2020 R1250 camshaft timing...
Discussion in 'GS Boxers' started by JamesD77, Nov 12, 2019.
  1. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    I've been reading a ton of info on here so I figured I'd give some back, here is some of the pics explaining the camshaft timing for the 1250, not much difference between the old 1200. Hope this helps some of you guys out!
  2. JimVonBaden
    Feb 11, 2005
    93,609
    Alexandria, VA
    Yes, exactly like the Wethead, with a new tool set. Same torque values.
    Where did you get this?
  3. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    They are copies of the procedure, not complete and some info redacted. I hope I have not broken any rules being his is my second post. You can IM me if I need to remove it.
  4. JimVonBaden
    Feb 11, 2005
    93,609
    Alexandria, VA
    No, not at all. I was just curious where you got them? The manual has not been released to the public yet.
  5. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,973
    Yes curious also. Wondering if I want to grab the cam tools and continue on my adventures of checking 1250's along with 1200's. I am very curious if they are all over the place as the 1200's are?
    JimVonBaden likes this.
  6. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    Well I'm sure the DVD service manual release will be soon, I do have the tool ordered, should get it today. Ill post a pic of the tool and the p/n to order, from your local dealer. The only difference is the removal and reinstallation of the shift solenoid, from the 1200 motor, as seen in the instructions. Lee, I'm also curious to see if timing is off, I know my 18' r1200 was at 6000mi.
    Beecher Snipes and LAFS like this.
  7. JimVonBaden
    Feb 11, 2005
    93,609
    Alexandria, VA
    Looking forward to this. :thumb
  8. Lead Wrist
    Lead Wrist Mehr Gelände Weniger Straße
    May 26, 2007
    9,753
    Zer0-Zer0-Zer0-Zer0
    Ty for the scans - it looks like 2 new tools, "11 2 510/1", are needed for Shifty as compared to original LC tools - the tensioner and rest of the tools you posted seem carryover...
    Please post the p#s for tools you've got for future reference... :beer
    It may not be bad idea to cross-post the same info in the main thread on the topic: https://advrider.com/f/threads/using-any-gsw-special-tools.937091/
    #8
  9. AZgman
    AZgman Addicted to curves
    Jan 1, 2014
    624
    Gilbert AZ
    The text implies (to me) that there is a left side and a right side alignment tool.
    #9
  10. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    Well still waiting on the tool. I think you can unbolt and flip the jig around for the opposite cylinder, but time will tell....shortly....hopefully Friday.
    #10
  11. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    I also agree looks like two tools in a set, but that could be a German to English translation error in wording. Again we'll see.
    #11
  12. LAFS
    LAFS Long timer
    Dec 15, 2016
    1,973
    Well they are the same number referenced so I hope it is one tool only.
    #12
  13. taran1900
    taran1900 Adventurer
    May 19, 2006
    16
    McKinney, TX
    I've had my 1250 almost a year and the manual still hasn't been released... :baldy
    #13
  14. JimVonBaden
    Feb 11, 2005
    93,609
    Alexandria, VA
    Hell, I had the video filmed a year ago, but didn't want to release it until I got a copy. I finally got confirmation on a few key factors values and torques, so just finished it 10 months after filming. I am still waiting on a copy of the manual though.
    #14
    phreakingeek likes this.
  15. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    Here is the tool, one p/n and you get the set. It retails for about $170.00
    B4F768CF-5F60-48B2-A590-E6CFF40BF932.jpeg A08A888D-2E4D-41CD-B432-F9EC664CE211.jpeg 24E02B76-DA52-42F0-9264-118E13B8C7DA.jpeg 53C9D89F-CA9C-4CEB-9186-64E4CC30917E.jpeg
    #15
    phreakingeek and JimVonBaden like this.
  16. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    F8E70AAF-90AF-45E1-A152-85C00DE97733.jpeg 825CF579-D472-4491-901C-34F316B737FB.jpeg 65E24AD6-56D8-4E89-9F99-E98929D0FBFF.jpeg A615632D-329A-45FB-AE01-5ACA5062971A.jpeg This is what I needed to confirm myself. The camshaft flats 'if you can call it that' are parallel with the valve cover gasket surface. That means with a little ingenuity and a digital protractor you could effectively set the cams in the same position as the jig tool. Also you can set your camshaft centerlines relative to the zero'ed out point either advanced or retarded or a combo of both to change open/ closing points this would effectively change the overlap number as well. Awesome stuff, but hot rodding a GS is probably not to popular.
    #16
  17. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    9DF56DCF-BDD4-40BA-AEC9-33BBA84A11B4.jpeg Here you go.....
    #17
  18. JimVonBaden
    Feb 11, 2005
    93,609
    Alexandria, VA
    Just like the Wetheads, it isn't necessary to have them exactly perfect for checking the valves:
    I did the same on the Shifthead, but visually:
    But for the cam timing, better precision is required.
    Wethead:
    I could see carefully improvising, or 3D printing these BMW plastic blocks for Cam Timing adjustments.
    #18
    JamesD77 likes this.
  19. JamesD77
    JamesD77 Adventurer
    Nov 12, 2019
    62
    North Jersey
    Awesome pictures Jim!!
    #19
  20. svtride
    svtride Been here awhile Supporter
    May 5, 2013
    646
    SE Michigan - MotorCity
    Thank you for this information. I'll probably order a set shortly.
    #20
