2020 KTM 350 EXC-F
Discussion in 'Thumpers' started by Dirt Rider, Oct 13, 2019.
  1. Dirt Rider
    Dirt Rider Old Adventurer Supporter
    Jan 15, 2003
    320
    Livermore, CA
    21B099DB-D9C9-49B8-9DF0-1C4C2922DEA6.jpeg I just brought one home Friday. Sure has a lot of changes from the 2019. So as folks get ahold of these, please post findings. It now has a closed loop injection system, a little lighter, a little more power, upgraded suspension, no skid plate ( ugh), larger/lighter muff. Exhaust pipe design all new.
    jm19328, OU812, NJ-Bill and 1 other person like this.
  2. El Pacifico
    El Pacifico Long timer
    Jan 17, 2012
    1,175
    Hood River, Oregon
    Did you come from the previous gen 350? Curious to know your impressions regarding the suspension performance between both generations.
  3. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    I had a ‘16 350 and an ‘18 350 Husky. Should not have sold the Husky as I thought I was through. I’m 74. But decided I needed one more. Can’t really say much about the suspension as all mine were lowered 2” which changes much. I liked the Husky forks better than the ‘16 KTM. It had Xplor forks like the new bike. It rode really smooth and I did not change any valving. New bikes suspension is now out for lowering. I pick the spring rates for my riding. 10% stiffer than stock. Worked out ok on Husky so doing same to the KTM.
    A friend of mine has the ‘16 KTM up in Oregon City. He likes it but is undersprung for his weight and ability. He needs to up his front spring rate as it bottoms a lot.
    husqvarna and El Pacifico like this.
  4. El Pacifico
    Jan 17, 2012
    1,175
    Hood River, Oregon
    Thanks. I’m on a 2012 350 which has the open chamber forks and am pleased with them. Stock height, and sprung for my weight.
    We also have a 2017 350 at home for the lady. It has been lowered and as you pointed out, it’s hard to compare. I briefly rode a 2018 501 with stock suspension and liked the one on my 2012 better.
    I’m hoping to eventually test ride a 2020 350 or 500 to get a sense of the suspension.
    I’ll be checking in here regularly to read up on your experiences with the new gen 350. They look great.
  5. Sixgun
    Sixgun Adventurer
    Jul 16, 2010
    85
    Morrison, CO
  6. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    I used a couple of his products on the '16. I liked the clutch weight. Now with the 02 sensor on the bike I probably will not do anything to it. 40+hp is plenty. I might order the clutch weight however. Some folks say he is a snake oil salesman but I was happy with what I bought. His exhaust tip for the muff was louder with his restrictor insert than the stock endcap with the screen removed according to my meter. I also had the manifold.
    Also for dualsporting the '16 KTM was geared too high as far as I was concerned. I went from a 45 tooth to a 49. Worked ok in CO at altitude. My Husky came with a 52 and I changed it to a 49. The new bike will also get the 49 tooth.
    I had GPR steering dampers on the '16 and '18. Not sure I will do that this time, however I liked the damper in the CO rocks. As I said above I am now 74 and don't need fast, I need light weight and lower to the ground. I have made and designed a shorter side stand that makes it easy to use the footpeg to mount and won't break. I used it on the '16 KTM and the '18 Husky. Gonna use it on the new bike if it still fits.
  7. FoggRider
    FoggRider Been here awhile
    Aug 24, 2015
    797
    California
    By closed loop, I’m assuming your saying can’t use a piggyback tuner on them? Bummer.
  8. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    Don't know. Not saying anything. I think on 02 sensor is a good thing. Best Dual has a tuner listed on his new site showing a tuner in a package for the '20s. I am not going to mess with the bike, Just ride it.
    #8
    outty and Sky2adam like this.
  9. hobomoped
    hobomoped Work hard, ride harder
    Jan 6, 2014
    10
    las vegas
    #9
  10. Adventurekid
    Adventurekid n00b
    Nov 12, 2019
    2
    Bay Area
    First post on this forum! I am starting to really enjoy trail/ adventure riding over MX and have my eyes set on the new 2020 350 exc-f for my first "dual sport" bike. Very curious to hear your feedback on the performance of the 2020 vs. 17-19 350 exc's. Was kind of bummed out to learn I would have to do Vortex ECU and everything else to just get the bike to run correctly.
    Looking forward to hearing about your experience.
    #10
    Jack90210 likes this.
  11. enduro16
    enduro16 Long timer
    May 15, 2012
    1,104
    The woods of northern IL.
    I've searched, maybe I don't know how to do it well? but I'm looking at the KTM, husky 350, the different of generations of the years, the pluses and the minuses of each one...thank You
    #11
    OU812 likes this.
  12. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    I’ll call tomorrow
    #12
  13. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    I’m sort of busy at the moment but I will write up something as soon as I get a minute. Or you could send me your phone number via PM/conversation and I could give you a call.
    #13
  14. Adventurekid
    Adventurekid n00b
    Nov 12, 2019
    2
    Bay Area
    Thanks! DM sent.
    #14
  15. little squirt
    little squirt Adventurer
    Sep 22, 2010
    95
    808 All Day
    is this bike in first post already lowered 2"? did you have the KTM 50mm kit installed at dealer prior to delivery/take home?
    #15
  16. Dan950ser
    Dan950ser Two Wheeled Addict
    Sep 24, 2010
    2,441
    Olympia, WA
    #16
    mikez104, OU812, Fallacy and 2 others like this.
  17. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    A5E0E33B-5359-439B-8AB3-D3EDB57A9F82.jpeg D27DE371-C039-4BC8-9798-2049597A3F9B.jpeg
    No and no.
    After lowering
    #17
    KevinBB, Jack90210 and OU812 like this.
  18. little squirt
    Sep 22, 2010
    95
    808 All Day
    did you have a shop lower it? Looking at getting a 2020 500 but live in Hawaii, so shipping suspension in a rifle case back and forth might be very costly....I was looking at the KTM 50mm. Thanks for any heads up or info
    #18
  19. Dirt Rider
    Jan 15, 2003
    320
    Livermore, CA
    PM sent. A shop I have used did it. Spring selection from KTM was a problem from their kit optional rates for my weight. Unobtainium stuff
    #19
  20. Bitingdog
    Bitingdog That's not my dog
    Apr 2, 2015
    15,225
    Vancouver B.C. rainforest
    #20
    mikez104, Brtp4, RideFreak and 8 others like this.
