2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,426
    Lexington, Ohio
    Mmmmmmmmmm.... beefy
    MotoZ Tractionator Adventure
  2. tahoeacr
    tahoeacr Long timer
    Jan 7, 2007
    2,326
    Lake Tahoe
    BB74E09D-FC5A-4A68-9AD5-55DD8019285A.jpeg Break in ride
  3. from_ky
    from_ky Adventurer
    May 23, 2018
    62
    Florida Panhandle
    For those that have the Standard (non-R), how does it perform on gravel, loose dirt, light to medium sand? Nearest dealer does not have any R models in stock, but has several standard models.
    Can the standard model handle the ID and CO BDRs? I realize these are two different ends of the off-road spectrum.
  4. BHoward
    BHoward Been here awhile Supporter
    May 5, 2014
    994
    Dallas, TX.
    Yep, the S will handle all the BDR's easy. However IMO the R will handle better, faster and easier.
    I have rode them on a 1190, they are designed for big adventure bikes, a 500-pound 790S well cruise over them easy. BTW my 1190 at full camp gear is touching 700lbs .
  5. from_ky
    from_ky Adventurer
    May 23, 2018
    62
    Florida Panhandle
    That is a lot of standing weight. Good to know.
    The BDRs are more a wish than reality, but I figure if it can handle that, then the fire roads, forest service roads, and occasional rutted dirt road would be easy enough. I’d rather have the R version, but nothing close by.
    NextAdventre and BHoward like this.
  6. motokeith
    motokeith Long timer
    Mar 29, 2012
    1,157
    Falcon, CO
    If you want the R then go to your dealer and put down a deposit to reserve one. Yeah it will require some patience, but don't settle for something that is not what you really want and then regret the purchase.
    BHoward likes this.
  7. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,812
    Jacksonville, FL
    Which would you rather have??
  8. from_ky
    from_ky Adventurer
    May 23, 2018
    62
    Florida Panhandle
    roookie1 likes this.
  9. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,307
    Austin, Texas
    The only real difference is the adjustability of the suspension right? I mean if you don’t like the low fender or color-way all that’s interchangeable. Can you get the tech pack on the S so you can get rally mode? I love that new grey color on the S.
    This probably doesn’t help.
  10. rsmith56
    rsmith56 Been here awhile
    Aug 4, 2016
    627
    NW of Lubbock TX
    Change tires?
  11. from_ky
    from_ky Adventurer
    May 23, 2018
    62
    Florida Panhandle
    Seems the suspension is the major difference. Only 7.9” travel front and back. And not as much adjustability. Course that means less ground clearance as well.
    Slightly shorter in overall length (by like an inch).
    Rally and tech packs are same options.
    Definitely need different tires.
  12. ianmp
    ianmp *****
    Oct 12, 2009
    219
    California
    I rode the S and was very impressed. the suspension has a weird, crashy feel but it gets the job done. I would be happy to own one for doing graded fire roads and the like.
    Having said that, I got the R so I could do dumb stuff. If you want to do that the R gives you more headroom
  13. Rich Rider
    Rich Rider Adventurer
    Nov 4, 2011
    37
    Edmonton, Canada
    Koso Apollo grips have just that type of controller. I had a set that I had been holding on to for a couple years until I picked up my 2021 890 Adventure and had them installed. They are exactly what I wanted. No bulky controller strapped to the bar (hello Oxford!) and a simple one button controller to scroll through three very effective heat settings (blue, orange and red). Get 'em if you can.
    alonad likes this.
  14. alonad
    alonad Been here awhile
    Mar 5, 2013
    996
    new york
    Hey just to make sure the link is for the size of the 790/890 bars correct 120mm?
  15. kirill_k
    kirill_k Adventurer
    Aug 9, 2013
    86
    Moscow
    kzeb and Thumper Dumper like this.
  16. Crazysheep
    Crazysheep Adventurer
    Jan 7, 2015
    88
    Spain, (north)
    Similar system has the guzzi v85tt. A button for the on/off/temp and the icon in the TFT with the selected level
  17. Ham
    Ham Long timer
    Aug 29, 2004
    1,171
    Montana
    XArmy, Dan D. and MeefZah like this.
  18. McMal
    McMal They are now making electric what?!?
    Nov 30, 2017
    25
    Central Coast NSW
    If anyone is searching for how to take the DB Killer / Baffle out of the 890 R Rally Akrapovic Muffler, I can tell you that it's a major pain!!
    The bolt that you normally just remove to slip the baffle out is welded into place. I think I wrecked 3 drill bits drilling the bolt so I could remove it.
    You can get to the bolt by drilling a hole in the end cap underneath, assuming they are all in the same spot on all pipes, but you can't just undo the bolt. Mine was welded in with no chance of breaking the welds.
    So was it worth it?
    The sound is good with the baffle out, not loud at all. But I'm not sure I'd do that again. It is a major pain. I'd only recommend it if you really want to keep the Akro.
    Cheers
    tk1250gsa and tahoeacr like this.
  19. tk1250gsa
    tk1250gsa Been here awhile
    Apr 8, 2014
    786
    Brooklyn
    cruise control issue still going on. my 155mi on 890 adv r cruise control already stop working and most of dealer service center require a month of waiting list to get serviced.
  20. tk1250gsa
    Apr 8, 2014
    786
    Brooklyn
    I was thinking to do that.. hum is Akra slip on that come with factory rally version is same form purchasing aftermarket one?
    I have 890 adv R and ordered Akrapovic slip on
