2021 Honda XR500R by N.A.P.A.L.M.
Discussion in 'Some Assembly Required' started by larryboy, Oct 1, 2019.
  1. Strong Bad
    Strong Bad Former World's Foremost Authority Supporter
    Oct 29, 2007
    14,076
    Omicron Persei 8
    I noticed the welding rod to indicate the steering head angle, are you looking to change the trail? I think road bikes tend to have a bit more trail than dirt or dual sport bikes.
  2. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Über Alles,California
    I was checking rake/trail to make sure I was good with the longer forks. It's spot on and I won't be changing the head angle.
  3. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    I got the neck cleaned up today.
    And the dog bones came in. They're heavy duty on the CRF250L. We had talked about me making some, but I'm wanting the bike to be easily serviced for the long term.
    Nixels, oldbmw, dave6253 and 4 others like this.
  4. Nixels
    Nixels Face fears - live life
    Sep 24, 2006
    10,474
    HayWeird, CA
    :scratch Don't you feed the dogs fresh meat? When did you start cheaping out and buying rawhide????
    :D
    :hide
    larryboy likes this.
  5. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Took a trip to use a buddies lathe, ten hour day, just got home.
    Made a decision on where to cut the neck before I left the house this morning. Trying to stay away from the VIN.
    Had to turn down the tube clamps a little to fit the DOM tubing.
    Then I did a bunch of work on some new slugs to mount the swingarm. I'll have to finish this at home on my micro lathe because I was using a bolt as an arbor and I stripped the bolt on the lathe...much more torque than I'm used to. No pictures.
    I didn't want to burn time on something I can do at home. I had a real live machinist at my disposal to give me pointers. I can use a lathe, but more knowledge is good.
    The main project was to make an adapter for the upper bearing race that is also a press fit to the head tube. Two different sizes of boring to be done.
    I got it all made right on the first try. I wanted to shape the outside to make it more pleasing to the eye, but ran out of energy. Hour drive home.
    Really pleased with the way it turned out. Now I can press it all together and get to work on the frame.
    shinyribs, Fubars, dave6253 and 10 others like this.
  6. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    Not boring at all - why did you say that??? :scratch
    dave6253, Honda-50 and larryboy like this.
  7. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    I was anticipating your arrival.
    :drums
    :imaposer
    Nixels and villageidiot like this.
  8. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    I'm no Johnnie-come-lately! You just want to get all lathered up and mill around. :D
    :zilla
    dave6253, larryboy and Honda-50 like this.
  9. loganlexow
    loganlexow Been here awhile Supporter
    Aug 15, 2015
    243
    seattle
    I'm am so in love with this. I get all giddy every time a get a notification for this build lol. Then, I get depressed when it's a comment like mine and not pictures
    Z50R, larryboy and Nixels like this.
  10. oldbmw
    oldbmw havehandlebarswillrideit
    Feb 2, 2008
    576
    Reedley, CA
    To me, this is at the rocket science skill level, way over my pay grade! Good job 'larryboy'
    larryboy and loganlexow like this.
  11. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Got enough energy to get some garage time in today.
    Finished the carb rebuild on the KTM 640.
    New fog light bulbs and some Rigid Duallys for the Triumph.
    Last but not least some lathe time on the neck for the 500.
  12. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    :lurk As the superpickle turns...
    :zilla
  13. SFKLR
    SFKLR Noob. Again.
    Jun 7, 2006
    376
    :lurk
  14. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    :wave
    SFKLR and larryboy like this.
  15. loganlexow
    Aug 15, 2015
    243
    seattle
    :dllama:
  16. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,734
    Oakland, CA
    Glad you're feeling well enough to get out to the shop. I hope that trend continues.
  17. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Got things back on the frame jig before work this morning.
    IMG_20210208_103908118.jpg IMG_20210208_103916188.jpg IMG_20210208_104053142.jpg
  18. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    I have been in envision mode. Saturday I will build the frame.
    I measured some other bikes here and 44" from the ground to the fuel cap is normal. I don't know that I can get this that low, looks more like the 46-48" range.
  19. Oyabun
    Oyabun 親分
    Apr 7, 2016
    869
    Budapest, Hungary
    Telly interested how you're installing the swingarm and what modifications are messed on the frame to install and align it.
  20. Bigbore4
    Bigbore4 Long timer
    Oct 21, 2010
    2,139
    Andover MN USA
    Make sure you contact and consult with the intern at Yamaha that designed the frame / upper engine interface o the Super Tenere. Leave 1/4 mm or less of space all around. Make sure the frame covers and makes it impossible to see the cam timing marks. ASSuming you can get the cover off.
    /engineering advice
    Nixels, larryboy, TimmyTheHog and 2 others like this.
