2020 Florida -> Alaska Again
Discussion in 'Americas' started by gpax, Jul 12, 2018.
  1. gpax
    gpax Honda NC750XD Yamaha XT250 Kawasaki VN-1700
    Aug 12, 2016
    1,372
    Pensacola, FL
    2018 Honda NC750XD ... So I buy a plug and play Denali Mini Soundblaster horn. Only problem is it blows the fuse. Not just the fuse to the horn but the fuse to nearly half of the bike including display. The dealer says the Denali draws too much current for the 7.5amp fuse? Also, I was looking at installing an accessory 12v plug and it takes a special sub-harness as well as special harness plug on the 12v socket. Now I need to install a battery tender plug to keep the battery charged in the garage. What kind of electrical system have I gotten myself into? Can I install the battery tender cable directly to the battery?
    Rapturee2 likes this.
  2. Tewster2
    Tewster2 Long timer Supporter
    Jun 17, 2011
    7,859
    DeLand Flatistan
    Wiring a battery tender cable is just like hooking up jumper cables...just connect the battery tender pigtail to the battery...I've done that to all my bikes...works perfect.
    EZMoney and Rapturee2 like this.
  3. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    631
    SE Michigan
    ^^^ This
    The battery tender cable usually has an in-line fuse so it is designed to connect directly to the battery. Typical cables have 7.5 Amp fuses. I have seen heavy duty tender cables that are rated for 15 Amp fuse.
    JT
  4. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
    An update photo:
    Taff1, bobw, Rapturee2 and 4 others like this.
  5. JagLite
    JagLite Long timer Supporter
    Jun 17, 2010
    9,967
    Anchorage Alaska
    Looks fantastic! :clap
    The skid plate, engine guard bars, wind screen, and seat are excellent for a ride to Alaska... and around the world. :thumb
  6. oldgrizz
    oldgrizz Long timer
    Nov 22, 2016
    3,235
    It sure looks pretty.
    I will have to stay at least a half mile behind you on my old FJR.
    Mine isn't pretty enough to ride beside yours.
    gpax and JagLite like this.
  7. JT105
    JT105 Let's Ride!
    Jun 24, 2014
    631
    SE Michigan
    Looking great.
    I have a skid plate on my Christmas list. Not holding my breath, but who knows.
    When are you mounting those Tusk panniers? Sure would like to see a pic.
    JT
    gpax likes this.
  8. Tewster2
    Jun 17, 2011
    7,859
    DeLand Flatistan
    You changing the rear spring?
  9. Rapturee2
    Rapturee2 Ride often, Pray Hard. Supporter
    Mar 24, 2018
    660
    Post Falls Idaho
    She's Lookin' pretty Sharp, love that Red!! :{)
    gpax likes this.
  10. Motomantra
    Motomantra Registered Lurker
    Mar 6, 2008
    3,359
    Beaverton, OR
    I'd put fork gators on to protect from rock dings. Will extend seal life, too.
    Excellent choice in bikes.
    gpax likes this.
  11. Bigbob1
    Bigbob1 Rain Rider Supporter
    Sep 20, 2009
    1,182
    Juneau Alaska
    Use a relay to power the horn. The relay will get it's power direct from the battery to honk the horn when your stock horn circuit signals it... no blown fuses
    Rapturee2, gpax and Tewster2 like this.
  12. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
    Not a bad consideration. But I’m running low on my piggy bank with launch day only four months away.
  13. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
    I was just looking at some Triumph boots that someone claimed would fit. Anyone have experience with NC fork gators?
  14. Tewster2
    Jun 17, 2011
    7,859
    DeLand Flatistan
    I got mine from Bella Corse for the GS and the DR.
  15. Motomantra
    Mar 6, 2008
    3,359
    Beaverton, OR
    I went to NAPA, got RANCHO brand #RS1952 for my wee. It's fork tubes are about 43 mm.
    Rapturee2 and gpax like this.
  16. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
    New boots. Replacing my SIDI adventure boots. Almost went with mid-calf but decided on keeping shin protection. These weigh so much less than the SIDIs. They are comfortable to walk in out of the box. Also bought a new riding jacket made with RockTex, a Goretex like waterproof material. Had to go with Joe Rocket Atomic 5.0 for size considerations.
  17. oldgrizz
    oldgrizz Long timer
    Nov 22, 2016
    3,235
    I have looked at some Joe Rocket stuff but most of it dissent seen to go much past 2XL.
    What size and jacket did you get?
  18. oldgrizz
    oldgrizz Long timer
    Nov 22, 2016
    3,235
    Well that was a stupid question on my part as you have in your post the model of jacket.
    You will look pretty sharp on your new bike
  19. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
  20. gpax
    Aug 12, 2016
    1,372
    Pensacola, FL
    Miss snow? Then go to Pensacola Beach. :-) Last year on my DL650
    Rapturee2, Bigbob1 and JagLite like this.
