2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. darkstar1269
    darkstar1269 Adventurer
    Nov 20, 2018
    24
    PHX, AZ
    Pack lots of water for the southern sections up to Young...it got hot this week quickly!!! I am sure you are watching the weather, but you know, as a local guy here, it's habit to remind everyone to hydrate often
    tft likes this.
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,465
    Star Tannery, VA
    Just about anything. You just want something slick that will make getting the edge slid back into place easier. As I recall I used silicone when I replaced mine when I had to work the edge of the seal back into place once when I had pulled it loose while getting a tire off the rim. If it is not completely in place it will leak even if not actually damaged.
    Two strips, red one is more like a traditional rim strip the black one is the "sealing" strip. When mine was finally shot and beyond help I replaced just the black part. It's a PITA to install a new one. If you have to go that route take your time and expect to have sore fingers when done.
    Kthursto and tft like this.
  3. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,607
    Denver, CO
    I used 303 rubber protector on the strips and they lasted 7 years and 64,000 miles
    live2ridetahoe, MeefZah and tft like this.
  4. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,301
    Austin, Texas
    Does this look right to y’all? How close the caliper is to the spokes and the deflection on the brake disk?
  5. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,524
    Upstate NY
    That looks a little too close. I have about 3/16 clearance on both sides, evenly spaced.
  6. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Yeah, that’s what my right side looks like.
    They are definitely not even spaced.
    I just reinstalled the front wheel. I can’t imagine what I did wrong. I went over it like 6 times.
  7. kubcat
    Sep 22, 2016
    2,524
    Upstate NY
    If it was further away before you removed the wheel, and its closer now, the only thing I can think of is that the rotor is skewed and you happen to be at the closest point there. IS the rotor flopping around at all? Some have reported the rivets being quite loose.
    edit: I just looked at your first pic, and you can see the rivet is popped out and angled just above the caliper assembly. Its not that way on the other side.
  8. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    The rotor isn’t warped that I can tell.
    Did I mess up a spacer?
    When I tighten the large axel nut up it definitely pinches the rotor like that. If the axel nut is loose it seems more in line.
  9. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    I may have a spacer on backwards. Can you send me a pic of yours?
  10. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    The rotor is definite pinched. It won’t free spin at all.
    edit: it seems the dealer mounted my tire the wrong way. I flipped it and everything lines up better. I thought the wheel wasn’t directional?
  11. kubcat
    Sep 22, 2016
    2,524
    Upstate NY
    The wheels and axles are definitely directional...
    tft likes this.
  12. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    well just another example of how TJs in Austin screwed me.
  13. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Im embarrassed that I didn’t notice the abs ring before. I appreciate all your help.
  14. levain
    levain STILL Jim Williams Supporter
    Oct 29, 2005
    10,957
    vermont
    I hate it when I have one leftover:scratch PXL_20210507_174111636.jpg
  15. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,114
    Lexington, Ohio
    Best guess is the fuel tank plastic shroud, the section that is extends under the seat that is then overlapped for a few inches by the rear plastic. Each side has one of those concealed under the overlapped section. They also are the airbox cover screws but you'd probably notice one of them not installed. I think they also are used in a few places on the gas tank shroud towards the front of the bike but those are all sort of exposed and you'd likely notice one missing... t
    levain likes this.
  16. comradecasey
    comradecasey Been here awhile
    Jun 5, 2018
    973
    Oregon / Tennessee
    You just increased the power to weight ratio without spending any money. Good job :thumb
    VandallusBand, kzeb and levain like this.
  17. windblown101
    May 17, 2010
    8,465
    Star Tannery, VA
    Put it in the spare parts bin. I'm guessing you'll find a need for it some day. ;)
    Or if you prefer not having parts randomly fall off the bike then start digging. There is only a few places where that screw is used.
    levain likes this.
  18. levain
    Oct 29, 2005
    10,957
    vermont
    Front end somewhere. I just wired a gps. I had 10 or so of those screws. I swear I got them all back where they belong. Except one:lol3
    windblown101 likes this.
  19. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    My guess is the gps mount.
  20. levain
    Oct 29, 2005
    10,957
    vermont
    Nope. I'll keep looking though!
