2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. alonad
    alonad Been here awhile
    Mar 5, 2013
    996
    new york
    i guess i am and thinking about it tend to agree about the design flaw, I do check the fit every time and it does take me a few times to get it right . the do recommend that you grease the rubber frame of the filter to insure a seal but i guess it can still get through the wedge
    kubcat likes this.
  2. slowkiwi
    slowkiwi Adventurer
    Sep 6, 2020
    87
    new zealand
    I thought I was careful, using lots of grease, and still got caught out. As soon as I found dust past the filter I ordered a Rottweiler airbox and havn't looked back..
    for ref it was enough of a problem that my inlet shims needed adjusting.
  3. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,780
    Denver, CO
    The Gugglatech filter isn't soft and pliable like the stock filter. It seals fine
  4. MtnRoamer
    MtnRoamer Been here awhile Supporter
    Dec 16, 2015
    328
    Oregon
    Does anyone have experience running SRT tubes on the street? I have a long ride coming up that will involve a few thousand street miles and these seem to be all the local KTM dealer is stocking. I have not heard of them and I am a bit hesitant to trust a brand I am not familiar with for a few thousand high speed street miles. Worst case I can swap the tires and keep running the tubes the bike came with, but I typically prefer to swap them out with the tires.
  5. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    537
    Durban South Africa
    My experience with the air filters is as follows:
    1. Standard paper filter seals fine, the sealing face is made of a soft rubber. Never had any dust pass through.
    2. Power parts foam filter did not seal and was recalled. I don't know if they have changed the design of the filter yet, I never bothered taking it back and its in a box with the Uni-filter. Had the filter installed for a few months before KTM SA recalled them. Did find some dust passing but since I greased the seal before installing and inspected frequently it doesn't appear to have been much.
    3. Uni-filter had the same issue as the power parts one, I'm still waiting for a reply from them regarding their defective filter. The saving grace with this set up was the snorkel filters caught the dust before it could get to the airbox. Pretty much what the Rotti power plate does.
    One of our local guys cut up a filter box to investigate the cause and found that apart from the rubber on the aftermarket filters being to hard the corners of the sealing face have a different radius to the standard paper filter. I believe the wedge only caused the airbox to deform when I used the power parts and Uni-filter filters with the harder rubber seals.
    I ended up running the standard filter with the Uni-filter snorkel filters with no dust passing (checked after every dusty ride) until I replaced the air box with the Rotti one.
    Now I have piece of mind that it works as intended and I can carry a spare for quick change if need be. It is an expensive way to go though especially when you consider that the ease of changing the filter was one of the selling points of the 790 adventure.
    What ever filter you decide to use, inspect frequently and install carefully.
    MeefZah likes this.
  6. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,400
    Lexington, Ohio
    I ordered the prefilter. I don't really need (or want to wait 10 weeks for) the airbox replacement. Thanks for the info.
    I still need the air filter from my original post though, LOL!
    kubcat likes this.
  7. jojojones
    jojojones Long timer Supporter
    Jul 21, 2016
    1,925
    Long Islandistan
  8. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,782
    Star Tannery, VA
    The TwinAir has very little filter surface area. IMHO a flat foam filter sized to the small overall dimensions of the OEM is the worst filter design offered for the 790. Heck, my riding lawn mower has a bigger filter.
    The OEM filter despite the small over all dimensions probably has 4x (or more) filter surface area due to the pleating. Slap a fairly open easy to get to pre-filter in front of it and call it a day, or go for an airbox replacement that offers a much larger foam filter.
    comradecasey and jojojones like this.
  9. alonad
    Mar 5, 2013
    996
    new york
    the only question how much water can get in if you get stuck in water ,anyone had that experience and can share
  10. Safariaddict
    Safariaddict Safari 2010 FINISHED
    Feb 24, 2010
    234
    NSW
    Anyone interested in a slightly used 890 Rally
    ErGuss likes this.
  11. MeefZah
    Nov 19, 2003
    15,400
    Lexington, Ohio
    Dibs on the air filter!!! :lol3
    ErGuss, alonad, Tjf1967 and 1 other person like this.
  12. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    537
    West Grove PA
    I guess going to the aluminum steering stem on 890 wasn't a good idea :-) gotta be a good story here
    yikes
  13. jrodgolfer
    jrodgolfer Wannabe
    Jan 20, 2005
    333
    Eagle, ID
    just to close the loop in the event someone has a similar issue:
    Dealer says oil pressure was fine, but they found a lot of assembly lube on the oil filter. They changed the oil, rode it for 40 miles, dumped the oil and cleaned the filters again and refilled with new oil. They report that the issue is resolved. I’m happy with the way it’s been handled, and the responsiveness of the dealership. If you’re in or around Boise, I’d recommend Carl’s Cycles.
    ErGuss and MtnRoamer like this.
  14. dirtymartini
    dirtymartini Shaken, Not Stirred Supporter
    Aug 20, 2004
    2,850
    Beaumont, PA
    Wow, WTH happenef?
  15. tex68w
    tex68w Mister Bevilaqua
    Jun 2, 2017
    1,386
    SoTex
    Disregard, I found the Rottweiler option.
  16. striped tomato
    striped tomato Been here awhile
    Sep 4, 2011
    356
    Brisbane, QLD
  17. windblown101
    May 17, 2010
    8,782
    Star Tannery, VA
    Wow. That must have been a gnarly hit. The aluminum steering stem may be weak point by the looks of it however if it had a steel stem it may have just destroyed the forks instead. Either way, that's a tough bit of luck. :(
  18. TrailTrauma
    TrailTrauma Nemophilist Supporter
    Jan 17, 2012
    7,056
    Planet Fucking Earth
    Jesus...
    But the imagery that sprang to mind was the hobbled rider limping off, something dark and mysterious tucked under an arm muttering .. 'ain't nobody taken ma alien vajaja...'.
  19. markgrolex
    Jul 23, 2017
    537
    West Grove PA
    oh I agree, I doubt there is any issues with that alum stem-- nothing could take two kangaroos. And you are right, it might have been worse with steel stem
  20. Thumper Dumper
    Apr 13, 2016
    537
    Durban South Africa
    Fully agree with the surface area theory although I believe the pleated filter will give far more than 4 x the surface area.
    A pre-filter will also reduce the surface area even more than the TwinAir filter, I'm also aware that you can carry a spare pre-filter but the same applies to the TwinAir one.
