2021 Husqvarna 701 Rally Build - Overheating, need advice
Discussion in 'Thumpers' started by crawlmeister, Aug 17, 2021.
  1. crawlmeister
    crawlmeister Adventurer
    Feb 23, 2021
    14
    Colorado
    I just double checked and it turns out that the LR DOES NOT have 2 fans, rather it has a single fan which is about 30% larger. I tried to source the parts for it but it look like it’s impossible to get in the US
    #21
  2. DJKuhn
    DJKuhn Been here awhile Supporter
    Apr 6, 2015
    171
    Finger Lakes NY
    I was going to add that folks strongly recommend aftermarket exhaust with bags to prevent overheating... but I think that's overheating in the back end of the bike rather than the motor.
    #22
  3. GeorgeD
    GeorgeD Been here awhile
    May 21, 2013
    700
    Sweden
    Indeed!
    I just got in home after removing front fuel tank and installing this extra switch that I mentioned above.
    I was trying to find the 2nd fan but in the end is only one (on the left side as we sit on the motorcycle).
    Good luck identifying the cause and keep us posted please!
    #23
  4. Racerx43
    Racerx43 Been here awhile Super Supporter
    Feb 2, 2021
    139
    Scottsdale, AZ
    That little switch does wonders
    #24
    GeorgeD likes this.
  5. GeorgeD
    May 21, 2013
    700
    Sweden
    #25
  6. Jan from Finland
    Jan from Finland Been here awhile
    May 2, 2005
    998
    True, but the LR kit includes the bigger fan. Then I have two fans to install.
    #26
  7. crawlmeister
    Feb 23, 2021
    14
    Colorado
    Two fans won't fit apparently (According to someone who's done it to their 690). I just ordered the LR big fan kit and will install it - hopefully that'll help
    #27
  8. Jan from Finland
    May 2, 2005
    998
    I know they won't fit using the original mounts, but too bad if you can't make them to fit.
    #28
  9. gibbo66
    gibbo66 Adventurer
    Apr 24, 2016
    14
    Sydney
    I think it'll be amazing if you can fix the overheating! I am very envious of your build ( Ive got a 2019 690R) but I guess if you add up a highly strung motor ( relatively), emissions mapping, elevation, slow riding, insulated cases ( with the CF) and a fair bit more weight on a bike that was designed to be as light as possible ( and thus with the smallest functional cooling capacity) you're gunna end up with challenges. I cant help but think its a pumpkin thing too- Ive had EXC 200, 2x300, Husky 300, now 4 690's and they’ve all got hot /boiled with minimal provocation . No Beta, Sherco or Gas Gas ( the Spanish ones) ever did.
    Good luck and you have an AWESOME bike!
    I suspect richening up the fueling will help a lot- you mentioned fuel dongle, might need re mapping though. I put one of Kevs fuel dongles on mine ( in line with O2 sensor), didnt make much difference BUT the 2019 is so far ahead of the previous ones, it may not have needed it.
    #29
  10. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    6,923
    Reno
    These bikes have always been prone to overheating and sometimes clutch problems when run at low speeds with serious clutch use. They may be called "Enduros". But gearing and low end power are not enduro like. I would suggest that lower gearing is needed for anything approaching serious off road. Of course the suggestions as to leaks and radiator caps are very important too. I have not found the change to lower temp fan switches to be beneficial. Make up your own mind on the waterless coolants. Lots of debate out there. I am in the camp that does not use them. They raise the boiling point at the expense of cooling capability. So bike still overheats it just doesn't warn you as soon with steam. FWIW
    #30
    Bitingdog and sharpie1 like this.
  11. Racerx43
    Feb 2, 2021
    139
    Scottsdale, AZ
    The statement about gearing ^^^ is my next move too. The sweet spot I find for cooling is when the motor is spun up a bit more. I need to move the RPM range that I tend to ride the slower sections - that will be a quick fix… Thanks for jogging me on that one. Now which size - LOL
    #31
  12. Honda Rider
    Honda Rider Been here awhile
    Dec 25, 2008
    199
    I moved to a 52 on the rear with a 120 link chain. This allows me to run a 14, 15 or 16 tooth counter shaft sprocket. 16-52 is about the same as dropping one tooth on the OEM front for the Enduro or 14-46.
    14-52 is perfect for me on single track but sucks on pavement obviously. I run 15-16 tooth front sprocket depending on how much tarmac I have to do.
    #32
