2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. sherloc
    sherloc Been here awhile
    Jan 24, 2015
    289
    KCMO
    Nice 690! On the 790/890 pair, the 790 weighs out ~20 lbs lighter then the 890 series in the listed wet weights. As for S or R, spend the money on the R, and get it lowered (ktm has a kit) to S suspension height.
    GF-kam likes this.
  2. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    9,207
    Star Tannery, VA
    I recall seeing one published report claiming that kind of weight difference, however there have been a few published reviews since then that included weighing the bike and the figures they have come up with are very close to KTMs claimed wet weight which makes it almost identical as the real world wet weight of the 790 ADV-R. I seem to recall hearing somewhere that KTM either had to or opted to change how they calculate published weights between when the 790 was produced and the 890 came out. Which would explain the vast weight difference KTM lists in their specs.
  3. sherloc
    Jan 24, 2015
    289
    KCMO
    The 890 does have an extra balance shaft, and 20% was added to the crank, so there must be some weight increase, unless KTM removed the added weight in other areas. I guess we need a weigh-off between the 2.
  4. Nowwhat
    Nowwhat I'll Go Second... Super Supporter
    Mar 2, 2007
    9,981
    On the Ground Laughing
    The bikes are about 2 lbs different...
  5. sherloc
    Jan 24, 2015
    289
    KCMO
    Folks spend $800+ on the Akra to save 2 lbs...
  6. Nowwhat
    Mar 2, 2007
    9,981
    Hahaha ....
    Yeah.. the akra that comes as a power part isn't anything but a pretty face...
    TrailTrauma likes this.
  7. windblown101
    May 17, 2010
    9,207
    Star Tannery, VA
    Yeah, I was bummed when Akra went all euro 4/5 compliant. Now it's just another OEM can and when it comes to OEM cans KTM already makes the best ones so why bother.
    ErGuss and Nowwhat like this.
  8. Shodan2
    Shodan2 Been here awhile
    Aug 19, 2018
    137
    West L.A., California
    Anyone knows of a fix for the poor cold start performance? Seems to be the case when the bike is at merely 12-15C after a night. At ~22C which is typical temperature for the basement garage it's parked normally - no issues after the break-in period.
    I'm concerned because I'm planning on doing some travel on it, but if it's struggling to start at 12C it might not start at all at 5C, let alone below freezing point. At least not before draining the battery. At which point I'd be screwed...
    A 2015 KTM-1190 I used to have before - started at -3C no problem. Ditto for my old 2009 Yamaha FZ6 street bike...
  9. DCGH
    DCGH Been here awhile Supporter
    Nov 30, 2020
    159
    Salmon Arm, BC
    When I was riding in March here in Canada the temp was regularly below 0C and the bike started with no issue, not sure why you are having issues, mine start fine at any temp from 45C down to -5C (yes that was a cold ride to work :))
    ErGuss likes this.
  10. Tjf1967
    Tjf1967 Adventurer
    Jan 21, 2021
    34
    Brunswick ny
    I picked mind up on a very cold day. -8 Fahrenheit. I have no problems starting it no matter the temp.
  11. Thumper Dumper
    Thumper Dumper Been here awhile
    Apr 13, 2016
    566
    Durban South Africa
    There are a couple of threads dedicated to this issue. Cold start problem 890 adventure | Adventure Rider (advrider.com)
    and this one for a 790 KTM 790 takes a few tries to start | Adventure Rider (advrider.com)
  12. Ham
    Ham Long timer
    Aug 29, 2004
    1,188
    Montana
    Tadpole, MaxFuel, Footy and 5 others like this.
  13. Ham
    Ham Long timer
    Aug 29, 2004
    1,188
    Montana
    Anxious to know in depth what you think of that Sargeant seat. Do you like it in that configuration or should a guy smooth out the bump?
  14. Idahopilot
    Idahopilot Been here awhile
    Oct 28, 2004
    140
    Idaho
    Absolutely not true; tequila makes my wife’s clothes fall off. :imaposer
  15. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,835
    Jacksonville, FL
    I used to work with a lady who said the same thing...
  16. tex68w
    tex68w Mister Bevilaqua
    Jun 2, 2017
    1,547
    SoTex
    I am assuming that most of you running the Arrow Cat Delete/Mid-Pipe aren't running any kind of running/fueling/mapping?
    kubcat likes this.
  17. DCGH
    Nov 30, 2020
    159
    Salmon Arm, BC
    I'm not...seems to run fine
    kubcat and tex68w like this.
  18. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,591
    Lexington, Ohio
    So my 890R been in the shop 29 days. They called today to basically tell me it needs a new wiring harness BUT KTM is having an issue replacing it under warranty because...
    ...there is an aftermarket skid plate and aftermarket "head support" on the bike.
    The head support, according to the tech, is going to be the hurdle. KTM is claiming that it chafes wiring. No wiring is chafed or even touched by the support and I'd argue that if KTM built the stupid things robustly enough to handle the stuff they claim it was built to handle, the issue of headlights falling off wouldn't need to be fixed by the aftermarket.
    We shall see how the fight goes!
    ErGuss, JimmyMojave, Bullseye and 2 others like this.
  19. Nowwhat
    Mar 2, 2007
    9,981
    Well that just sucks......Hope it works out...this is one of those times you need the owner of the dealership to go to bat for ya....skid plate...sheesh....
    Your post will probably get others to pull their head braces off before going to dealer for an electrical issue...sigh
    EvilSteve and MeefZah like this.
  20. tex68w
    Jun 2, 2017
    1,547
    SoTex
    MeefZah likes this.
