2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. asphaltsurfer1
    asphaltsurfer1 CatManDew
    Jun 24, 2011
    593
    By the pool
    Gremlins
  2. offworlder
    offworlder Been here awhile
    Sep 6, 2010
    738
    Vancouver, Canada
    I'm not as experienced as CJ, but have run 16-22 PSI on the rear without exception with no rim lock, and have had no issues. Majority of my riding is slower/technical, and I'm using the PP wheels.
    groot-stuff likes this.
  3. cjracer
    cjracer AWD please!!
    Sep 26, 2005
    4,138
    Mukwonago, WI
    So to be clear, I'm riding a 790 Rally, with tubed wheels. Not an 890 as this thread is about.
    I have run the oem tires down to about 20 psi for offroad testing and I have noticed tire slip on the rear rim b/c the valve stem has started to lean. That could have been the high speed field runs with low height lip jumps landing with the throttle on. But this was with the oem tires. Add a more aggressive tire and it normally just gets worse.
    On my 950 Adv I normally don't go less than 25 when off road for the same reason. So this test confirmed I need a rim lock and/or need to keep the psi a little higher on the 790 as well. Thats why I'd like to test a mousse and rim lock for aggressive race/trail riding.
    I've not set up the 790 with luggage yet, other than a tail rack so I can toss on a soft bag for my tent and bag, plus some clothes for 3-4 day rides and my tank bag. So not a very heavy load. With luggage or passenger it'd run higher psi. I found with my 950Adv, I'd never go below 30psi in the front for safety and avoid pinch flats. 30psi in the rear, or 25psi if I was solo and running mixed dirt.
    All psi specs are cold.
    The 790 is a much lighter and smaller bike than the 950Adv bike, but still no 500exc. I'll keep testing tires and psi setting to stay in the safe no pinch flat zone.
    I also have not ridden 2 up with my wife on the 790 yet. I'm 6'4", so I feel this is going to be a much less comfortable ride for the 2 of us. I plan to keep the 950AWD Adv delegated for 2 up use when needed.
    Here is what the IRC M5B looked like after about 200 miles. If I'd been in dirt, mud, sand. It would have lasted much better. Plenty good for a 60 mile hare scramble. 20210401_151522.jpg 20210401_151441.jpg
    pk1791, EvilSteve, offworlder and 2 others like this.
  4. cjracer
    Sep 26, 2005
    4,138
    Mukwonago, WI
    What tires are you running on that setup?
    Is the front a 1.85"?
    Rear 2.5"?
  5. groot-stuff
    groot-stuff Been here awhile
    Jan 18, 2021
    140
    Somewhere in the woods, Colorado
    Great info, thanks!
    Your specifying of the OEM tires is an important note for those that are less inclined about rims, tires, pressures and "inflation medium" (tubes, tubeless, tubliss, mousse)... different tire/rim/inflation medium combinations can have different results depending on the tread style/composition, sidewall plies, rim width, etc. etc. etc.
  6. offworlder
    Sep 6, 2010
    738
    Vancouver, Canada
    Correct, re PP wheels sizes. Re tires, Pirelli Scorpion Rally front, Dunlop 606 rear.
    cjracer likes this.
  7. abandoned track
    abandoned track Been here awhile
    Oct 16, 2012
    171
    OZ (as in Far East Kansas)
    I have not seen it reported yet for the 790/890 Enduro, but has anyone experienced overheating of the engine? The reason I ask is because of the design of the fuel tank it seems like it would limit airflow and then with some of the skid plate/engine guards I have seen, appearing like they further limit airflow.
    At this point in time for the 890, probably most of the experience of riding in 90+ degrees (32+ celsius) is with the Southern hemisphere riders.
  8. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,471
    Star Tannery, VA
    I've not seen any reports of overheating issues either and prowl the 790/890 forums pretty regular. I've gotten my 790 hot enough to boil the gas on a long slow stretch of terrain one time and even then the motor temp itself was fine. Overheating the motor seems to be a non-issue.
    tonyubsdell and cjracer like this.
  9. abandoned track
    Oct 16, 2012
    171
    "hot enough to boil the gas" --- that was my other concern
  10. kubcat
    kubcat Riding is Eudaemonic Supporter
    Sep 22, 2016
    2,527
    Upstate NY
    I think you should probably stick to the Japanese bikes...:hide
  11. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,118
    Lexington, Ohio
    Nobody?
    Were the questions too stupid to bother answering
    or were they too smart? :lol3
  12. kubcat
    Sep 22, 2016
    2,527
    Upstate NY
    either way is fine as its "technically" overfilled at that level anyway. If you check warm it will be a bit higher than if you checked when cold. I personally prefer to check after its warm, so any oil in the top end will thin out and I think its a bit more accurate.
    https://advrider.com/f/threads/790-chain-slack-whats-correct.1453243/
    MeefZah and groot-stuff like this.
  13. windblown101
    May 17, 2010
    8,471
    Star Tannery, VA
    Pump gas can have an amazingly low boiling point. It's not a cause for concern. Heck, some "winter blend" pump gas has butane added to it and Butane boils at 32F. So basically once it hits 32F it's outgassing the same stuff a BIC lighter does out the vent line. Watch out for sparks! LOLOLOL.
    kirill_k and alonad like this.
  14. Dan D.
    Dan D. Long timer
    Mar 13, 2020
    1,670
    Jacksonville, FL
    His tire was throwing roost 100 feet back, 100 feet high of pure railroad ballast. I know because I was behind him.
    Nowwhat, eRdd, ErGuss and 1 other person like this.
  15. Tjf1967
    Tjf1967 Adventurer
    Jan 21, 2021
    32
    Brunswick ny
    I'm dumb and didn't know that. I feel better about the boiling gas. Glad I don't smoke anymore.
    windblown101 likes this.
  16. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,301
    Austin, Texas
    I think I’ve boiled the fuel in every motorcycle I’ve ever owned come to think of it. Especially my Honda XR650l!
  17. cjracer
    Sep 26, 2005
    4,138
    Mukwonago, WI
    Roosting so hard it knocked over a 790.... :jack 20210327_163012.jpg
    Such a great day of 790 chasing.
    kirill_k, Dan D., kzeb and 1 other person like this.
  18. robin_nerf
    robin_nerf Adventurer
    May 28, 2020
    70
    Sweden
    In a small "goodie bag" I got a small pouch with some tools in, isent this suppose to have a compartment under the seat ? Also, when I lifted the seat I saw a loose cable, what's that ? (The big one on the left with mudguard over it)
  19. windblown101
    May 17, 2010
    8,471
    Star Tannery, VA
    You have the two storage boxes in the rear side panels you can use or it may fit in the recessed area where the air filter lid is.
    The large plug is for the optional alarm system.
    old Roman likes this.
  20. roookie1
    roookie1 Been here awhile
    Jun 15, 2009
    727
    Denmark
    Top of oil window sits 4-5 cm below the clutch. I cant see it make a difference. Clutch is getting oil from pump, not bathing in it..
