2021 Honda XR500R by N.A.P.A.L.M.
Discussion in 'Some Assembly Required' started by larryboy, Oct 1, 2019.
  1. Nixels
    Nixels Face fears - live life
    Sep 24, 2006
    10,474
    HayWeird, CA
    That's what I like about your builds @larryboy - keeping it simple and illustrating what you're posting. :deal
    :zilla
    Pezz_gs, oldbmw and larryboy like this.
  2. bk brkr baker
    bk brkr baker Long timer Supporter
    Jul 19, 2006
    12,145
    The Bluegrass
    Happy that you're healthy and welding stuff up . Continue please !
    Roadracer_Al, Ladybug and Nixels like this.
  3. Roadracer_Al
    Roadracer_Al louder, louder, louder!
    Aug 5, 2007
    2,734
    Oakland, CA
    Dang! You need to install a grease nipple on that notcher.
  4. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Über Alles,California
    It has one, I spray dry graphite on it. I hate grease all over everything.
    Made some good progress today.
    Messed up the angle on the forward notch on this tube. Good enough to tape up there so I can see how it looks.
    The frame jig is invaluable for notching because you always know where 0° and 90° are at.
    That's better.
    Got the other side made up. This is the side that will get the tube clamps so the valve cover can be removed.
    Got tempted to pull it out of the jig to put suspension and wheels on it.
    Better get the upper engine mounts in first. Got an original frame tube out to see what Honda did. For some reason the hole for the bolt is way oversized, probably due to variances in each frame.
    Made up a tab for the left side and welded it in. This is what I came up with for the other side.
    Pezz_gs, shinyribs, dave6253 and 10 others like this.
  5. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    Wow! You really turned it up a notch, @larryboy.
    :zilla
  6. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    I'm coping well with your posts.
    :drums
  7. Nixels
    Sep 24, 2006
    10,474
    HayWeird, CA
    There’s always a way to frame it without tacking on unnecessary words.
  8. oldbmw
    oldbmw havehandlebarswillrideit
    Feb 2, 2008
    576
    Reedley, CA
    Super exciting!
    Nixels and larryboy like this.
  9. HardWorkingDog
    HardWorkingDog Super Ordinary
    Aug 20, 2009
    4,222
    Walnut Crick, Cal.
    You mind telling/showing more about your frame jig? Is it something you made, or bought?
    larryboy likes this.
  10. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    It's a kit from Chop Source.
    Extra cost for the rotisserie, it's super nice for final welding.
    Extra cost for the feet you can adjust to level out the whole jig.
    All of the tubing is provided by you, so you can make it whatever length or height that you want.
    JagLite, mentolio, Hanz and 4 others like this.
  11. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Got approval to trap the valve cover in there. I'll use the tube clamps for the cradle.
    So relieved!! :clap
    When I remove the engine to paint the frame I'll check the valves. It's a Honda...
    dwdantzler, dave6253, Barron and 2 others like this.
  12. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    Got her out of the jig and the trees on. Need to check turning radius before final welding.
    Looks like it'll work.
    Got things mocked up. No weight on the ground.
    Seat is at 34" there, but no sag, so it can really go up a few inches.
    The total package is tiny, this thing is going to be great!!
    Had big plans for today, couldn't make it happen.
  13. 2on2off
    2on2off Head'n somewhere new
    May 22, 2007
    2,314
    The Western USA
    This bike is coming together very nicely.
    Vrode, waylongway and larryboy like this.
  14. jays100
    jays100 Been here awhile
    Aug 1, 2006
    566
    CT
    Are you going to run a loop around the engine from the top rear to the front? I wouldn’t jump this thing otherwise. It appears all stress is concentrated in the tube above the swingarm pivot…a structural hinge point. Or, do you think the cases are strong enough to handle off road duty?
    envisioned loop is horizontal each side so engine still drops out the bottom, ala Harris frames. Not a cradle setup.
    loganlexow likes this.
  15. jays100
    Aug 1, 2006
    566
    CT
    My chief engineer would say “show me your numbers” but if you say so…
  16. 2on2off
    May 22, 2007
    2,314
    The Western USA
    Great to see the work you are doing. Question: I know there were some issues mounting a skid plate on the CB500X models as the engine is a stress member, I think that is correct. I believe some have said engine bolts could sheer off with a strong enough hit to a skid plate mounted to the engine. 1. Will a skid plate be able to be mounted differently on this bike than a CB500X? 2. Any idea how many inches of increased ground clearance you will have vs. a CB500X?
    I may be getting ahead of myself with these questions since this is still in process. It is fun to watch the progress on this bike.
  17. larryboy
    larryboy Just obey!
    Jan 9, 2005
    31,047
    @2on2off , I'm building a removable lower cradle that will have a skid plate. We're at 14" of ground clearance unsagged, shooting for 12" at sag.My goal is to have full oil capacity and the cat in place.
    JagLite, Nixels, TimmyTheHog and 2 others like this.
  18. svo_jon
    svo_jon Been here awhile
    May 10, 2019
    231
    Bend OR
    My rally raid engine guard has taken some good hits without any sheered bolts.
    Jonathan
    SlowernOlder and loganlexow like this.
  19. jays100
    Aug 1, 2006
    566
    CT
    This is serious, and needs to be thought through more fully.
    The elasticity modulus is the same for both mild steel and chrome moly so nothing is gained by change in material. The difference in tensile strength doesn’t help with the applied load direction. Also, the bend stress on a dirt bike off of a jump is (in engineering parlance) both ends restrained with middle unrestrained…wheels landing with the engine and rider continuing to move. A wheelie (from your pic) is front wheel only, only 1/2 the realized load on that middle frame pipe.
    I can only stress in the strongest possible terms (as an engineer) to rethink adding either a circular stressed link to the down tube or add a cradle underneath the engine. I guess you could restrict riding envelope.
  20. tobiism
    tobiism Long timer Supporter
    Jun 28, 2011
    2,253
    Chandler AZ
    Screenshot_20210703-145458_Chrome.jpg like this?
