2020 Ural Gear-Up 2WD Adventure Sidecar - A Ride and Test Report in Three Parts
Discussion in 'Hacks' started by mikepa, Mar 28, 2020.
  1. mikepa
    mikepa SideCzarist Supporter
    Dec 10, 2001
    814
    Seattle, WA in the Great Pacific NorthWET (USA)
    I’m here to disclose a re-kindled love affair with an old friend, the internationally-sourced, Russian-built 2020 Ural 2WD Ural Gear-Up, the world’s most capable, purpose-built motorcycle/sidecar “combi”, with a host of features unmatched by any other production vehicle today.
    About Me: Sidecars are a passion. I’ve owned eight, currently have two at home, one in Germany, one in Japan. I’ve re-built several for friends. Both solo and with my wife, along with 25 lbs of tools, spares, and a well-considered road kit, I’ve piloted one of our rigs on both organized and self-guided tours across five continents. I’m a former military missile technician, amateur six-hour endurance racer, product design and manufacturing engineer, and I am passionate about building and making things hands-on.
    I’ve owned three different 2006 to 2008 Gear-Ups. They were a great way to tour state and forest service roads while taking in the varied and gorgeous landscapes of our home stomping grounds, America’s Pacific Northwest.
    However, the prowess of the then-carbureted/coiled ignition system Gear-Ups off-pavement didn’t hold true on the Interstates and trailering a Gear-Up to where we wanted to ride soon lost its charm. I found a compromise - take the Ural’s rugged sidecar chassis and body and mate it to a BMW GS-series motorcycle. That was a kick-ass combi, I built two of them, still own one, and since, have built BMW GS-based combi’s with sidecars from one Japanese (ABEZ), and three Dutch sidecar kit manufacturers: EZS, EML and LBS/Stepler. I’m not a sidecar expert, but I have a wide and deep experience base to draw on.
    I’m going to do a ride report on the 2020 Ural Gear-Up in three parts. First, the up-close-and-personal, lots of photos. Second, a highways ride on local, state and Interstate pavement, two-up. Finally, a run on some dirt roads, also two-up. I know some of you are Ural owners and experts, some are at least familiar with the brand but not the details, for some, it will be all new. I’ll do my best to make it real for those of you in the latter category.
    The 2020 Gear-Up, with improved “pretty much everything” over my previous Urals, has really come into its own. Over the last decade, the factory has evolved Urals from “Russian tractors” with unmatched off-road performance, to a multi-functional vehicle that performs well at freeway speeds. They were once 650cc, now 750cc. They once had carburetors, they now have Keihin throttle-body, closed-loop fuel injection systems. They once had coils and breaker ignition systems, now an electronic engine management system. Drum brakes have been replaced with three-wheel disc brakes. In short, its still a high-capability retro-styled machine, but now with thoroughly modern components.
    Let’s take an up-close-and-personal look!
    Ural Vice-President Madina Merzhoeva, showing a freshly uncrated 2020 Gear-Up in the headquarters and warehouse in Redmond, Washington (State) USA:
    A 2020 Gear-Up in Burnt Orange (aka “Screaming School Bus Yellow”):
    A signature feature of the Gear-Up is a manually selectable 2WD (the sidecar wheel is driven). It is a true or “full locking system”, both the bike’s rear wheel and sidecar wheel are powered and turn together, even if one or the other loses traction. An absolute hoot on loose traction surfaces like sand and snow:
    2WD is engaged by this ball-end selector lever on the right side of the transmission:
    Viewed from underneath, looking at the inside of the bike’s rear wheel, you can see the 2WD output shaft from the final drive:
    Viewed from under the nose of the sidecar, looking back, the large diameter lower cross-member is part of the chassis, the smaller diameter tube above is the driven output shaft that transfers power from the bike’s rear wheel final drive, to the sidecar’s wheel. Also note the two black rubber “snowmen” or “Michelin Men”, these two towers are shock absorbers, isolating the rear of the sidecar body from the chassis, makes the ride smoother for a passenger, man’s best friend, or your gear:
    View from the saddle. All standard hand controls, 5-gallon fuel tank, good for an estimated 155-185 range, with fuel economy estimated from 31 to 37MPG:
    Digital speedometer and odometer:
    Manually operated parking brake, it really holds!:
    Pedals operated by the right foot include a mechanically linked rear wheel/sidecar wheel brake system with independent hydraulic circuits, and also FORWARD/REVERSE selector pedal. Reverse is an awesome feature that attracts as much attention in the parking lot as the rig itself:
    750cc, air-cooled, horizontally-opposed twin cylinder motor. Develops 46HP and 42 ft-lbs of torque. Motor has both an electric and time-honored manual kickstarter. All new front cover and valve cover casting give a finished appearance, while the new cylinder heads improve heat dissipation:
    Introduced in 2019, the new Keihin throttle body, closed-loop fuel injection system results in immediate cold starts, and surprising power delivery. Throttle response is smooth. Emissions meet US, European and Japanese standards:
    Re-located oil filter makes for super easy oil and filter changes:
    The standard motorcycle telescopic front fork is not well-suited for a sidecar combi, as they do not take well to side-load forces, and don’t need to since motorcycle bank in a turn. Experienced sidecar designers choose a leading link front fork as the optimal design for sidecars. They are designed to take side-load forces, and have the added advantage of reducing or eliminating nose-diving during had braking. New for 2020, a single-piece forged brake caliper carrier:
    All three wheels have disc brakes. The rear brake caliper is operated hydraulically by the rear brake pedal during normal operation, and is cable actuated mechanical by the handlebar mounted parking brake lever:
    Rear wheel disc brake:
    Front end is now equipped with a BITUBO steering damper:
    Twin LED auxiliary driving lights are standard:
    (continued next)
    Rakthi, black 8, turbonotch and 7 others like this.
