2021 KTM 890 Adventure / Adventure R / Adventure R Rally
Discussion in 'Parallel World (790/890)' started by 06Z, Oct 6, 2020.
  1. tft
    tft Spends to much time on advrider. Supporter
    Nov 30, 2012
    1,301
    Austin, Texas
    I haven't finished the job yet but its totally doable at home. I already have the heat mode unlocked. I'm not sure if the dealer did it when they did the tech pack or not.
    The connecter for the new control box is plugged into a dummy near the bottom right of the fuse box. Pull the fuse box, install the new holder in place of the fuse box, heated grips connector connects at the bottom of the new control module and then fuse box sits on top. Just need to take seat and battery cover off. I had to move the ground wire for my battery a bit for a little more room to work. The grips are super easy to remove, just look for the small set screw on the left hand grip. It took me time to install the right grip but thats because it was late and my brain wasn't working and i couldn't figure out how the wires were to be ran exiting the throttle housing. It helps to visualize if you remove the throttle tube completely and then drop the top half of the throttle housing into place. You can easily see how the little plastic piece that holds the wires sits. Tonight i'll pull the headlight and finish wiring it all up (plugging it in).
    Bomb_Dude likes this.
  2. Pipeman
    Pipeman Been here awhile Supporter
    Jul 5, 2010
    455
    North Central Pa.
    Awesome ! Hopefully my dealer will receive mine soon. You didn't mention having to remove the gas tank? Hope not.....
  3. Crazysheep
    Crazysheep Adventurer
    Jan 7, 2015
    88
    Spain, (north)
    Some pics with the mounting prices would be awesome
    Doesn't sound too easy for newbies...
  4. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    No, do not remove the tank. I actually tried to removed the battery tray thinking the plug for the new controller box was under there. I was too stupid to realize ktm made it easy and accessible and that they would take the time to actually mount a dummy cap for it.
    Pipeman likes this.
  5. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    i'll take some pictures tonight and add them to my previous post.
    Pipeman and Crazysheep like this.
  6. MeefZah
    MeefZah Curmudgeonly Supporter
    Nov 19, 2003
    15,131
    Lexington, Ohio
    I assume the entire throttle tube gets replaced with a new unit integrated into the RH grip? Cause ain't nothing easy getting the old grip off the existing tube....
  7. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Yes, very easy.
    Roll back the rubber flange and locate the small set screw, this is for the left side. Right side is just undo 2 phillips screw in the bottom of the throttle tube housing.
    The grips are whole units.
    Here is all I could find as far as instructions but it'll show how to remove the grips and give an overall idea. This is for the 1290 and 890 Duke I think.
    Go here https://www.ktm.com/en-int/service/manuals.html search for this part number 60712964044.
    Crazysheep and MeefZah like this.
  8. groot-stuff
    groot-stuff Been here awhile
    Jan 18, 2021
    140
    Somewhere in the woods, Colorado
    Crazysheep likes this.
  9. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Well f*^% I can’t find the plug for the wires in the headlight bucket.....how hard is it to remove the tank?
  10. windblown101
    windblown101 Long timer Supporter
    May 17, 2010
    8,490
    Star Tannery, VA
    I could have sworn I read somewhere in this forum that the plug for the heated grips on the 890 was not in the headlight bucket.
  11. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Yes, koekeroe made some post about it but I thought he had a duke for some reason. When I went back I saw he had the 890 rally I think.
  12. windblown101
    May 17, 2010
    8,490
    Star Tannery, VA
    Well good luck with it!
    gsuks likes this.
  13. brianbrannon
    brianbrannon They'll ride up with wear
    Dec 15, 2009
    3,616
    Denver, CO
    Shouldn't the grips plug into the new controller you installed?
    Maybe the other socket on the controller is for the heated seat? The wiring diagram is not great
  14. groot-stuff
    Jan 18, 2021
    140
    Heated grips plug location: https://advrider.com/f/threads/2021...venture-r-rally.1470293/page-80#post-41899964
    edit: corrected link to the post with pictures
  15. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Not that I can tell. They plug into each other and then there is a 2 pin plug. I can’t find the mate to that 2 pin plug.
  16. tft
    Nov 30, 2012
    1,301
    Austin, Texas
  17. groot-stuff
    Jan 18, 2021
    140
  18. tft
    Nov 30, 2012
    1,301
    Austin, Texas
    Ah, yes. That is what plugs into the module. the grips themselves have to plug into each other and then into something else. Reference my post earlier with the service manual “instructions” from ktm to see what I mean.
  19. David_Moen
    David_Moen Long timer Supporter
    Apr 23, 2006
    2,149
    Salmon Arm, B.C. Canada Eh!
    I have the service manual, but this installation does not seem to be covered. I'll see if I can find any reference to the connector.
  20. koekeroe
    koekeroe Been here awhile
    Dec 12, 2015
    153
    onder den haag
    the plug for the heated grips is above the camcover under the tank near the abs module
    Pipeman, tft and windblown101 like this.
