276C Device not found.
Discussion in 'GPS 101 - Which GPS For Me' started by twowheels03, Jun 9, 2011.
  1. twowheels03
    twowheels03 Adventurer
    Jan 26, 2010
    98
    Back in the Garage/regrouping.
    Hello Guys,
    I have acquired a used 276c, all looks to be ok but the MS on the lap top will not "FIND DEVICE".
    I have installed the drivers, checked updates.
    Un-installed all Garmin Progs and Re-installed.
    Called support and done all they asked.
    Send them the unit for testing - all ok.
    Tried a few USB leads - still the same.
    It must be something simple but I'm stuck.
    Can you help me please.
    Paul
  2. Countdown
    Countdown Long timer
    Oct 20, 2003
    6,933
    Carson City/Ridgecrest
    My friend's would not work on side ports, only rear port.
  3. TRZ Charlie
    TRZ Charlie That's MR. Asshole
    Nov 13, 2008
    20,769
    Tucson, Arizona
    What Countdown said. Try plugging the unit in via the usb port. Turn the 276c on then reboot the computer with the unit plugged in. I had a similar experience but rebooting with the unit plugged in helped the computer recognize the 276. After it's not happened again. Your results may vary but worth a try.
  4. twowheels03
    Jan 26, 2010
    98
    Thanks Guys, trying it now.
  5. twowheels03
    Jan 26, 2010
    98
    AAHHH, Tried that fella's, still no go.
    Tried all the leads I have as well.
    Back to Garmin or try and find a tech guy locally I guess.
  6. bush pilot
    bush pilot Long timer
    Jun 23, 2006
    2,526
    Thailand
    I went around and around with this a while back getting my 276c recognized.
    What computer and OS are you using. I'd tripple check the drivers as that is the likely culprit there. It was for me anyway.
    I forget exactly but I think there is a setting on the device as well. Check that.
  7. bush pilot
    Jun 23, 2006
    2,526
    Thailand
    I just checked how my unit is set.
    In setup com2 the format setting should be "garmin data tranfer" and the transfer mode "host".
  8. TRZ Charlie
    Nov 13, 2008
    20,769
    Tucson, Arizona
    I just did the same and mine is set up this way too.
    #8
  9. twowheels03
    Jan 26, 2010
    98
    Hi BP,
    Checked that out and found the problem. I went - my computer - system properties - device manager - I found a yellow flagged up un named file and deleted it - re-installed the device driver and hey - presto. fixed.
    Thanks all, stress levels were high but ok now.
    #9