  2. mikepa
    Dec 10, 2001
    814
    (Up-Close-and-Personal, continued)
    Anti-slip molded step makes passenger ingress and exit simple and safe:
    It comes with a fourth wheel, and the spare will fit in front, on the rear, or on the sidecar. Wheels are sourced from Italcerchio S.R.L.. Italy:
    Spacious trunk has improved latches and a keylock for security:
    Passenger compartment. In sidecar parlance, the passenger is often referred to as “the monkey”, no offense intended!:
    Seats are contoured, embossed, nicely stitched, and also sourced in Italy, and the seat bottom is removable, revealing a molded storage compartment that holds a tool kit, tonneau cover, and paint touch-up kit. Not even BMWs come with a tool kit any longer:
    A Hella/Euro-style 12VDC accessory outlet is included for a passenger’s heated clothing, charger, or other devices:
    In time-honored tradition, the Gear-Up still comes with an “entrenching tool’:
    A rugged steel NATO canister and carrier are standard equipment:
    For active off-roading, an accessory 2-into-1 high pipe is available, all stainless steel construction:
    Here’s what the high-pipe exhaust system looks like from down under:
    Ural is the world’s only motorcycle/sidecar combi that is certified for international sales. The 2019/2020 models have remained faithful to their retro design, and have come into their own as both a capable touring sidecar, and also an unbeatable off-pavement machine that can carry two and your road kit in comfort. With its new fuel injection system, 2WD, reverse gear, fully interchangeable spare wheel, capacious trunk, three-wheel disc brakes, parking brake, and let’s not forget the entrenching tool, it an unbeatable value, and perhaps the most multi-functional and fun vehicle money can buy:
    On the next installment, a highways road test, "two-up"!
    Kruzof, Rakthi, Metalcarver and 12 others like this.
  3. Tall Man
    Tall Man 129% of people exaggerate.
    Jul 14, 2007
    6,779
    The Occident
    Brilliant photos. Well done.
    A few comments in passing from a Gear Up owner, respectfully submitted and for the sake of clarity.
    "Manually operated parking brake, it really holds!"
    Yes, for about a month or so after delivery. :-) It isn't self-adjusting. That is to say, as the rear brake pads wear, the owner will have to adjust the parking brake cable at the front of the swing arm to maintain the function of the parking brake feature. A simple procedure for doing so is clearly illustrated in the Owner's Manual.
    "750cc, air-cooled, horizontally-opposed twin cylinder motor. Develops 41HP..."
    The 2019+ rigs provide 46 hp, a 5 hp increase when compared to their 2014-18 ElectroJet FI brethren. Yes, a website edit to the spec data is probably indicated.
    "All new front cover..."
    The current iteration of the front (ignition) cover, with the external oil filter, was introduced with the 2014 model year.
    "Front end is now equipped with a BITUBO steering damper."
    Introduced with the 2018 model year. A marked improvement over the previous design used from 2014-17, some of which were subject to leaking due to premature seal failure.
    "...the seat bottom is removable, revealing a molded storage compartment that holds a tool kit, tonneau cover, and paint touch-up kit."
    The one-piece under seat storage tray, while convenient, is a bit shallow. The center divider prevents the tray from holding either the standard Ural tool roll, or perhaps even a folded tonneau cover (without compressing it) possibly to the point of damage. It's best used for a few loose tools, carefully packed, as well as a first aid and a spare pair of gloves.
    "Switched Hella/Euro-style 12VDC accessory outlet..."
    The Powerlet socket is in fact unswitched (i.e., always hot). It can be used to power a 12 V accessory, or a USB connection with the appropriate adapter. When the rig is parked, the socket can also accept input charging/float voltage from a battery tender.
    The toggle switch on the fuse panel is a remnant of (and was intended to control) the sidecar spotlight that was discontinued after the 2017 model year. As delivered, the switch controls nothing. It can be wired to control an owner-installed electrical accessory of his choosing.
    Best of luck with your road test. Be safe.
    TMac99, Rakthi, rg sw wa. and 5 others like this.
  4. mr.spui
    mr.spui Been here awhile
    May 1, 2017
    107
    The Ural is not "the world’s only purpose-built motorcycle/sidecar “combi”, ". It might be the only one available in the USA, but the Jialing JH600B-A, Chang Jiang CJ650B and Shineray XF400B are available elsewhere.
