2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,308
    Austin, Texas
    My grips are on order, is the connecter in the headlight marked or is it easy to tell which it is?
  2. Yellow Pig
    Yellow Pig Allergic to asphalt! Supporter
    Oct 28, 2004
    9,813
    Thousand Oaks, CA
    No it's kind of hidden away and has a protective plug cover on it, but it's the only 3 wire connector in there. Remember mine was on a Duke 890 R.
    Bomb_Dude and tft like this.
  3. 8lives
    8lives Dharma Bum
    Jan 16, 2012
    2,368
    Nor Cal
    Redding, but I ride to the coast often.
    MeefZah likes this.
  4. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,510
    Lexington, Ohio
    You should pop in on the Humboldt thread in regionals -> west!
    Several of us in Eureka.
  5. 8lives
    8lives Dharma Bum
    Jan 16, 2012
    2,368
    Nor Cal
    Thank you, I'll join up!
    MeefZah likes this.
  6. Bomb_Dude
    Bomb_Dude Adventurer
    Feb 5, 2011
    80
    Tijeras, NM
    Thanks, I opened mine today and could not find the connector. Nothing had a cover and 3 Wires. Any other ideas? IMG_2674.jpg IMG_2673.jpg
  7. markgrolex
    markgrolex Been here awhile
    Jul 23, 2017
    559
    West Grove PA
    what heated grips do you have on order? the older 790 model with external heat conrol switch or he new 890 ones ( that are not available yet) that integrate with dash and the existing bar switch. O dont think we will know until the new 890 unit arrives and see instructions. What I have kinda figured out is the new 890 ones will come with a heater control unit. and just below the battery to right under fuse panel is a big plug with a dummy cap. I think that is there the heat control unit may plug in based on pictures Ive seen of the control unit--and I suspect the second part of heat control unit will be for heated seats.
    Bomb_Dude likes this.
  8. motokeith
    motokeith Long timer
    Mar 29, 2012
    1,175
    Falcon, CO
    I'm anxious to get the heated grips, but I'm holding off on making any moves until they actually materialize. The KTM site was showing 63712964088 as the heated grip kit for the 890 Adventure, but that does not appear to be there anymore. I had chatted with a European supplier that had the 63712964088 part listed and they said it has been replaced by two part numbers: 60712964044 is the actual grips (same as the 1290 ADV I think) and 63712944044 (not yet available) is the control module. They had asked for my VIN# in order to make this determination so I have at least a little faith in the information.
  9. koekeroe
    koekeroe Been here awhile
    Dec 12, 2015
    163
    onder den haag
    with the heayed grips comes a bracked and a box
    you have to instal the controle box in the bracked
    you pul the sead of and take the tank of
    pul the fusebox of its bracked and you wil see a connector under there
    put the connector in the controle box and place the bracked wit he box on the place where the fusebox was sitting
    place the fusebox on the new bracked
  10. koekeroe
    Dec 12, 2015
    163
    onder den haag
    The connector for the heater grips sits under the abs module IMG_20210221_135504.jpg IMG_20210221_135829.jpg
    Pipeman and Bomb_Dude like this.
  11. Bomb_Dude
    Feb 5, 2011
    80
    Tijeras, NM
  12. Bomb_Dude
    Feb 5, 2011
    80
    Tijeras, NM
  13. Bomb_Dude
    Feb 5, 2011
    80
    Tijeras, NM
    Thanks for the info!
    koekeroe likes this.
  14. markgrolex
    Jul 23, 2017
    559
    West Grove PA
    Screen Shot 2021-02-28 at 5.28.45 PM.png Screen Shot 2021-02-28 at 5.28.15 PM.png
    great where do the actual grips connecter located- it would be just like KTM to hide it under the fuel tank-- why not just in headlamp mask or in front tube housing- they are good at making things harder than needed. Here is a 1290 instruction pic -looks like a 2 pin connector to me for the grips. Let us know where yours was and thanks!
  15. Bomb_Dude
    Feb 5, 2011
    80
    Tijeras, NM
    I have the new 890 Heated grips on order, not extra control box. That is if my KTM dealer didn’t screw it up! Lol
  16. motokeith
    Mar 29, 2012
    1,175
    Falcon, CO
    I'm about 98.5% sure your dealer screwed up and ordered the heated grips for the 1290 bikes. I believe those bikes have the controller built into the dash unit and the grips just plug into the rear of the dash unit. So the kit is just a set of grips with no control unit or bracket.
  17. hogmolly
    hogmolly Dude
    May 28, 2003
    3,305
    McKinney, TX and Breckenridge, CO
    I can’t wait to hear the feedback on the new grips. I’m still debating the Tech software package.
  18. Bomb_Dude
    Feb 5, 2011
    80
    Tijeras, NM
    890 ADVR in the sand! I need more time in the saddle!
  19. koekeroe
    Dec 12, 2015
    163
    onder den haag
    under the tank and the abs unit
    and its lebelt heated grips
  20. offworlder
    offworlder Been here awhile
    Sep 6, 2010
    755
    Vancouver, Canada
    El Bomba,
    I noticed your insect head (inside the electrical harness) pics show the euro turn signal lights, but the desert vid shows the NA turn signals?
