2021 KTM 500 EXC-F setup for dual sport
Discussion in 'Thumpers' started by mbillens1, Sep 13, 2020.
  1. Buildzall
    Buildzall Rooster Supporter
    Apr 22, 2013
    5,423
    Ga
    Bottom right corner of right radiator (throttle/brake side)
  2. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    image.jpg Nope
  3. Buildzall
    Apr 22, 2013
    5,423
    Ga
    Dammit
  4. webnetxpress
    webnetxpress DakarEnduro
    Nov 12, 2015
    591
    Pretoria, South Africa
    I dont see any wiring from that hose. And you are correct, on the schematics I dont see a mention. Hmmm.
    Someone much more experienced than me will have to chime in! sorry
    Buildzall likes this.
  5. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,457
    USA
    The schematic shows it on the cylinder head, facing up, right hand side. It'll look like every other water temp sensor - brass body, plastic connected to that, two wires exiting.
    Buildzall and 75bronco like this.
  6. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    image.jpg Bingo
    moto74 and Buildzall like this.
  7. webnetxpress
    Nov 12, 2015
    591
    Looking on the 2020 schematics, which one would I find that on? Just curious, can't see it on the cylinder head one.
  8. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
  9. Buildzall
    Apr 22, 2013
    5,423
    Ga
    Yeah, I passed out last night looking at schematics for that bugger.
    The fan plug end is there.
    but not the adjoining connector, nor the temp sensor/switch.
    I feel reasonably competent compared to avg folks and I swear it wasn't there.
    :baldy
  10. Buildzall
    Apr 22, 2013
    5,423
    Ga
    That's the water flow temp regulator thats inside the hose assy.
    The temp sensor/switches the fan
  11. NoelJ
    NoelJ Long timer
    Apr 7, 2016
    2,457
    USA
    It's there. This was from RMATV, 2020 and/or 21 "cylinder head" image.
  12. webnetxpress
    Nov 12, 2015
    591
    Thank you!
  13. moto74
    moto74 displaced
    Sep 18, 2012
    723
    BOP, NZ
    Copy that, thanks!
  14. Fast1
    Fast1 Twisted Throttle
    Aug 18, 2007
    5,471
    Bridge over Troubled Water
    For some reason I thought the fan switch on the most recent production is activated by the ECU settings.. based on discussion from Taco Mike and aftermarket ECU settings.
    Isn't the thermostat switch (not fan switch) the one pointed out in the top of the head in the previous posts? Does the wiring for this run to the ECU wiring harness?
  15. 75bronco
    75bronco Long timer
    Apr 2, 2009
    1,197
    East TN
    I have a GET ecu
    i do not see any options for adjusting fan temp. But then again, i aint super tech savy.
  16. Fast1
    Aug 18, 2007
    5,471
    I thought Taco Mike in one of his you tube videos indicated that this parameter was adjustable during the programming phase for the new motos/ECUs while also building the fuel/timing maps.. could be wrong but don't know for sure..
    Bitingdog likes this.
  17. PistolPetey
    PistolPetey Been here awhile Supporter
    Dec 17, 2009
    367
    Wild West BC
    I ordered the True North Moto rack a couple weeks ago. Install was straightforward. Rack is nice fit and finish, good customer service.
    I was worried It might interfere with mx boots and on hard single track, but o can’t even tell it’s on.
    Mosko R80s and the GL Mojave’s fit solid and in the correct positioning.
    Highly recommended!
    838205E5-CADC-4E21-85B6-483FAA6A124B.jpeg 2F6DA2DF-81B4-41CD-B568-E4AF7285B69F.jpeg 2D331D97-5A24-4609-9AC1-F609D3121A83.jpeg 23216161-3DA0-467F-A324-F5D2C11164CB.jpeg
    Buildzall and Bitingdog like this.
  18. Takataka
    Takataka Been here awhile
    Sep 26, 2014
    861
    NZ
    Doesn't that strap anchor on the right side cause problems for your boot?
    Brokein2 and Fast1 like this.
  19. PistolPetey
    Dec 17, 2009
    367
    Wild West BC
    A bit. I left it on when I installed the rack to compare mounting points and provide another option between the R80 and the GL Mojave. I’m pretty sure I’m gonna take it off.
    Takataka likes this.
  20. JP4
    JP4 Thumper Geek
    Mar 22, 2003
    706
    Hood River, OR
    New GET ECU from Taco Moto Co this week as well as the PMB end cap with the Ultra quiet insert. I left the reeds in for now until I get a few trail rides on it to see how I like it. I bought the one without the WiFi module, since I didn't think I'd need to mess with it. After riding it a few times, I'm really happy with the improvement in performance and smoother throttle response. This bike already had way more power than I could use, but now it's usable at lower rpm. I can putt around in a taller gear without any shake, shudder, or knocking. It really feels more tractable down low.
    We finally got a little rain here, so hopefully more is on the way and we can get the trails back open so I can put it to a proper test.
    Also, the Ultra quiet insert is really pretty quiet. It's a little deeper tone that's more pleasing to my ear than stock, but the difference in overall sound level is minimal. Very happy with it. 20210909_110248.jpg 20210903_204440.jpg
