2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,996
    Star Tannery, VA
    It would be cool to see dyno results with that cross over open and then plugged. I suspect there are some tangible benefits within normal RPM/throttle riding but would love to see it on paper. I need unlimited funds, time, and equipment. :)
    Nowwhat and BHoward like this.
  2. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    994
    Dallas, TX.
    I heard a vicious rumor it was almost 3 horsepower increase.
    My but dyno says, it will pull 3rd gear wheelies much easier. I'm guessing it helps the power in the 5000-6000rpm range.
    MtnRoamer, Nowwhat and windblown101 like this.
  3. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,308
    Austin, Texas
    Has anyone changed their tires yet and had a “defect” in the sealing strips on the rear wheel? I’m getting jerked around by my dealer. God, the KTM dealer network is BS.
    Had some motoz tractionator gps mounted up to replace the tkc80’s. First off the dealer didn’t balance which I called them out on. Then when I get home and start cleaning the wheels I notice air bubbling from a couple spokes. I knew exactly what happened, but back to the dealer who tells me I now owe another $150 for this “defect”. I lost my damn mind to say the least.
  4. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,831
    Jacksonville, FL
    Get used to it... It's a love hate relationship.
    tft likes this.
  5. windblown101
    May 17, 2010
    8,996
    Star Tannery, VA
    Not leaking when you took it in and leaking after they changed the tire? Sounds like their tire monkey screwed up the rim strip and they don't want to have to eat the cost. How high up the food chain have you gone with the dealer? That sort of thing is bad for ones blood pressure.
  6. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    Well last night I was dealing with the service manager who decided it was the right time to try and sell be a tire and wheel plan. Today it’ll be the owner if need be.
    If they would’ve found the “defective” sealing strip when they pulled the tire off for the first time I’d likely be fine with it. My frustration stems from them sending me out into the world with a leaking tire. There is a reason I do most my own wrenching. I just hate doing tires.
  7. windblown101
    May 17, 2010
    8,996
    Star Tannery, VA
    It's not surprising they missed it as it's easy to miss the damage. No shops I know of test for a leak after installing a tire unless it's obviously spewing air. All that said, it sounds like they goofed and should be fixing it on their dime.
    I'd have a calm talk with the owner. If you don't get anywhere then walk away and forget they existed. Life is short, buy some spoons. ;)
    BHoward, Yukon Ho! and tft like this.
  8. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,963
    Denver, CO
    Stand with them while they pull the tire off to show you the defect and point out the tire money damaged it. The strip may not be damaged sometimes it just gets knocked loose. But that dealer is treating you badly
    tft likes this.
  9. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    Here is a pic. You can just see the band not seated in the grove. Something to keep an eye out for.
  10. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    Update on the tire “saga”:
    The sealing gasket strip and outer rim strip are on back order. Looks like I’m running a tube for the time being. I’m about to take off on the AZBDR from Texas. Hope it all holds up.
  11. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,510
    Lexington, Ohio
    Having not actually peered inside, and not seeing the image too well... are these held in place essentially by air pressure, or glued in, or what? I've always kind of envisioned just sort of a "factory" Outex kind of deal.
  12. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    11,231
    vermont
    Trying to remove the TFT to gain access to ACC wires under headlight. He mentions a clip at 1:08. I can't find one. Yes the screw is removed. what am I missing? Something is holding it on...
    Edit: Ahh! Of course, after posting I stick a screwdriver in and work this little post out. I was looking for a "clip"
    tft likes this.
  13. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    I’m honestly not sure. I haven’t been able to look for myself. I believe there is a channel that they mount into. Surely someone on here has first hand experience. These are my first spoked tubeless wheels.
  14. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    Its easiest to remove the headlight in my opinion. It’s honestly not hard at all and gives you super easy access.
    darkstar1269 likes this.
  15. svtride
    svtride Been here awhile Supporter
    May 5, 2013
    860
    SE Michigan - MotorCity
    IMO, after watching the video, pulling the whole headlamp assy was easier and less risky to damaging headlight surround and trim pieces.
    Then I just fished fabricated pigtails for ACC1 & 2 up to access ports which also connect to the GPS mount cavity. All this can be done on bench.
    MBigButt and TrailTrauma like this.
  16. brianbrannon
    Dec 15, 2009
    3,963
    Denver, CO
    I've done a shit load of 1190 tires with the same strip. Just lube the sealing strip and push it back into the channel it seals into.
    tft and MeefZah like this.
  17. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    559
    West Grove PA
    thats what I was wondering- what is the life expectancy of a rim strip if you lube it and dont rip it up doing a change. Id hope it last 5 or 6 tires. Brian seems like you state yes, it should last multiple changes if done right. Thats good to hear.
    The fella that posted his leaked -what # tire change was that. and yes, seems like crappy dealer handling just to say oh, its gonna be another 150.
  18. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    Can I give you my mechanics number? Lol
  19. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    1st tire change.
    The dealer doesn’t know what they are doing or talking about.
    If I can just get my tire and wheel back I’m doing it myself.
    It’s a whole mess at this point.
  20. tft
    Nov 30, 2012
    1,308
    Austin, Texas
    What do you use to lube the sealing strip?