  5. davide
    davide Been here awhile
    Aug 14, 2006
    588
    Elizabeth, Colorado
    Great write up and beautiful pictures, Mikepa, and thank you, Tall Man, for the extra info. Looking fwd to reading more. Nothing like Ural porn to get thru this period of isolation. Just one question about the skid plate and the protective cage around tail light: stock on 2020 Gear Up or from accessories catalogue to be bought extra?
    rg sw wa., Tall Man and mikepa like this.
  6. GR8ADV
    GR8ADV Safety Second!
    Mar 7, 2007
    1,789
    Bellevue
    What is the up charge on the raised exhaust? Given that I at least would replace the stock exhaust and cat does this play into the system? Thanks for the write up.
    rg sw wa. likes this.
  7. mikepa
    Dec 10, 2001
    814
    The Ural is available in major international markets, the Chinese makes are not. But, you're technically correct, I've made the edit, thanks for pointing that out.
  8. mikepa
    Dec 10, 2001
    814
    Thanks for the comments @Tall Man. Relevant corrections have been made.
    #8
    rg sw wa. and Tall Man like this.
  9. mikepa
    Dec 10, 2001
    814
    The high pipe and skid plate are accessory products, and like most in that category, high-pipe is, of course, "for offroad use only".
    #9
    rg sw wa. and davide like this.
  10. mikepa
    Dec 10, 2001
    814
    Thanks! I would recommend you find your nearest dealer for pricing of anything of interest. Although my loaner has the standard twin mufflers, I believe the high-pipe includes headers, a 2-into-1 collector, and the high muffler.
    #10
  11. Flyin' Monkeys
    Flyin' Monkeys Wicked Witch Airlines Supporter
    Apr 10, 2019
    388
    Emerald City
    Mike, if I may make an observation, and suggest an improvement that should be passed on to Ural Vice-President Madina Merzhoeva, in this picture you posted,
    it shows the exposed U-Joint, that drives the axle for the sidecar wheel.
    In MY world, I would immediately make a measurement of the overall length of that complete U-Joint, and the overall diameter of the same U-Joint, then check with certain automotive manufacturers to see which CV Boot would properly fit over that entire exposed U-Joint. Personally, I would go with a Fuji brand one, used on the Subaru's, as they have been using CV Boots longer than most manufacturers, and use them on all 4 wheels.
    Given the intended use of a Ural 2-Up, with off-road duties being a focus, there is no way I would leave that U-Joint exposed. :nono
    Frankly, if I were Ural Vice-President Madina Merzhoeva, I would JUMP on this idea, and send a memo to the manufacturing facility in Mother Russia, and get this implemented ASAP. The "cost" for installing a good/quality CV Boot on each and every Ural 2-Up would be about $ 5.00 per machine.
    #11
    TaZ9, rg sw wa., GR8ADV and 2 others like this.
  12. GR8ADV
    Mar 7, 2007
    1,789
    Bellevue
    Reminds me of the old line from eating in a restaurant with a dirty bathroom. “ if that’s what they will let me see, what’s behind the closed kitchen doors”
    #12
    Strick and Flyin' Monkeys like this.
  13. windmill
    windmill Long timer
    Feb 18, 2008
    6,132
    Kent, Washington State
    The always hot lead to the power outlet can be changed to the switched lead by simply unplugging the one, and plugging in the other without any modifications.
    #13
  14. rg sw wa.
    rg sw wa. Long timer Supporter
    Feb 9, 2011
    1,789
    Southwest Washington
    See pic of:
    The wires need to be better secured. Refer back to Mike’s excellent posting / write with pics on re-wiring a BMW / sidecar.
    I’ll never look at another bike / car wiring repair / installation job the same way again.
    #14
    norton(kel) and mikepa like this.
  15. Tall Man
    Jul 14, 2007
    6,779
    The Occident
    Link?
    #15
  16. Bar None
    Bar None Long timer Supporter
    Mar 2, 2007
    13,093
    SWFL WNC
    Nice photos of the GU. Waiting for the next part.
    #16
    mikepa likes this.
  17. rg sw wa.
    Feb 9, 2011
    1,789
    #17
    Tall Man likes this.
  18. Scott of the Sahara
    Scott of the Sahara Been here awhile
    Feb 26, 2009
    483
    Mighty Fine Ural
    #18
    mikepa likes this.
  19. SLACKER
    SLACKER Been here awhile Supporter
    Feb 10, 2003
    290
    vagabond.......
    As someone who hasn't owned or driven a Ural since a 2000 model which I sold years ago I am anxious to read a ride report from you Mike. I swore Urals off many years ago but this has piqued my interest.
    Thanks for sharing your unbiased experiences here
    #19
    TaZ9 and mikepa like this.
  20. GR8ADV
    Mar 7, 2007
    1,789
    Bellevue
    Mike, Mike, Mike ...
    #20
