276C power cable ?
Discussion in 'GPS 101 - Which GPS For Me' started by greenlizard, Oct 24, 2010.
  1. greenlizard
    greenlizard adventure lite
    Feb 6, 2006
    131
    Chapin, SC
    Anyone have a source for the fused bare wire power cable with the old style 90 degree plug for the 276C? The one most commonly available now has a straight plug on the gps end which does not allow use of my Touratech mount. I stupidly let my power cord go with my last bike before finding out that Garmin changed from the 90 degree plug to the straight one while keeping the same part number. Argh. I guess I could cobble something up from a cigarette type cord I have laying around, but I'd rather not, if possible.
  2. TRZ Charlie
    TRZ Charlie That's MR. Asshole
    Nov 13, 2008
    20,769
    Tucson, Arizona
  3. dlew
    dlew Daypass Adventurer Supporter
    Oct 26, 2004
    2,145
    Brooklyn, NY
    That's a good question.
    Unfortunately that link goes to a connector that is not for the 276C, sorry to say.
  4. ramz
    ramz Professional Trail Rider Supporter
    Dec 11, 2006
    2,928
    Salida, CO
  5. TRZ Charlie
    Nov 13, 2008
    20,769
    Tucson, Arizona
    Sorry about the above link. Must have been a redirect as it was the right one. Here is one at CYCLEGADGETS.COM.
  6. greenlizard
    Feb 6, 2006
    131
    Chapin, SC
    Thanks, guys. I'll make a couple of calls tomorrow and post what I find out. As I said, the part changed but the part number remains the same. Several vendors including GPSCity.com show the 90 degree connector, but only sell the newer straight connector. If you have a Touratech mount don't lose the power cord!
  7. Cogswell
    Cogswell Now living the new normal.
    Jan 3, 2005
    10,567
    Riding with my pal Richard Cranium
    I have had two of the 90 degree power cord ends come apart on me so far. One was the car cord with speaker, and the other was hard wired to the bike.
    The outer sheathing just came off the end that plugs into the GPS and pulled a few of the wires loose. They may have changed the design to correct this issue. :dunno
    Good luck on your hunt.
    Mike
  8. greenlizard
    Feb 6, 2006
    131
    Chapin, SC
    According to the helpful lady at gpscity.com, you are exactly right. She told me Garmin has seen too many failures of the 90 degree plug and that is what lead to the new straight plug. The new plug looks more robust and seems to anchor the cable to the plug more securely. I called Garmin and got the same story. So. My next move is to cannibalize a 12 volt cig plug and make an old style cable so I can use my gps with the Touratech mount designed for it.
    #8
  9. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
    #9
  10. Cogswell
    Jan 3, 2005
    10,567
    Just got an email back from Larry at that site. They do not make anything for the 276c.
    Thanks for trying Bruce !
    Mike
    #10
  11. joefromsf
    joefromsf Dark Happens Supporter
    Apr 28, 2005
    2,101
    San Francisco
    Looks like there's two available on ebay right now. Search for "garmin 276c power cable". Note I am just going by the supplied pics. Best to verify with sellers they are the old right angle cables.
    #11
  12. greenlizard
    Feb 6, 2006
    131
    Chapin, SC
    Thanks for the interest guys. After some head scratching and fooling around, I found that the new, straight power plug WILL fit the Touratech mount. It may require a little bit of filing on the mount as it is very close, but it does work. Whew! The remaining issue is whether the plug will stay connected over rough terrain, since the mount does not keep it pressed into the gps like the older, 90 degree power plug was. Maybe some zip ties will help - I'll see what I can do. Photos will be posted when a solution is found.
    My 60CX works fine but I sure have missed the 276C's big screen and faster redraw!
    #12
  13. MarylandStrom
    MarylandStrom Long timer
    Dec 7, 2007
    1,224
    Beltsville, Maryland
    I got sick of replacing my power cord on my 276/376c/478. The last time it broke, I bought a new one and then downline a little I spliced in a four pin trailer plug. Now I never unplug the 90 degree plug on the back of the set. I just unplug the trailer plug which is far more robust. It was the perfect fix.
    I now have a trailer plug on my bike as well as the Garmin cable with the speaker box.
    #13
  14. mcnut
    mcnut Long timer
    Apr 26, 2006
    1,757
    Bakersfield CA
  15. rmhrc628
    rmhrc628 Long timer
    Feb 6, 2006
    3,076
    Melbourne
    I have just purchased the power cable for my 276C - down here in Ozstralia we are so backward we still have the old style 90 degree cables for sale brand new.
    Not knowing there was a superceded version of this cable, how long will I get out of it before it breaks?
    can i superglue it together to keep it in one piece?
    Also what is the suggested connection type to plug the GPS into? The ends of the cable are just bare wire and I'd like something a little better if you guys know of something
    #15
