2021 KTM 500 EXC-F setup for dual sport
Discussion in 'Thumpers' started by mbillens1, Sep 13, 2020.
  1. renogeorge
    renogeorge Let's ride!! Supporter
    Apr 7, 2007
    7,017
    Reno
    My experience too and much cheaper than ECU replacement and in my experience totally smooths and increase power. I ran on on my 2012 XCW 500 and now on my 2019 501. I hear the suggestion that the more $$ ECU replacements are worth the extra $5-6 hundred. I’d sure like to see real world USABLE benefits and not just minuscule HP/Torque gains at extreme high RPMs that most riders will never see. FWIW
    MoseFitch, Magile and Mike in Roswell like this.
  2. 2whl-hoop
    2whl-hoop Long timer Supporter
    Jan 12, 2008
    1,780
    Woodbury, MN
    I use the Motominded dash on my 350. The USB comes wired into a jumper that goes between the headlight plugs. I love it. I power my phone off it which I use as a GPS.
    These instructions on their website show it pretty well:
    https://drive.google.com/file/d/1_bv4LAA5ibltP8Lilkqjc5JRC5_cQkvJ/view
    pratered likes this.
  3. Mike in Roswell
    Mike in Roswell Been here awhile Supporter
    Apr 17, 2019
    104
    Roswell, GA
    2whl-hoop likes this.
  4. Mike in Roswell
    Apr 17, 2019
    104
    Roswell, GA
    Hmm, this looks like an ACC connection? Anyone used it / know for sure?
  5. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    706
    Hood River, OR
    Tapped into the wire powering the USB included in the Motominded dash, which inturn is powered by an inline plug to the headlight, if that makes any sense.
  6. rjg418
    rjg418 Adventurer
    Jul 12, 2021
    16
    Ontario
    Does anyone know first hand experience that the IMS 4.5 gal tank would accomodate enduro engineering machined billet radiator guards?
    I realize they are unnecessay once the tank is on but I bought these long before I wanted an IMS tank and they still will protect the front of the radiators.
    They are beefier on the outside where the tank might rub.
    See example of them below.
  7. PistolPetey
    PistolPetey Been here awhile Supporter
    Dec 17, 2009
    367
    Wild West BC
    i have Emperor Racing rad guards, which appear to have similar width as yours. The IMS tank is not compatible with my guards. Check the EE website or contact them to find out if they know about compatibility.
  8. rjg418
    rjg418 Adventurer
    Jul 12, 2021
    16
    Ontario
    Thank you for the reply. I checked out emporer guards and if they dont fit with the ims tank then enduroengineering definetly wont either since they are thicker than yours. I guess im going with acerbis
    Nk
    PistolPetey likes this.
  9. Magile
    Magile Long timer Supporter
    Apr 11, 2005
    1,220
    HVL, NC
    rjg418 and PistolPetey like this.
  10. twinrider
    twinrider Pass the catnip
    Aug 20, 2002
    18,498
    日本
    My buddy Mark of Tokyo Offroad converted my 15's 4CS forks to Xplor, which have better options for improving and lowering them. Installed the Dal Soggio XP-One kit to improve the forks and the Zeta lowering kit to drop them 3 cm. Used the Terra-X kit lowering kit on the shock. Took some ingenuity for Mark to get everything to work, including machining new spacers for the brake disc guard. Also fitted some Shinko 804/5s and balanced the wheels using his handmade brass weights. Looking forward to some DP exploring on it.
    Emgo, Cafeguzzi, nzrian and 7 others like this.
  11. rjg418
    rjg418 Adventurer
    Jul 12, 2021
    16
    Ontario
  12. FLEUP
    FLEUP Adventurer
    Jun 7, 2021
    28
    France
    just ordered my 21' 500, , should arrive in 2 weeks .... may you please put photos from hi capacity fuel tank available for this bike?
    I seen few on this post, Acerbis look very hight and IMS very wide but I didn't see how wide they are (pictore from the top or the rear)... and others models do exist?
    Thx!!
  13. Magile
    Apr 11, 2005
    1,220
    HVL, NC
    IMS 4.50 gal tank is ~57 cm wide. Photos are from '19 & '21 500EXC's. We love our 500's...
    It is possible to spend more $, but I used a simple JD Tuner, removed the muffler screen and intake flap. https://jdjetting.com/product/jdktx14-ktm-500-xcfw-exc-20-21/
    Bonne chance - M
    PS: Giant Loop Tank Bag - https://www.giantloopmoto.com/product/buckin-roll-tank-bag-2020/
  14. FLEUP
    FLEUP Adventurer
    Jun 7, 2021
    28
    France
  15. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    I have ims
    Protects radiators very well, so additional guards are not needed. Kinda of a money saver really
    RTWstare and pratered like this.
  16. FLEUP
    FLEUP Adventurer
    Jun 7, 2021
    28
    France
    I'm agree
  17. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    Has anyone replace fan switch so it comes on at a lower temp?
    I cannot locate any info on this mod.
  18. Magile
    Apr 11, 2005
    1,220
    HVL, NC
  19. webnetxpress
    webnetxpress DakarEnduro
    Nov 12, 2015
    591
    Pretoria, South Africa
    Yep, on my last 500.
    It is a standard automotive switch you unscrew the old one from the radiator and install the new one. OEM is on at 100c and off at 95c. I chose a 90c ON one to get my fan to kick in sooner.
    Here is one-
    https://autoplicity.com/9242760-febi-61-31-1-364-272-91-auxiliary-fan-switch
    (I believe it is a standard BMW thermo switch)
    or you can buy a KTM one for 3x price-
    https://aomc.mx/83035045000.html
  20. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    i have looked and just cant locate switch. Does not seem to be in usual location.
