    Dismiss Notice
2019 Scorpa 300 Factory leaking Fuel
Discussion in 'Trials' started by Ozzbear, Jun 9, 2020.
  1. Ozzbear
    Ozzbear 113T Supporter
    Jun 8, 2008
    84
    Utah
    Just throwing this out is anyone else still have a fuel leak on your New Scorpa? I have had this about 2 weeks , I bought it as a Demo but really its New. I really wanted a trials Bike as Im new to this type of riding not a Roman candle.
    edgerat likes this.
  2. y4m4
    y4m4 Calvin
    May 24, 2009
    572
    Federal Heights, CO
    New? I thought that was sorted a couple years back.
  3. Norman Foley
    Norman Foley Devotee of the Husqvarna Supporter
    Mar 20, 2004
    4,505
    New York... The Finger Lakes
    I switched to a Jitsie aftermarket fuel tap, when my new '18 Scorpa 125 Factory leaked 2 years ago. That solved the problem for me.
    I would speak to the dealer you bought it from first. If they are no help, call Mike Komer at the Tryals Shop. He's sorted a few of these.
    fprintf likes this.
  4. Ozzbear
    Jun 8, 2008
    84
    Utah
    Really wow I had No Idea Im looking for fix not a smart ass
  5. Ozzbear
    Jun 8, 2008
    84
    Utah
    Thank You
  6. Thesolidman1
    Thesolidman1 Been here awhile
    Dec 15, 2011
    119
    Nor Cal
    Mine started leaking on my 2019. The fuel tank gets spongy where the petcock mounts. A thicker o-ring fixed it, no longer an issue. At least for now.
    Norman Foley likes this.
  7. y4m4
    y4m4 Calvin
    May 24, 2009
    572
    Federal Heights, CO
    Chill out.
    I was genuinely curious that this was still an issue. This was a known issue on the early ones.
    Good luck.
    VxZeroKnots likes this.
  8. Boom Boom
    Boom Boom Been here awhile
    Oct 10, 2006
    571
    Central PA
    Different O-ring seemed to patch the problem. Just my $.02 but seems those that run pump gas with ethanol seemed to have more issues (tank opening would warp) vs those that ran non ethanol based fuels.
    #8
  9. Yinzer Moto
    Yinzer Moto Sloppy 300 rider Supporter
    Jun 13, 2008
    39,243
    Pittsburgh PA
    These will fix the problem
    #9
  10. 75' Forty
    75' Forty Been here awhile
    Apr 26, 2016
    117
    Grand Haven, MI
    Might have missed it, but where is it leaking fuel from?
    #10
  11. Norman Foley
    Mar 20, 2004
    4,505
    I've run Avgas 100LL from new, so maybe that's why I have less of a problem?
    #11
    Huzband likes this.
  12. Norman Foley
    Mar 20, 2004
    4,505
    Where fuel tap attaches to the tank.
    #12
  13. Yinzer Moto
    Jun 13, 2008
    39,243
    Pittsburgh PA
    The tanks warp and a fatter oring is required
    #13
  14. 75' Forty
    Apr 26, 2016
    117
    Grand Haven, MI
    Gotchya. Never saw the OP say location so wanted to ask.
    #14
  15. DyrWolf
    DyrWolf Long timer Supporter
    Jan 21, 2012
    2,959
    RICHMOND VA
    Just curious some NE guys seem to have a easy fix SW guys more trouble Maybe not fuel but ambient temp related?
    #15
  16. Yinzer Moto
    Jun 13, 2008
    39,243
    Pittsburgh PA
    I spend a month or two in NM every year. Nothing seems to change with the tank. As @Boom Boom mentioned, ethanol might play a part.
    #16
    Brewtus, Norman Foley and DyrWolf like this.
  17. 2whlrcr
    2whlrcr gooligan
    Jan 30, 2005
    15,972
    Dubuque, Iowa
    Gordy may not let you in the state, next time you try go there.
    #17
    10K likes this.
  18. Boom Boom
    Oct 10, 2006
    571
    Central PA
    The leak started from new but only leaked when fuel was turned to on position as the hydro line was putting pressure on the fuel lever and making the undersized o-ring leak. I found some slack in the hydro line and pulled up out of the way of the fuel lever and installed a larger o-ring. IMHO the plastic thickness is just to thin at this location and the thicker o-rings just keep flexing it more require a thicker o-ring. Nephews 17 Sherco also leaked so moved the hydro line and stopped the leaking. Overall the Sherco / Scorpa is a fine product...just know you will have some fit and finish details to fiddle with.
    #18
    Yinzer Moto likes this.
  19. Gordy
    Gordy SUPPORTER
    Dec 30, 2001
    32,580
    NM
    Like a moth to a flame I am. :rofl
    My POS Scorpa tank was leaking when we uncreated it and set it up, so yes, ethanol could make the problem worse but is not the root cause.
    The fuel tank is obviously made in some kids backyard plastic injection mold kit. The quality control or the mold is crap.
    The problem is right where the petcock mates to the tank, the plastic is super thin and WILL warp when the two bolts that hold it in press it tight against the gasket or o-ring. The surface is thin, wavy, flat, etc. Not at all what anyone in their right mind would create to form a gasket seal surface. Some guys have apparently had luck with using a larger o-ring but on some, the gap is just ridiculous and a new tank (which could be the same) is required.
    It’s a known defect that the team riders all suffered through at a NM national and that the importer doesn’t want to deal with. They actually tried to SELL me a thicker gasket when approached about it by my dealer!!!! WTF?
    If you compare with the Sherco tank, there is a nice thick boss area where the petcock mounts and the threaded nuts are embedded. Obviously, Scorpa is sourcing tanks from a different manufacturer.
    I personally am not going to support or recommend a $9K bike that entire management chain knows has this defect but will not back-up or even acknowledge the problem.
    Is the bike really that superior (in what ways?) to purposely buy knowing that it has a good chance of having a leaky tank and/or fixing it for them after the sale? That, IMO is just :loco
    There are several options out there that don’t come with this gremlin. If the bike “fits” why not just go blue and give Sherco your money? You can still drain the tranny oil out of a case bolt. :imaposer
    There. Now can we talk about Beta clutches?
    #19
  20. Norman Foley
    Mar 20, 2004
    4,505
    I still say dog with a bone!
    still
    #20
    Junglejeff1, Brewtus and 10K like this.
