2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    993
    Dallas, TX.
    Hey thanks, I always thought they would just pull out or mabey kick them real hard to pop them out. Sure glad you told me or I would have not known till it was to late.
    MeefZah likes this.
  2. old Roman
    old Roman weekend adventurer
    Jan 24, 2010
    196
    EU - Slovenia
  3. chevmekanik
    chevmekanik Been here awhile Supporter
    Mar 28, 2012
    241
    West Kootenays
    2596CF2F-F157-4D60-A214-1ED0705ACAEB.jpeg 1DB6DDAF-769E-456E-BA8E-B0BE2EFAD736.jpeg
    Say no to snow!
    Finally have new bike accumulating break in miles. Now that I actually have a KTM I am now entitled to tell everyone how they are doing it all wrong?
    roookie1, DCGH, David_Moen and 4 others like this.
  4. NextAdventre
    NextAdventre Been here awhile
    Mar 25, 2013
    278
    Western NC
    Been using hard luggage for a few years. Planning to use panniers on the 890 with a KTM topcase. I’m impressed with how well built these Tusk Pilot panniers appear to be. Was doing a test pack and fit on the new bike. Looking forward to the annual moto-camping trip.
  5. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,981
    vermont
    JUst brought my 890 R home today. I searched for this answer and didn't find it.
    There's a ACC1 and ACC2 power in the front and rear. I only see 1 fuse for each under the seat 10 & 15amp respectively. I'm guessing they are on the same circuit? In other words, you have 10/15 amps between the front and rear? And, which one is switched? On my 690 only one of them is under the front mask.
  6. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,551
    Upstate NY
    Yes, there are 2 ACC1 and 2 ACC2 sockets - 1 each in the headlight pod and 1 each under the seat. On the 2019 790 ACC1 is always on and is fuse 7 ACC2 is switched and is fuse 8. Both are 10A.
    Yukon Ho! likes this.
  7. RoaringTodd
    RoaringTodd Been here awhile
    Aug 14, 2013
    334
    I can't find any gray gloss 890 base ADV's at the three KTM dealerships near me. Of course, I happened on 2 at a dealer's floor in West Virginia when on vacation with my wife last weekend. Loved the color and made up my mind to find one in Philadelphia, only to find out they're all gone. Hopefully this color continues into 2022.
  8. levain
    Oct 29, 2005
    10,981
    vermont
    I just got a new 890 and feel like I'm going to have silly random questions that I can't seem to find an answer for through search. Here's another:clap
    I use and like Oxford heated grips. I've always ran them to a switched circuit. I think something has changed since I installed them on my 690.
    The directions now state , and recommend, you can safely wire them direct to the battery since they automagically sense the bike isn't running and shut them off. Parasitic draw sucks. How have you wired your Oxford grips, on your 890? I'm not interested in what you did with any other brand of heated grips. Asking specifically about Oxford.
  9. David_Moen
    David_Moen Long timer Supporter
    Apr 23, 2006
    2,150
    Salmon Arm, B.C. Canada Eh!
    Great to see you finally got it!
  10. SCPancho
    SCPancho Old farts riding club. Supporter
    Oct 27, 2005
    35,075
    Upstate SC
    Agree. Dumb place to save money. Actually can’t see that it would cost KTM any more.
  11. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,302
    Austin, Texas
    No one that I am aware of has run Oxford heated grips on the 890. It’s because of the unique grips KTM uses. Search the main 790/890 forum for the heated grip thread.
    levain likes this.
  12. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,173
    Lexington, Ohio
    I got you.
    I went to battery. It was actually easier than taking apart the headlight nacelle and going to the ACC wires.
    I've had several of the Oxfords in the past few years and the auto off technology is 100% now - there's no risk of leaving them on and draining the battery as there used to be. In fact all 3 bikes in my garage currently wear the version 8.0 ADV grips and no issues. They work great.
    If you go to battery you can do it without removing the tank if you poke the wiring through just under the top right side of the tank. Using a strong piece of wire or similar helps get it through. A piece of wiring loom can then be slid over the wiring to protect it from engine heat and abrasion.
    I will warn you getting the factory throttle grip off is a nightmare. I'd suggest buying a new throttle tube.
    The photo angles make the wiring look way more exposed than it actually is... and don't mock my "custom " controller bracket...
  13. MeefZah
    Nov 19, 2003
    15,173
    Lexington, Ohio
    ^ oh also, my experience with installing these has led me to this bit of advice:
    don't use the included super glue, use a high temp epoxy... I use JB Weld. The grips tend to rotate on the bars under high heat if you use the super glue. I've never had a grip failure that would necessitate grip removal so I have no qualms using a "permanent" type adhesive.
    levain likes this.
  14. alonad
    alonad Been here awhile
    Mar 5, 2013
    993
    new york
  15. levain
    Oct 29, 2005
    10,981
    vermont
    @MeefZah looks great. Thanks.
    Did you destroy the throttle tube getting the old grip off? Why buy a replacement? I usually cut the stock grips off. I'm funny that way:rofl
  16. MeefZah
    Nov 19, 2003
    15,173
    Lexington, Ohio
    No, the throttle tube came out intact, but the glue KTM uses to adhere the grip to the tube is of incredible strength and a lot of it. Prepare to spend several hours cutting and filing and cursing. Knowing now what I didn't then, I'd have bought a fresh tube and just used it rather than waste my time.
    levain likes this.
  17. chevmekanik
    Mar 28, 2012
    241
    West Kootenays
    It is good to be out on it now. Deposit was last fall and have a small mountain of accessories to install on it.
    DCGH likes this.
  18. braaap!
    braaap! Long timer Supporter
    Mar 16, 2005
    5,518
    Melbourne - AU
    Sorry, you’re incorrect (maybe)...
    My 2019 had CC fitted and activated pre-delivery... In a box I have a LH switch block sans CC switch paddle...
    As @groot-stuff says... Non-recyclable waste! Or a fall back spare in case of an unfortunate event!
    As an industrial designer, I would have thought KTM would have cleverly designed the main switch block with a blank ‘patch’ that as std, was non CC enabled.
    Want the CC option? Pay a fee for having the patch popped out and a CC switch patch inserted plus the necessary software / firmware installation and off you go.
    Less wastage.
    Maybe global economies of scale in R&D, production, parts inventory control and warehousing, logistics etc simply dictate that 2 switch block types make $ sense.
    Hate ‘non recyclable waste’ though!
  19. wpbarlow
    wpbarlow Long timer Supporter
    Jun 9, 2003
    18,893
    Central NJ
    First time I've seen this color combo. I like it- makes the bike look more of a piece (aka less ugly looking :lol3).
    Kthursto and tft like this.
  20. rjk47
    rjk47 n00b
    Jan 2, 2012
    2
    B&B in Lancaster has a gray one.
    RoaringTodd likes this.
