over time, or if over tightened. When this happens, any atmospheric change will effect the brakes. Take a very sharp razor and trim the gasket to remove the bump.
    Also, try 'back bleeding'. Get a big screwdriver and pry back the brake pads. Do it fast. Then pump them back out slowly. Pump, release, pause. This helps brakes keep the air out.
    Hauling your bike over the mountains can cause this. Small amounts of air can settle out and cause it. It really helps to pressurize the system for a few days before you bleed it. Press the brake lever, wrap a bungie around the lever and let it set for a few days. Then bleed it. This will push small air bubbles into the fluid and make it much easier to bleed them out.
  15. Trailryder42
    Oct 3, 2006
    1,788
    Amarillo, Texas
  16. AllSeasonRider
    Feb 20, 2008
    3,820
    Los Angeles, CA
    I've had the same thing happen. Bled the system and it's been fine since. I'll have to take a look and try what @Zuber has suggested regarding the cap.
    You will feel a little vibration at the lever if the ABS is activating, but it should not have any impact on the prevailing feeling of firmness or squishy-ness of the lever.
  17. Barak
    Apr 28, 2006
    289
    Albuquerque, NM
    Yeah, I know how ABS feels when it activates and been riding long enough to know that this was not normal. That's why I'm afraid bleeding might not ut it but the recommendations in response to my post are new techniques to me so I'm excited to try them out! Thanks
  18. Barak
    Apr 28, 2006
    289
    Albuquerque, NM
    Thank you! I will try this out.
    Barak
  19. Barak
    Apr 28, 2006
    289
    Albuquerque, NM
    Thanks Zuber. I'll take a look at that gasket and try these methods out.
    Definitely huge elevation changes from riding the SW Colorado mountains this last summer...
    Such a great forum - what a gift
    Barak
  20. JoniBarTeam
    JoniBarTeam Been here awhile
    Dec 18, 2013
    177
    Melbourne
